[petsc-dev] PETSc 3.10: September 4, 2018, is the cutoff-date for new features
Hapla Vaclav
vaclav.hapla at erdw.ethz.ch
Wed Sep 12 10:43:07 CDT 2018
I have also noticed that the headline TAO is 2 times in 310.html - should I fix it in maint?
Vaclav
> 12. 9. 2018 v 17:36, Satish Balay <balay at mcs.anl.gov>:
> Thanks! Fixed now.
> Satish
> On Wed, 12 Sep 2018, Hapla Vaclav wrote:
>> Satish, at http://www.mcs.anl.gov/petsc/download/index.html, link "Summary of PETSc-3.10 changes" still points to 39.html
>> Vaclav
>>> 12. 9. 2018 v 17:01, Satish Balay <balay at mcs.anl.gov>:
>>> v3.10 tag is pushed, maint & master branches are updated, and tarballs are now available for download.
>>> Satish
>>> On Wed, 12 Sep 2018, Balay, Satish wrote:
>>>> All release relevant PRs are now merged to master. And I'm ready to tag the release [and spin the tarballs]
>>>> Any potential (code, doc) fixes can be queued for 3.10.1
>>>> Satish
>>>> On Tue, 11 Sep 2018, Satish Balay wrote:
>>>>> Reminder!
>>>>> please check
>>>>> http://www.mcs.anl.gov/petsc/documentation/changes/dev.html and update
>>>>> src/docs/website/documentation/changes/dev.html with relavent changes.
>>>>> Thanks,
>>>>> Satish
>>>>> On Mon, 10 Sep 2018, Satish Balay wrote:
>>>>>> Also - please check and update src/docs/website/documentation/changes/dev.html as needed.
>>>>>> Thanks,
>>>>>> Satish
>>>>>> On Wed, 5 Sep 2018, Karl Rupp wrote:
>>>>>>> Dear PETSc developers,
>>>>>>> please open any outstanding pull requests for the upcoming PETSc 3.10 release
>>>>>>> in the next few hours. After that, please do not merge anything to `next` or
>>>>>>> `master` unless it is integration work for existing open PRs.
>>>>>>> You can open up new pull requests in the next days and weeks as usual. If
>>>>>>> these are documentation enhancements, we will most likely integrate them
>>>>>>> quickly. If these are bugfixes, we may still integrate them for PETSc 3.10,
>>>>>>> decided on a per-case basis. New features, however, will not be integrated
>>>>>>> until PETSc 3.10 is out.
>>>>>>> Thanks and best regards,
>>>>>>> Karli
>>>>>>>> this is a gentle reminder for the cutoff-date on September 4.
>>>>>>>> Best regards,
>>>>>>>> Karli
>>>>>>>>> in order to ensure a PETSc 3.10 release no later than by the end of
>>>>>>>>> September (possibly earlier), we agreed on September 4, 2018, as the
>>>>>>>>> cut-off date for new features. Please make sure that a pull request has
>>>>>>>>> been opened on Bitbucket by this time. This is the preferred model over
>>>>>>>>> merging to next directly, since our Jenkins test infrastructure will test
>>>>>>>>> each PR separately (thus providing faster feedback and thus allow for
>>>>>>>>> faster integration).
>>>>>>>>> And while we are at it: Please keep in mind that new features also require
>>>>>>>>> appropriate documentation. :-)
>>>>>>>>> Karli
