[petsc-dev] Is master broken?
    Mark Adams
    mfadams at lbl.gov
    Thu Aug  1 05:23:58 CDT 2019
I get the same error with a fresh clone of master.
On Thu, Aug 1, 2019 at 6:03 AM Mark Adams <mfadams at lbl.gov> wrote:
> Tried again after deleting the arch dirs and still have it.
> This is my branch that just merged master. I will try with just master.
> Thanks,
> On Thu, Aug 1, 2019 at 1:36 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>   It is generated automatically and put in
>> arch-linux2-c-debug/include/petscpkg_version.h  this include file is
>> included at top of the "bad" source  file crashes so in theory everything
>> is in order check that arch-linux2-c-debug/include/petscpkg_version.h
>> contains PETSC_PKG_CUDA_VERSION_GE and similar macros. If not send
>> configure.lo
>> check what is in arch-linux2-c-debug/include/petscpkg_version.h it
>> nothing or broken send configure.lo
>>   Barry
>> > On Jul 31, 2019, at 9:28 PM, Mark Adams via petsc-dev <
>> petsc-dev at mcs.anl.gov> wrote:
>> > I am seeing this when I pull master into my branch:
>> > "/autofs/nccs-svm1_home1/adams/petsc/src/mat/impls/dense/seq/cuda/
>> densecuda.cu"
>> >           , line 243: error: function call is not allowed in a constant
>> >           expression
>> >   #if PETSC_PKG_CUDA_VERSION_GE(10,1,0)
>> > and I see that this macro does not seem to be defined:
>> > 22:24 master= ~/Codes/petsc$ git grep PETSC_PKG_CUDA_VERSION_GE
>> > src/mat/impls/dense/seq/cuda/densecuda.cu:#if
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190801/a930a8ee/attachment.html>
