[petsc-dev] Regression in Vec assembly
Jed Brown
jed at jedbrown.org
Tue Feb 19 23:32:33 CST 2019
Yuck, bad bug. I pushed a one-line fix to your branch. Can you let me
know if there are any outstanding issues? If it solves the problem for
you, I'll cherry-pick it to 'maint'. Thanks.
Stefano Zampini <stefano.zampini at gmail.com> writes:
> In the link I have sent you, ex29 was modified to invert the order of values set. There’s also a command line that shows the error
> mpiexec -n 3 ./ex29 -n 4 -invert -bs 2
> I have added the correct output, but if you run with bts you’ll see some of the entries are scrambled up.
>> On Feb 20, 2019, at 1:27 AM, Jed Brown <jed at jedbrown.org> wrote:
>> Is this what I'm supposed to see? What should I be looking at?
>> $ mpiexec.hydra -n 3 mpich-clang/tests/vec/vec/examples/tests/ex29 -n 126 -info | grep malloc
>> [0] VecAssemblyBegin_MPI_BTS(): Stash has 252 entries, uses 2 mallocs.
>> [0] VecAssemblyBegin_MPI_BTS(): Block-Stash has 0 entries, uses 0 mallocs.
>> [0] VecAssemblyBegin_MPI_BTS(): Stash has 0 entries, uses 0 mallocs.
>> [0] VecAssemblyBegin_MPI_BTS(): Block-Stash has 252 entries, uses 2 mallocs.
>> $ mpiexec.hydra -n 3 mpich-clang/tests/vec/vec/examples/tests/ex29 -n 126 -vec_assembly_legacy -info | grep malloc
>> [0] VecAssemblyBegin_MPI(): Stash has 252 entries, uses 2 mallocs.
>> [0] VecAssemblyBegin_MPI(): Block-Stash has 0 entries, uses 0 mallocs.
>> [0] VecAssemblyBegin_MPI(): Stash has 0 entries, uses 0 mallocs.
>> [0] VecAssemblyBegin_MPI(): Block-Stash has 252 entries, uses 2 mallocs.
>>> Jed,
>>> I’m resurrecting this thread since I believe this bug has not yet been fixed.
>>> I have spent a couple of hours today tracking down a bug in my code, that I finally confined to be related with VecSetValuesBlocked.
>>> I have pushed an example that shows the problem here https://bitbucket.org/petsc/petsc/commits/1cb7fb90b416ce1d4e4767a0d5a2ef5043656d53?at=stefano_zampini/feature-pcbddc-enablelor <https://bitbucket.org/petsc/petsc/commits/1cb7fb90b416ce1d4e4767a0d5a2ef5043656d53?at=stefano_zampini/feature-pcbddc-enablelor>
>>> Could you please have a look?
>>> Thanks,
>>> Stefano
>>>> On Apr 24, 2016, at 10:52 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>> Lisandro Dalcin <dalcinl at gmail.com> writes:
>>>>> Do you remember about this regression? My PetIGA tests are still
>>>>> failing with petsc/master.
>>>> Yes, I have most of a fix in a branch that I'm working to finish.
