[petsc-dev] PETSc 3.10: September 4, 2018, is the cutoff-date for new features
Hapla Vaclav vaclav.hapla at erdw.ethz.ch
Wed Sep 12 10:10:31 CDT 2018
Satish, at http://www.mcs.anl.gov/petsc/download/index.html, link "Summary of PETSc-3.10 changes" still points to 39.html
Vaclav
> 12. 9. 2018 v 17:01, Satish Balay <balay at mcs.anl.gov>:
> v3.10 tag is pushed, maint & master branches are updated, and tarballs are now available for download.
> Satish
> On Wed, 12 Sep 2018, Balay, Satish wrote:
>> All release relevant PRs are now merged to master. And I'm ready to tag the release [and spin the tarballs]
>> Any potential (code, doc) fixes can be queued for 3.10.1
>> Satish
>> On Tue, 11 Sep 2018, Satish Balay wrote:
>>> Reminder!
>>> please check
>>> http://www.mcs.anl.gov/petsc/documentation/changes/dev.html and update
>>> src/docs/website/documentation/changes/dev.html with relavent changes.
>>> Thanks,
>>> Satish
>>> On Mon, 10 Sep 2018, Satish Balay wrote:
>>>> Also - please check and update src/docs/website/documentation/changes/dev.html as needed.
>>>> Thanks,
>>>> Satish
>>>> On Wed, 5 Sep 2018, Karl Rupp wrote:
>>>>> Dear PETSc developers,
>>>>> please open any outstanding pull requests for the upcoming PETSc 3.10 release
>>>>> in the next few hours. After that, please do not merge anything to `next` or
>>>>> `master` unless it is integration work for existing open PRs.
>>>>> You can open up new pull requests in the next days and weeks as usual. If
>>>>> these are documentation enhancements, we will most likely integrate them
>>>>> quickly. If these are bugfixes, we may still integrate them for PETSc 3.10,
>>>>> decided on a per-case basis. New features, however, will not be integrated
>>>>> until PETSc 3.10 is out.
>>>>> Thanks and best regards,
>>>>> Karli
>>>>>> this is a gentle reminder for the cutoff-date on September 4.
>>>>>> Best regards,
>>>>>> Karli
>>>>>>> in order to ensure a PETSc 3.10 release no later than by the end of
>>>>>>> September (possibly earlier), we agreed on September 4, 2018, as the
>>>>>>> cut-off date for new features. Please make sure that a pull request has
>>>>>>> been opened on Bitbucket by this time. This is the preferred model over
>>>>>>> merging to next directly, since our Jenkins test infrastructure will test
>>>>>>> each PR separately (thus providing faster feedback and thus allow for
>>>>>>> faster integration).
>>>>>>> And while we are at it: Please keep in mind that new features also require
>>>>>>> appropriate documentation. :-)
>>>>>>> Karli
