[petsc-dev] Checking for valid C linker flags with Intel 19 on Cygwin
Balay, Satish balay at mcs.anl.gov
Mon Apr 1 09:04:49 CDT 2019
I guess the following change will work with this compiler?
diff --git a/config/BuildSystem/config/setCompilers.py b/config/BuildSystem/config/setCompilers.py
index 3a616f0318..edd11894d7 100644
--- a/config/BuildSystem/config/setCompilers.py
+++ b/config/BuildSystem/config/setCompilers.py
@@ -1004,7 +1004,7 @@ class Configure(config.base.Configure):
         output.find('not recognized') >= 0 or output.find('not recognised') >= 0 or
         output.find('unknown option') >= 0 or output.find('unknown flag') >= 0 or output.find('Unknown switch') >= 0 or
         output.find('ignoring option') >= 0 or output.find('ignored') >= 0 or
-        output.find('argument unused') >= 0 or
+        output.find('argument unused') >= 0 or output.find('not supported') >= 0 or
         # When checking for the existence of 'attribute'
         output.find('is unsupported and will be skipped') >= 0 or
         output.find('illegal option') >= 0 or output.find('Invalid option') >= 0 or
Satish
On Mon, 1 Apr 2019, Tim Steinhoff via petsc-dev wrote:
> Hi,
> we moved from Intel 16 to Intel 19 compiler on Cygwin and it seems
> that Intel has changed their error message, when PETSc is testing for
> rpath flag.
> Intel 16 - PETSc rejects the flag correctly:
> stdout: icl: command line warning #10157: ignoring option '/W';
> argument is of wrong type
>             Rejecting C linker flag -Wl,-rpath,/reps/petsc.git due to
> Now with Intel 19, PETSc thinks it is valid despite the warning message:
> stdout: icl: command line warning #10148: option
> '/Wl,-rpath,/home/jac/reps/petsc/petsc.git' not supported
>             Valid C linker flag -Wl,-rpath,/home/jac/reps/petsc/petsc.git
> This leads to PETSc not recognizing that rpath is actually not
> supported which will lead to problems later.
> Could you please add the new message to the check in
> containsInvalidFlag (setCompilers.py) or should I create a PR?
> Thanks and kind regards,
> Volker
