[petsc-dev] error with --download-amgx
    Mark Adams
    mfadams at lbl.gov
    Tue Dec  3 20:34:48 CST 2019
Barry,
First, there is a fix that we need in the AMGx repo (appended).
I've never had problems like this not being able to build. I will try to
build my AMGx manually to check.
21:31 master *= ~/AMGX$ git diff
diff --git a/base/include/amgx_c_wrappers.inl
b/base/include/amgx_c_wrappers.inl
index 42496f0..ed9f0e1 100644
--- a/base/include/amgx_c_wrappers.inl
+++ b/base/include/amgx_c_wrappers.inl
@@ -643,7 +643,7 @@ inline AMGX_Mode get_mode_from(const Envelope &envl)
         //throws...
-        FatalError("Mode not found.\n", AMGX_ERR_BAD_MODE);
+        // FatalError("Mode not found.\n", AMGX_ERR_BAD_MODE);
     AMGX_Mode mode = static_cast<AMGX_Mode>(itFound->second);
@@ -1125,4 +1125,4 @@ inline bool remove_managed_matrix(AMGX_matrix_handle
envl)
 } //namespace unnamed
On Tue, Dec 3, 2019 at 8:50 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   The first error is
> nvcc error   : 'cicc' died due to signal 9 (Kill signal)
> later
> /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/base/src/
> amgx_c_common.cu(77): catastrophic error: error while writing generated
> C++ file: Cannot allocate memory
> 1 catastrophic error detected in the compilation of
> "/tmp/tmpxft_000038d3_00000000-4_amgx_c_common.cpp4.ii".
>   Whatever machine you are compiling on seems to be overloaded. What does
> top show? Can you log into "different" compiler servers on Summit?
>   I run the install on the utk system with no problems like this.
> PETSc configure is deciding
> TEST configureMakeNP from
> config.packages.make(/autofs/nccs-svm1_home1/adams/petsc/config/BuildSystem/config/packages/make.py:168)
> TESTING: configureMakeNP from
> config.packages.make(config/BuildSystem/config/packages/make.py:168)
>   check no of cores on the build machine [perhaps to do make '-j ncores']
>           module multiprocessing found 128 cores: using make_np = 59
>             Defined make macro "MAKE_NP" to "59"
>             Defined make macro "MAKE_TEST_NP" to "49"
>             Defined make macro "MAKE_LOAD" to "166.4"
>             Defined make macro "NPMAX" to "128"
> then somehow this gets passed down to the AMGX cmake. Perhaps you could
> try less greedy numbers.
> Executing: /usr/bin/gmake -j59 -l166.4
> Perhaps try
> --with-make-np=20
> --with-make-load=20
> Barry
> > On Dec 3, 2019, at 4:17 PM, Mark Adams <mfadams at lbl.gov> wrote:
> >  That might have been from an old .nsf file. Here is a new one. I'm sure
> I have the disk space.
> > On Tue, Dec 3, 2019 at 4:51 PM Mark Adams <mfadams at lbl.gov> wrote:
> > Humm, clean up and seem to have different error:
> > On Tue, Dec 3, 2019 at 3:45 PM Matthew Knepley <knepley at gmail.com>
> wrote:
> > Could you have run out of disk space?
> > /usr/bin/ranlib: libamgx_base.a: Input/output error
> > gmake[2]: *** [base/libamgx_base.a] Error 1
> > gmake[2]: *** Deleting file `base/libamgx_base.a'
> > gmake[1]: *** [base/CMakeFiles/amgx_base.dir/all] Error 2
> > gmake: *** [all] Error 2
> >    Matt
> > On Tue, Dec 3, 2019 at 1:44 PM Mark Adams <mfadams at lbl.gov> wrote:
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191203/4e132e58/attachment.html>
