[petsc-dev] plex test 26 failing for complex
Hapla Vaclav
vaclav.hapla at erdw.ethz.ch
Wed Oct 24 08:53:45 CDT 2018
Tests dm_impls_plex_tests-ex26% fail for exodusii+complex build.
E.g.
not ok dm_impls_plex_tests-ex26_15
# [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
# [0]PETSC ERROR: Petsc has generated inconsistent data
# [0]PETSC ERROR: UAlpha ||Vin - Vout|| = 1000.56
# [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
# [0]PETSC ERROR: Petsc Development GIT revision: v3.10.1-219-g632bab2 GIT Date: 2018-10-24 12:51:19 +0200
# [0]PETSC ERROR: ../ex26 on a arch-linux-gcc-complex-single-64idx named swp-group-pc by vhapla Wed Oct 24 15:43:20 2018
# [0]PETSC ERROR: Configure options --download-c2html --download-f2cblaslapack --download-exodusii --download-hdf5 --download-metis --download-netcdf --download-pnetcdf --download-parmetis --download-ptscotch --download-ctetgen --with-64-bit-indices --download-zlib --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpifort --with-precision=single --with-python=1 --with-scalar-type=complex --with-shared-libraries=1 --with-valgrind-dir=/home/vhapla PETSC_ARCH=arch-linux-gcc-complex-single-64idx
# [0]PETSC ERROR: #1 main() line 387 in /home/vhapla/petsc-1/src/dm/impls/plex/examples/tests/ex26.c
Should this be fixed or "requires: !complex" added?
Is this configuration not covered by nightly tests?
Vaclav
