[petsc-dev] Is master broken?
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Thu Aug  1 09:29:57 CDT 2019
  Send
ls arch-linux2-c-debug/include/
 arch-linux2-c-debug/include/petscpkg_version.h
and configure.log
> On Aug 1, 2019, at 5:23 AM, Mark Adams <mfadams at lbl.gov> wrote:
> I get the same error with a fresh clone of master.
> On Thu, Aug 1, 2019 at 6:03 AM Mark Adams <mfadams at lbl.gov> wrote:
> Tried again after deleting the arch dirs and still have it.
> This is my branch that just merged master. I will try with just master.
> Thanks,
> On Thu, Aug 1, 2019 at 1:36 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   It is generated automatically and put in arch-linux2-c-debug/include/petscpkg_version.h  this include file is included at top of the "bad" source  file crashes so in theory everything is in order check that arch-linux2-c-debug/include/petscpkg_version.h contains PETSC_PKG_CUDA_VERSION_GE and similar macros. If not send configure.lo
> check what is in arch-linux2-c-debug/include/petscpkg_version.h it nothing or broken send configure.lo
>   Barry
> > On Jul 31, 2019, at 9:28 PM, Mark Adams via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> > I am seeing this when I pull master into my branch:
> > "/autofs/nccs-svm1_home1/adams/petsc/src/mat/impls/dense/seq/cuda/densecuda.cu"
> >           , line 243: error: function call is not allowed in a constant
> >           expression
> >   #if PETSC_PKG_CUDA_VERSION_GE(10,1,0)
> > and I see that this macro does not seem to be defined:
> > 22:24 master= ~/Codes/petsc$ git grep PETSC_PKG_CUDA_VERSION_GE
> > src/mat/impls/dense/seq/cuda/densecuda.cu:#if PETSC_PKG_CUDA_VERSION_GE(10,1,0)
