[petsc-dev] PETSc 3.10: September 4, 2018, is the cutoff-date for new features
Wed Sep 12 10:36:05 CDT 2018
Thanks! Fixed now.
Satish
On Wed, 12 Sep 2018, Hapla  Vaclav wrote:
> Satish, at http://www.mcs.anl.gov/petsc/download/index.html, link "Summary of PETSc-3.10 changes" still points to 39.html
> Vaclav
> > 12. 9. 2018 v 17:01, Satish Balay <balay at mcs.anl.gov>:
> > v3.10 tag is pushed, maint & master branches are updated, and tarballs are now available for download.
> > Satish
> > On Wed, 12 Sep 2018, Balay, Satish wrote:
> >> All release relevant PRs are now merged to master. And I'm ready to tag the release [and spin the tarballs]
> >> Any potential (code, doc) fixes can be queued for 3.10.1
> >> Satish
> >> On Tue, 11 Sep 2018, Satish Balay wrote:
> >>> Reminder!
> >>> please check
> >>> http://www.mcs.anl.gov/petsc/documentation/changes/dev.html and update
> >>> src/docs/website/documentation/changes/dev.html with relavent changes.
> >>> Thanks,
> >>> Satish
> >>> On Mon, 10 Sep 2018, Satish Balay wrote:
> >>>> Also - please check and update src/docs/website/documentation/changes/dev.html as needed.
> >>>> Thanks,
> >>>> Satish
> >>>> On Wed, 5 Sep 2018, Karl Rupp wrote:
> >>>>> Dear PETSc developers,
> >>>>> please open any outstanding pull requests for the upcoming PETSc 3.10 release
> >>>>> in the next few hours. After that, please do not merge anything to `next` or
> >>>>> `master` unless it is integration work for existing open PRs.
> >>>>> You can open up new pull requests in the next days and weeks as usual. If
> >>>>> these are documentation enhancements, we will most likely integrate them
> >>>>> quickly. If these are bugfixes, we may still integrate them for PETSc 3.10,
> >>>>> decided on a per-case basis. New features, however, will not be integrated
> >>>>> until PETSc 3.10 is out.
> >>>>> Thanks and best regards,
> >>>>> Karli
> >>>>>> this is a gentle reminder for the cutoff-date on September 4.
> >>>>>> Best regards,
> >>>>>> Karli
> >>>>>>> in order to ensure a PETSc 3.10 release no later than by the end of
> >>>>>>> September (possibly earlier), we agreed on September 4, 2018, as the
> >>>>>>> cut-off date for new features. Please make sure that a pull request has
> >>>>>>> been opened on Bitbucket by this time. This is the preferred model over
> >>>>>>> merging to next directly, since our Jenkins test infrastructure will test
> >>>>>>> each PR separately (thus providing faster feedback and thus allow for
> >>>>>>> faster integration).
> >>>>>>> And while we are at it: Please keep in mind that new features also require
> >>>>>>> appropriate documentation. :-)
> >>>>>>> Karli
