[petsc-dev] error with --download-amgx
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Tue Dec  3 21:13:10 CST 2019
  I have added the comment below as you requested to the forked branch. I also updated the forked branch based on the latest commits in the last few days to the AMRX repository/
> On Dec 3, 2019, at 8:34 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Barry,
> First, there is a fix that we need in the AMGx repo (appended).
> I've never had problems like this not being able to build. I will try to build my AMGx manually to check.
> 21:31 master *= ~/AMGX$ git diff
> diff --git a/base/include/amgx_c_wrappers.inl b/base/include/amgx_c_wrappers.inl
> index 42496f0..ed9f0e1 100644
> --- a/base/include/amgx_c_wrappers.inl
> +++ b/base/include/amgx_c_wrappers.inl
> @@ -643,7 +643,7 @@ inline AMGX_Mode get_mode_from(const Envelope &envl)
>          //throws...
> -        FatalError("Mode not found.\n", AMGX_ERR_BAD_MODE);
> +        // FatalError("Mode not found.\n", AMGX_ERR_BAD_MODE);
>      AMGX_Mode mode = static_cast<AMGX_Mode>(itFound->second);
> @@ -1125,4 +1125,4 @@ inline bool remove_managed_matrix(AMGX_matrix_handle envl)
>  } //namespace unnamed
> On Tue, Dec 3, 2019 at 8:50 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   The first error is
> nvcc error   : 'cicc' died due to signal 9 (Kill signal)
> later
> /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/base/src/amgx_c_common.cu(77): catastrophic error: error while writing generated C++ file: Cannot allocate memory
> 1 catastrophic error detected in the compilation of "/tmp/tmpxft_000038d3_00000000-4_amgx_c_common.cpp4.ii".
>   Whatever machine you are compiling on seems to be overloaded. What does top show? Can you log into "different" compiler servers on Summit?
>   I run the install on the utk system with no problems like this.
> PETSc configure is deciding
> TEST configureMakeNP from config.packages.make(/autofs/nccs-svm1_home1/adams/petsc/config/BuildSystem/config/packages/make.py:168)
> TESTING: configureMakeNP from config.packages.make(config/BuildSystem/config/packages/make.py:168)
>   check no of cores on the build machine [perhaps to do make '-j ncores']
>           module multiprocessing found 128 cores: using make_np = 59
>             Defined make macro "MAKE_NP" to "59"
>             Defined make macro "MAKE_TEST_NP" to "49"
>             Defined make macro "MAKE_LOAD" to "166.4"
>             Defined make macro "NPMAX" to "128"
> then somehow this gets passed down to the AMGX cmake. Perhaps you could try less greedy numbers.
> Executing: /usr/bin/gmake -j59 -l166.4
> Perhaps try
> --with-make-np=20
> --with-make-load=20
> Barry
> > On Dec 3, 2019, at 4:17 PM, Mark Adams <mfadams at lbl.gov> wrote:
> >  That might have been from an old .nsf file. Here is a new one. I'm sure I have the disk space.
> > On Tue, Dec 3, 2019 at 4:51 PM Mark Adams <mfadams at lbl.gov> wrote:
> > Humm, clean up and seem to have different error:
> > On Tue, Dec 3, 2019 at 3:45 PM Matthew Knepley <knepley at gmail.com> wrote:
> > Could you have run out of disk space?
> > /usr/bin/ranlib: libamgx_base.a: Input/output error
> > gmake[2]: *** [base/libamgx_base.a] Error 1
> > gmake[2]: *** Deleting file `base/libamgx_base.a'
> > gmake[1]: *** [base/CMakeFiles/amgx_base.dir/all] Error 2
> > gmake: *** [all] Error 2
> >    Matt
> > On Tue, Dec 3, 2019 at 1:44 PM Mark Adams <mfadams at lbl.gov> wrote:
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
> > <configure.log>
