[petsc-dev] Is master broken?
    Mark Adams
    mfadams at lbl.gov
    Thu Aug  1 05:03:39 CDT 2019
Tried again after deleting the arch dirs and still have it.
This is my branch that just merged master. I will try with just master.
On Thu, Aug 1, 2019 at 1:36 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   It is generated automatically and put in
> arch-linux2-c-debug/include/petscpkg_version.h  this include file is
> included at top of the "bad" source  file crashes so in theory everything
> is in order check that arch-linux2-c-debug/include/petscpkg_version.h
> contains PETSC_PKG_CUDA_VERSION_GE and similar macros. If not send
> configure.lo
> check what is in arch-linux2-c-debug/include/petscpkg_version.h it nothing
> or broken send configure.lo
>   Barry
> > On Jul 31, 2019, at 9:28 PM, Mark Adams via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
> > I am seeing this when I pull master into my branch:
> > "/autofs/nccs-svm1_home1/adams/petsc/src/mat/impls/dense/seq/cuda/
> densecuda.cu"
> >           , line 243: error: function call is not allowed in a constant
> >           expression
> >   #if PETSC_PKG_CUDA_VERSION_GE(10,1,0)
> > and I see that this macro does not seem to be defined:
> > 22:24 master= ~/Codes/petsc$ git grep PETSC_PKG_CUDA_VERSION_GE
> > src/mat/impls/dense/seq/cuda/densecuda.cu:#if
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190801/8bd2a7ef/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190801/8bd2a7ef/attachment-0001.obj>
