[petsc-dev] Checking for valid C linker flags with Intel 19 on Cygwin
Balay, Satish
balay at mcs.anl.gov
Mon Apr 1 10:02:19 CDT 2019
Thanks for the confirmation. Here is the PR for this change.
https://bitbucket.org/petsc/petsc/pull-requests/1484/win-update-containsinvalidflag-with-icc-19/diff
Satish
On Mon, 1 Apr 2019, Tim Steinhoff via petsc-dev wrote:
> Satish, that should be exactly it. Thanks!
> Am Mo., 1. Apr. 2019 um 16:04 Uhr schrieb Balay, Satish <balay at mcs.anl.gov>:
> > I guess the following change will work with this compiler?
> > diff --git a/config/BuildSystem/config/setCompilers.py b/config/BuildSystem/config/setCompilers.py
> > index 3a616f0318..edd11894d7 100644
> > --- a/config/BuildSystem/config/setCompilers.py
> > +++ b/config/BuildSystem/config/setCompilers.py
> > @@ -1004,7 +1004,7 @@ class Configure(config.base.Configure):
> > output.find('not recognized') >= 0 or output.find('not recognised') >= 0 or
> > output.find('unknown option') >= 0 or output.find('unknown flag') >= 0 or output.find('Unknown switch') >= 0 or
> > output.find('ignoring option') >= 0 or output.find('ignored') >= 0 or
> > - output.find('argument unused') >= 0 or
> > + output.find('argument unused') >= 0 or output.find('not supported') >= 0 or
> > # When checking for the existence of 'attribute'
> > output.find('is unsupported and will be skipped') >= 0 or
> > output.find('illegal option') >= 0 or output.find('Invalid option') >= 0 or
> > Satish
> > > Hi,
> > > we moved from Intel 16 to Intel 19 compiler on Cygwin and it seems
> > > that Intel has changed their error message, when PETSc is testing for
> > > rpath flag.
> > > Intel 16 - PETSc rejects the flag correctly:
> > > stdout: icl: command line warning #10157: ignoring option '/W';
> > > argument is of wrong type
> > > Rejecting C linker flag -Wl,-rpath,/reps/petsc.git due to
> > > Now with Intel 19, PETSc thinks it is valid despite the warning message:
> > > stdout: icl: command line warning #10148: option
> > > '/Wl,-rpath,/home/jac/reps/petsc/petsc.git' not supported
> > > Valid C linker flag -Wl,-rpath,/home/jac/reps/petsc/petsc.git
> > > This leads to PETSc not recognizing that rpath is actually not
> > > supported which will lead to problems later.
> > > Could you please add the new message to the check in
> > > containsInvalidFlag (setCompilers.py) or should I create a PR?
> > > Thanks and kind regards,
> > > Volker
