[petsc-dev] Fortran interface problem in v.3.10.2
Adrian Croucher a.croucher at auckland.ac.nz
Thu Oct 18 22:14:53 CDT 2018
hi Barry,
On 18/10/18 11:34 AM, Smith, Barry F. wrote:
>     Sorry about this problem. I think the change was only introduced in master and should not affect 3.10.x Please confirm that master is where the failed compile is?
Yes, it's on master. I have tracked down the commit at which it started
to fail: 6f222c9d1e, "type checking for Fortran" (Fri Sep 28).
>     Please send us the calling sequence of your routine that won't compile (cut and paste).
I've attached a minimal example program which fails with the following
error:
    call SNESSetConvergenceTest(snes, convergence, context, &
                                                  1
Error: Actual argument at (1) to assumed-type dummy is of derived type
with type-bound or FINAL procedures
Cheers, Adrian
>> On Oct 17, 2018, at 5:21 PM, Adrian Croucher <a.croucher at auckland.ac.nz> wrote:
>> hi
>> A colleague has just reported that my code no longer builds with PETSc 3.10.2, though it builds OK with 3.10.1.
>> The problem appears to be the Fortran interface to SNESSetConvergenceTest(), which was changed at commit f9a1a4d.
>> It now complains about the context argument we are passing in to this function ('cctx' in the interface, which is declared there as type(*)). The error is:
>> "Error: Actual argument at (1) to assumed-type dummy is of derived type with type-bound or FINAL procedures"
>> This is true, the argument being passed in is of derived type with type-bound procedures. Previously this didn't bother it, but it looks like it does now.
>> Is its complaint legitimate? or perhaps a compiler bug? (this is using gcc 6.3.0)
>> - Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181019/2d43ed45/attachment.bin>
