[petsc-dev] Something changed with SBAIJ on april 17?
Stefano Zampini stefano.zampini at gmail.com
Sun Apr 21 10:21:47 CDT 2019
Eric
I have opened a PRmay fix the issues you reported
https://bitbucket.org/petsc/petsc/pull-requests/1571/fix-sbaij/diff
Could you please try
https://bitbucket.org/petsc/petsc/branch/stefano_zampini/fix-matcopy-sbaij?
(off maint)
Thanks
Il giorno ven 19 apr 2019 alle ore 23:26 Éric Chamberland via petsc-dev <
petsc-dev at mcs.anl.gov> ha scritto:
> Hi,
> ok, I will try do to one, but since I am on vacation right now, I will try
> to do it at my return in a week.
> I wanted to report the bug asap, so you may figure out the problem quickly.
> Thanks,
> Eric
> Le 19-04-19 à 19:10, Stefano Zampini via petsc-dev a écrit :
> Can you please send a MWE to reproduce the errors so that I can provide a
> fix?
> Il Ven 19 Apr 2019, 17:00 Matthew Knepley via petsc-dev <
>> On Fri, Apr 19, 2019 at 9:40 AM Balay, Satish via petsc-dev <
>> petsc-dev at mcs.anl.gov> wrote:
>>> There were a few merges in the the past few days.
>>> For ex:
>>> https://bitbucket.org/petsc/petsc/pull-requests/1547/add-support-for-zeroing-rows-and-columns/diff
>>> Perhaps you can narrow down to the commit that triggered this change
>>> with git bisect.
>> I think its this commit:
>> https://bitbucket.org/petsc/petsc/commits/2b4bbc58b197e97e85869bd03594884bbca73c67
>>     Matt
>>> cc: Stefano
>>> Satish
>>> On Fri, 19 Apr 2019, Éric Chamberland via petsc-dev wrote:
>>> > Hi,
>>> > Looks like something pushed on master change or broke some sbaij
>>> usages.  I
>>> > have two kind off errors with MatCopy:
>>> > 1) MatCopy error saying: No support for this operation for this object
>>> type
>>> > [0]PETSC ERROR: --------------------- Error Message
>>> > [0]PETSC ERROR: No support for this operation for this object type
>>> > [0]PETSC ERROR: MatGetRow is not supported for SBAIJ matrix format.
>>> Getting
>>> > the upper triangular part of row, run with
>>> -mat_getrow_uppertriangular, call
>>> > MatSetOption(mat,MAT_GETROW_UPPERTRIANGULAR,PETSC_TRUE) or
>>> > MatGetRowUpperTriangular()
>>> > [0]PETSC ERROR: See
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for
>>> > trouble shooting.
>>> > [0]PETSC ERROR: Petsc Development GIT revision: v3.11.1-277-g63b3610
>>> GIT
>>> > Date: 2019-04-18 08:33:56 -0500
>>> > [0]PETSC ERROR:
>>> /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/BIB/bin/
>>> Test.deliMEFPP.dev
>>> > on a  named compile by Unknown Fri Apr 19 03:19:09 2019
>>> > [0]PETSC ERROR: Configure options --prefix=/opt/petsc-master_debug
>>> > --with-mpi-compilers=1 --with-mpi-dir=/opt/openmpi-1.10.2
>>> > --with-cxx-dialect=C++11 --with-make-np=12 --with-shared-libraries=1
>>> > --with-debugging=yes --with-memalign=64 --with-visibility=0
>>> > --with-64-bit-indices=0 --download-ml=yes --download-mumps=yes
>>> > --download-superlu=yes --download-superlu_dist=yes
>>> --download-parmetis=yes
>>> > --download-ptscotch=yes --download-metis=yes --download-suitesparse=yes
>>> > --download-hypre=yes
>>> > --with-blaslapack-dir=/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64
>>> > --with-mkl_pardiso-dir=/opt/intel/composer_xe_2015.2.164/mkl
>>> > --with-mkl_cpardiso-dir=/opt/intel/composer_xe_2015.2.164/mkl
>>> > --with-scalapack=1
>>> > --with-scalapack-include=/opt/intel/composer_xe_2015.2.164/mkl/include
>>> --with-scalapack-lib="-L/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64
>>> > -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
>>> > [0]PETSC ERROR: #1 MatGetRow_SeqSBAIJ() line 281 in
>>> /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/sbaij/seq/sbaij.c
>>> > [0]PETSC ERROR: #2 MatGetRow() line 574 in
>>> /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
>>> > [0]PETSC ERROR: #3 MatAXPY_Basic_Preallocate() line 138 in
>>> /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/utils/axpy.c
>>> > [0]PETSC ERROR: #4 MatAXPY() line 95 in
>>> > [0]PETSC ERROR: #5 MatAYPX() line 384 in
>>> > [0]PETSC ERROR: #6 MatCopy_Basic() line 4056 in
>>> > [0]PETSC ERROR: #7 MatCopy_SeqAIJ() line 2844 in
>>> /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/aij/seq/aij.c
>>> > [0]PETSC ERROR: #8 MatCopy() line 4110 in
>>> > 2) MatCopy error saying:
>>> > Argument out of range: New nonzero at (6,7) caused a malloc
>>> > [0]PETSC ERROR: Argument out of range
>>> > [0]PETSC ERROR: New nonzero at (6,7) caused a malloc
>>> > Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to
>>> turn off
>>> > this check
>>> > [0]PETSC ERROR: See
>>> > trouble shooting.
>>> GIT
>>> > [0]PETSC ERROR:
>>> Test.BIBProblemeGD.dev
>>> > on a  named compile by Unknown Fri Apr 19 03:22:25 2019
>>> > --with-scalapack=1
>>> > [0]PETSC ERROR: #1 MatSetValues_SeqSBAIJ() line 990 in
>>> > [0]PETSC ERROR: #2 MatSetValues() line 1404 in
>>> > [0]PETSC ERROR: #3 MatAXPY_BasicWithPreallocation() line 209 in
>>> > [0]PETSC ERROR: #4 MatAXPY() line 96 in
>>> > Here are my installation logs as of april 18, at 02h00:
>>> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_configure.log
>>> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_make.log
>>> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_default.log
>>> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_RDict.log
>>> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_CMakeLists.txt
>>> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_make_test.log
>>> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_make_streams.log
>>> > Thanks,
>>> > Eric
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190421/e0f71b17/attachment.html>
