[petsc-dev] PETSc 3.10: September 4, 2018, is the cutoff-date for new features
Wed Sep 12 10:49:14 CDT 2018
yes. such fixes can go into maint.
Thanks!
Satish
On Wed, 12 Sep 2018, Hapla  Vaclav wrote:
> I have also noticed that the headline TAO is 2 times in 310.html - should I fix it in maint?
> Vaclav
> > 12. 9. 2018 v 17:36, Satish Balay <balay at mcs.anl.gov>:
> > Thanks! Fixed now.
> > Satish
> >> Satish, at http://www.mcs.anl.gov/petsc/download/index.html, link "Summary of PETSc-3.10 changes" still points to 39.html
> >> Vaclav
> >>> 12. 9. 2018 v 17:01, Satish Balay <balay at mcs.anl.gov>:
> >>> v3.10 tag is pushed, maint & master branches are updated, and tarballs are now available for download.
> >>> Satish
> >>> On Wed, 12 Sep 2018, Balay, Satish wrote:
> >>>> All release relevant PRs are now merged to master. And I'm ready to tag the release [and spin the tarballs]
> >>>> Any potential (code, doc) fixes can be queued for 3.10.1
> >>>> Satish
> >>>> On Tue, 11 Sep 2018, Satish Balay wrote:
> >>>>> Reminder!
> >>>>> please check
> >>>>> http://www.mcs.anl.gov/petsc/documentation/changes/dev.html and update
> >>>>> src/docs/website/documentation/changes/dev.html with relavent changes.
> >>>>> Thanks,
> >>>>> Satish
> >>>>> On Mon, 10 Sep 2018, Satish Balay wrote:
> >>>>>> Also - please check and update src/docs/website/documentation/changes/dev.html as needed.
> >>>>>> Thanks,
> >>>>>> Satish
> >>>>>> On Wed, 5 Sep 2018, Karl Rupp wrote:
> >>>>>>> Dear PETSc developers,
> >>>>>>> please open any outstanding pull requests for the upcoming PETSc 3.10 release
> >>>>>>> in the next few hours. After that, please do not merge anything to `next` or
> >>>>>>> `master` unless it is integration work for existing open PRs.
> >>>>>>> You can open up new pull requests in the next days and weeks as usual. If
> >>>>>>> these are documentation enhancements, we will most likely integrate them
> >>>>>>> quickly. If these are bugfixes, we may still integrate them for PETSc 3.10,
> >>>>>>> decided on a per-case basis. New features, however, will not be integrated
> >>>>>>> until PETSc 3.10 is out.
> >>>>>>> Thanks and best regards,
> >>>>>>> Karli
> >>>>>>>> this is a gentle reminder for the cutoff-date on September 4.
> >>>>>>>> Best regards,
> >>>>>>>> Karli
> >>>>>>>>> in order to ensure a PETSc 3.10 release no later than by the end of
> >>>>>>>>> September (possibly earlier), we agreed on September 4, 2018, as the
> >>>>>>>>> cut-off date for new features. Please make sure that a pull request has
> >>>>>>>>> been opened on Bitbucket by this time. This is the preferred model over
> >>>>>>>>> merging to next directly, since our Jenkins test infrastructure will test
> >>>>>>>>> each PR separately (thus providing faster feedback and thus allow for
> >>>>>>>>> faster integration).
> >>>>>>>>> And while we are at it: Please keep in mind that new features also require
> >>>>>>>>> appropriate documentation. :-)
> >>>>>>>>> Karli
