[petsc-dev] plex test 26 failing for complex
Wed Oct 24 09:03:06 CDT 2018
On Wed, Oct 24, 2018 at 9:54 AM Hapla Vaclav <vaclav.hapla at erdw.ethz.ch>
wrote:
> Tests dm_impls_plex_tests-ex26% fail for exodusii+complex build.
> E.g.
> not ok dm_impls_plex_tests-ex26_15
> #       [0]PETSC ERROR: --------------------- Error Message
> #       [0]PETSC ERROR: Petsc has generated inconsistent data
> #       [0]PETSC ERROR: UAlpha ||Vin - Vout|| = 1000.56
> #       [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> #       [0]PETSC ERROR: Petsc Development GIT revision:
> v3.10.1-219-g632bab2  GIT Date: 2018-10-24 12:51:19 +0200
> #       [0]PETSC ERROR: ../ex26 on a arch-linux-gcc-complex-single-64idx
> named swp-group-pc by vhapla Wed Oct 24 15:43:20 2018
> #       [0]PETSC ERROR: Configure options --download-c2html
> --download-f2cblaslapack --download-exodusii --download-hdf5
> --download-metis --download-netcdf --download-pnetcdf --download-parmetis
> --download-ptscotch --download-ctetgen --with-64-bit-indices
> --download-zlib --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpifort
> --with-precision=single --with-python=1 --with-scalar-type=complex
> --with-shared-libraries=1 --with-valgrind-dir=/home/vhapla
> PETSC_ARCH=arch-linux-gcc-complex-single-64idx
> #       [0]PETSC ERROR: #1 main() line 387 in
> /home/vhapla/petsc-1/src/dm/impls/plex/examples/tests/ex26.c
> Should this be fixed or "requires: !complex" added?
Yes. This is Blaise's test, and I do not know if it was intended to work
with complex.
     Matt
> Is this configuration not covered by nightly tests?
> Vaclav
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181024/809eb3b1/attachment.html>
