[petsc-dev] plex test 26 failing for complex
Blaise A Bourdin bourdin at lsu.edu
Wed Oct 24 13:30:47 CDT 2018
On Oct 24, 2018, at 9:03 AM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Oct 24, 2018 at 9:54 AM Hapla Vaclav <vaclav.hapla at erdw.ethz.ch<mailto:vaclav.hapla at erdw.ethz.ch>> wrote:
Tests dm_impls_plex_tests-ex26% fail for exodusii+complex build.
E.g.
not ok dm_impls_plex_tests-ex26_15
#       [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
#       [0]PETSC ERROR: Petsc has generated inconsistent data
#       [0]PETSC ERROR: UAlpha ||Vin - Vout|| = 1000.56
#       [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
#       [0]PETSC ERROR: Petsc Development GIT revision: v3.10.1-219-g632bab2  GIT Date: 2018-10-24 12:51:19 +0200
#       [0]PETSC ERROR: ../ex26 on a arch-linux-gcc-complex-single-64idx named swp-group-pc by vhapla Wed Oct 24 15:43:20 2018
#       [0]PETSC ERROR: Configure options --download-c2html --download-f2cblaslapack --download-exodusii --download-hdf5 --download-metis --download-netcdf --download-pnetcdf --download-parmetis --download-ptscotch --download-ctetgen --with-64-bit-indices --download-zlib --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpifort --with-precision=single --with-python=1 --with-scalar-type=complex --with-shared-libraries=1 --with-valgrind-dir=/home/vhapla PETSC_ARCH=arch-linux-gcc-complex-single-64idx
#       [0]PETSC ERROR: #1 main() line 387 in /home/vhapla/petsc-1/src/dm/impls/plex/examples/tests/ex26.c
Should this be fixed or "requires: !complex" added?
Yes. This is Blaise's test, and I do not know if it was intended to work with complex.
No, it is not.
Blaise
     Matt
Is this configuration not covered by nightly tests?
Vaclav
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181024/7898dc04/attachment.html>
