[petsc-dev] error with --download-amgx
    Balay, Satish
    balay at mcs.anl.gov
    Tue Dec  3 21:29:36 CST 2019
autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/cmake-3.15.2-xit2o3iepxvqbyku77lwcugufilztu7t/bin/cmake -E remove /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/petsc-build/core/CMakeFiles/amgx_core.dir/src/classical/interpolators/./amgx_core_generated_common.cu.o
/sw/summit/cuda/10.1.168/bin/nvcc -M -D__CUDACC__ /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/plugin_config.cu -o /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/petsc-build/base/CMakeFiles/amgx_base.dir/__/amgx_base_generated_plugin_config.cu.o.NVCC-depend -m64 -Xcompiler ,\"-fstack-protector\",\"-g\",\"-O2\",\"-fPIC\",\"-Wno-terminate\",\"-static-libgcc\",\"-fopenmp\",\"-DRAPIDJSON_DEFINED\",\"-DAMGX_WITH_MPI\",\"-fstack-protector\",\"-g\",\"-O2\",\"-fPIC\" -ccbin mpicxx -gencode=arch=compute_35,code=\"sm_35,compute_35\" -gencode=arch=compute_52,code=\"sm_52,compute_52\" -gencode=arch=compute_60,code=\"sm_60,compute_60\" -gencode=arch=compute_70,code=\"sm_70,compute_70\" -O3 -DNDEBUG -std=c++11 --Werror cross-execution-space-call -DNVCC -I/autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/../../thrust -I/autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git..amgx/base/include -I/sw/summit/cuda/10.1.168/include -I/autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/external/rapidjson/include
-- Removing /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/petsc-build/base/CMakeFiles/amgx_base.dir/src/./amgx_base_generated_device_properties.cu.o
Also - its best to avoid -Werror in externalpackage builds..
Satish
On Tue, 3 Dec 2019, Mark Adams wrote:
> Barry,
> First, there is a fix that we need in the AMGx repo (appended).
> I've never had problems like this not being able to build. I will try to
> build my AMGx manually to check.
> 21:31 master *= ~/AMGX$ git diff
> diff --git a/base/include/amgx_c_wrappers.inl
> b/base/include/amgx_c_wrappers.inl
> index 42496f0..ed9f0e1 100644
> --- a/base/include/amgx_c_wrappers.inl
> +++ b/base/include/amgx_c_wrappers.inl
> @@ -643,7 +643,7 @@ inline AMGX_Mode get_mode_from(const Envelope &envl)
>          //throws...
> -        FatalError("Mode not found.\n", AMGX_ERR_BAD_MODE);
> +        // FatalError("Mode not found.\n", AMGX_ERR_BAD_MODE);
>      AMGX_Mode mode = static_cast<AMGX_Mode>(itFound->second);
> @@ -1125,4 +1125,4 @@ inline bool remove_managed_matrix(AMGX_matrix_handle
> envl)
>  } //namespace unnamed
> On Tue, Dec 3, 2019 at 8:50 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> >   The first error is
> > nvcc error   : 'cicc' died due to signal 9 (Kill signal)
> > later
> > /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/base/src/
> > amgx_c_common.cu(77): catastrophic error: error while writing generated
> > C++ file: Cannot allocate memory
> > 1 catastrophic error detected in the compilation of
> > "/tmp/tmpxft_000038d3_00000000-4_amgx_c_common.cpp4.ii".
> >   Whatever machine you are compiling on seems to be overloaded. What does
> > top show? Can you log into "different" compiler servers on Summit?
> >   I run the install on the utk system with no problems like this.
> > PETSc configure is deciding
> > TEST configureMakeNP from
> > config.packages.make(/autofs/nccs-svm1_home1/adams/petsc/config/BuildSystem/config/packages/make.py:168)
> > TESTING: configureMakeNP from
> > config.packages.make(config/BuildSystem/config/packages/make.py:168)
> >   check no of cores on the build machine [perhaps to do make '-j ncores']
> >           module multiprocessing found 128 cores: using make_np = 59
> >             Defined make macro "MAKE_NP" to "59"
> >             Defined make macro "MAKE_TEST_NP" to "49"
> >             Defined make macro "MAKE_LOAD" to "166.4"
> >             Defined make macro "NPMAX" to "128"
> > then somehow this gets passed down to the AMGX cmake. Perhaps you could
> > try less greedy numbers.
> > Executing: /usr/bin/gmake -j59 -l166.4
> > Perhaps try
> > --with-make-np=20
> > --with-make-load=20
> > Barry
> > > On Dec 3, 2019, at 4:17 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > >  That might have been from an old .nsf file. Here is a new one. I'm sure
> > I have the disk space.
> > > On Tue, Dec 3, 2019 at 4:51 PM Mark Adams <mfadams at lbl.gov> wrote:
> > > Humm, clean up and seem to have different error:
> > > On Tue, Dec 3, 2019 at 3:45 PM Matthew Knepley <knepley at gmail.com>
> > wrote:
> > > Could you have run out of disk space?
> > > /usr/bin/ranlib: libamgx_base.a: Input/output error
> > > gmake[2]: *** [base/libamgx_base.a] Error 1
> > > gmake[2]: *** Deleting file `base/libamgx_base.a'
> > > gmake[1]: *** [base/CMakeFiles/amgx_base.dir/all] Error 2
> > > gmake: *** [all] Error 2
> > >    Matt
> > > On Tue, Dec 3, 2019 at 1:44 PM Mark Adams <mfadams at lbl.gov> wrote:
> > > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which their
> > experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> > > <configure.log>
