[petsc-dev] Checking for valid C linker flags with Intel 19 on Cygwin
Tim Steinhoff
kandanovian at gmail.com
Mon Apr 1 09:53:13 CDT 2019
Satish, that should be exactly it. Thanks!
Am Mo., 1. Apr. 2019 um 16:04 Uhr schrieb Balay, Satish <balay at mcs.anl.gov>:
> I guess the following change will work with this compiler?
> diff --git a/config/BuildSystem/config/setCompilers.py b/config/BuildSystem/config/setCompilers.py
> index 3a616f0318..edd11894d7 100644
> --- a/config/BuildSystem/config/setCompilers.py
> +++ b/config/BuildSystem/config/setCompilers.py
> @@ -1004,7 +1004,7 @@ class Configure(config.base.Configure):
> output.find('not recognized') >= 0 or output.find('not recognised') >= 0 or
> output.find('unknown option') >= 0 or output.find('unknown flag') >= 0 or output.find('Unknown switch') >= 0 or
> output.find('ignoring option') >= 0 or output.find('ignored') >= 0 or
> - output.find('argument unused') >= 0 or
> + output.find('argument unused') >= 0 or output.find('not supported') >= 0 or
> # When checking for the existence of 'attribute'
> output.find('is unsupported and will be skipped') >= 0 or
> output.find('illegal option') >= 0 or output.find('Invalid option') >= 0 or
> Satish
> On Mon, 1 Apr 2019, Tim Steinhoff via petsc-dev wrote:
> > Hi,
> > we moved from Intel 16 to Intel 19 compiler on Cygwin and it seems
> > that Intel has changed their error message, when PETSc is testing for
> > rpath flag.
> > Intel 16 - PETSc rejects the flag correctly:
> > stdout: icl: command line warning #10157: ignoring option '/W';
> > argument is of wrong type
> > Rejecting C linker flag -Wl,-rpath,/reps/petsc.git due to
> > Now with Intel 19, PETSc thinks it is valid despite the warning message:
> > stdout: icl: command line warning #10148: option
> > '/Wl,-rpath,/home/jac/reps/petsc/petsc.git' not supported
> > Valid C linker flag -Wl,-rpath,/home/jac/reps/petsc/petsc.git
> > This leads to PETSc not recognizing that rpath is actually not
> > supported which will lead to problems later.
> > Could you please add the new message to the check in
> > containsInvalidFlag (setCompilers.py) or should I create a PR?
> > Thanks and kind regards,
> > Volker
