[petsc-dev] Something changed with SBAIJ on april 17?
    Éric Chamberland
    Eric.Chamberland at giref.ulaval.ca
    Sun Apr 21 15:52:13 CDT 2019
Hi Stefano,
sure!
configuration is running with your branch and tests will begin later.  I
will see and share the results tomorrow.
thanks! :)
Eric
Le 19-04-21 à 17:21, Stefano Zampini a écrit :
> Eric
> I have opened a PRmay fix the issues you reported
> https://bitbucket.org/petsc/petsc/pull-requests/1571/fix-sbaij/diff
> Could you please try
> https://bitbucket.org/petsc/petsc/branch/stefano_zampini/fix-matcopy-sbaij?
> (off maint)
> Thanks
> Il giorno ven 19 apr 2019 alle ore 23:26 Éric Chamberland via
> petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> ha
> scritto:
>     Hi,
>     ok, I will try do to one, but since I am on vacation right now, I
>     will try to do it at my return in a week.
>     I wanted to report the bug asap, so you may figure out the problem
>     quickly.
>     Thanks,
>     Eric
>     Le 19-04-19 à 19:10, Stefano Zampini via petsc-dev a écrit :
>>     Can you please send a MWE to reproduce the errors so that I can
>>     provide a fix?
>>     Il Ven 19 Apr 2019, 17:00 Matthew Knepley via petsc-dev
>>     <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> ha scritto:
>>         On Fri, Apr 19, 2019 at 9:40 AM Balay, Satish via petsc-dev
>>         <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
>>             There were a few merges in the the past few days.
>>             For ex:
>>             https://bitbucket.org/petsc/petsc/pull-requests/1547/add-support-for-zeroing-rows-and-columns/diff
>>             Perhaps you can narrow down to the commit that triggered
>>             this change with git bisect.
>>         I think its this commit:
>>         https://bitbucket.org/petsc/petsc/commits/2b4bbc58b197e97e85869bd03594884bbca73c67
>>             Matt
>>             cc: Stefano
>>             Satish
>>             On Fri, 19 Apr 2019, Éric Chamberland via petsc-dev wrote:
>>             > Hi,
>>             > Looks like something pushed on master change or broke
>>             some sbaij usages.  I
>>             > have two kind off errors with MatCopy:
>>             > 1) MatCopy error saying: No support for this operation
>>             for this object type
>>             > [0]PETSC ERROR: --------------------- Error Message
>>             > [0]PETSC ERROR: No support for this operation for this
>>             object type
>>             > [0]PETSC ERROR: MatGetRow is not supported for SBAIJ
>>             matrix format. Getting
>>             > the upper triangular part of row, run with
>>             -mat_getrow_uppertriangular, call
>>             > MatSetOption(mat,MAT_GETROW_UPPERTRIANGULAR,PETSC_TRUE) or
>>             > MatGetRowUpperTriangular()
>>             > [0]PETSC ERROR: See
>>             http://www.mcs.anl.gov/petsc/documentation/faq.html for
>>             > trouble shooting.
>>             > [0]PETSC ERROR: Petsc Development GIT revision:
>>             v3.11.1-277-g63b3610  GIT
>>             > Date: 2019-04-18 08:33:56 -0500
>>             > [0]PETSC ERROR:
>>             /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/BIB/bin/Test.deliMEFPP.dev
>>             <http://Test.deliMEFPP.dev>
>>             > on a  named compile by Unknown Fri Apr 19 03:19:09 2019
>>             > [0]PETSC ERROR: Configure options
>>             --prefix=/opt/petsc-master_debug
>>             > --with-mpi-compilers=1 --with-mpi-dir=/opt/openmpi-1.10.2
>>             > --with-cxx-dialect=C++11 --with-make-np=12
>>             --with-shared-libraries=1
>>             > --with-debugging=yes --with-memalign=64 --with-visibility=0
>>             > --with-64-bit-indices=0 --download-ml=yes
>>             --download-mumps=yes
>>             > --download-superlu=yes --download-superlu_dist=yes
>>             --download-parmetis=yes
>>             > --download-ptscotch=yes --download-metis=yes
>>             --download-suitesparse=yes
>>             > --download-hypre=yes
>>             --with-blaslapack-dir=/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64
>>             --with-mkl_pardiso-dir=/opt/intel/composer_xe_2015.2.164/mkl
>>             --with-mkl_cpardiso-dir=/opt/intel/composer_xe_2015.2.164/mkl
>>             > --with-scalapack=1
>>             --with-scalapack-include=/opt/intel/composer_xe_2015.2.164/mkl/include
>>             --with-scalapack-lib="-L/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64
>>             > -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
>>             > [0]PETSC ERROR: #1 MatGetRow_SeqSBAIJ() line 281 in
>>             /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/sbaij/seq/sbaij.c
>>             > [0]PETSC ERROR: #2 MatGetRow() line 574 in
>>             /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
>>             > [0]PETSC ERROR: #3 MatAXPY_Basic_Preallocate() line 138 in
>>             /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/utils/axpy.c
>>             > [0]PETSC ERROR: #4 MatAXPY() line 95 in
>>             > [0]PETSC ERROR: #5 MatAYPX() line 384 in
>>             > [0]PETSC ERROR: #6 MatCopy_Basic() line 4056 in
>>             > [0]PETSC ERROR: #7 MatCopy_SeqAIJ() line 2844 in
>>             /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/aij/seq/aij.c
>>             > [0]PETSC ERROR: #8 MatCopy() line 4110 in
>>             > 2) MatCopy error saying:
>>             > Argument out of range: New nonzero at (6,7) caused a malloc
>>             > [0]PETSC ERROR: Argument out of range
>>             > [0]PETSC ERROR: New nonzero at (6,7) caused a malloc
>>             > Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR,
>>             PETSC_FALSE) to turn off
>>             > this check
>>             > [0]PETSC ERROR: See
>>             > trouble shooting.
>>             > [0]PETSC ERROR:
>>             /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/BIB/bin/Test.BIBProblemeGD.dev
>>             <http://Test.BIBProblemeGD.dev>
>>             > on a  named compile by Unknown Fri Apr 19 03:22:25 2019
>>             > --with-scalapack=1
>>             > [0]PETSC ERROR: #1 MatSetValues_SeqSBAIJ() line 990 in
>>             > [0]PETSC ERROR: #2 MatSetValues() line 1404 in
>>             > [0]PETSC ERROR: #3 MatAXPY_BasicWithPreallocation()
>>             line 209 in
>>             > [0]PETSC ERROR: #4 MatAXPY() line 96 in
>>             > Here are my installation logs as of april 18, at 02h00:
>>             http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_configure.log
>>             http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_make.log
>>             http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_default.log
>>             http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_RDict.log
>>             http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_CMakeLists.txt
>>             http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_make_test.log
>>             http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_make_streams.log
>>             > Thanks,
>>             > Eric
>>         What most experimenters take for granted before they begin
>>         their experiments is infinitely more interesting than any
>>         results to which their experiments lead.
>>         -- Norbert Wiener
>>         https://www.cse.buffalo.edu/~knepley/
>>         <http://www.cse.buffalo.edu/~knepley/>
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190421/359403b0/attachment-0001.html>
