[petsc-dev] Fortran interface problem in v.3.10.2
Smith, Barry F.
bsmith at mcs.anl.gov
Fri Oct 19 14:52:31 CDT 2018
Adrian,
I goggled a bit but couldn't understand anything I found. My guess is that
type(*)
doesn't work for certain derived types (why not?) perhaps those that contain procedures. If I remove the procedure from the
routine it all compiles, thus producing some evidence my theory is correct.
So we have a problem. The type checking one user wants is causing another users code to not build.
Here is a short term fix you can do. After you run ./configure edit $PETSC_ARCH/include/petscconf.h locate
#ifndef PETSC_HAVE_FORTRAN_TYPE_STAR
#define PETSC_HAVE_FORTRAN_TYPE_STAR 1
#endif
then run make. This will turn off the type checking for all routines that have type(*) arguments which includes SNESSetConvergenceTest
I don't have a good long term solution at the moment. Maybe a Fortran expert has some idea.
Barry
> On Oct 18, 2018, at 10:14 PM, Adrian Croucher <a.croucher at auckland.ac.nz> wrote:
> hi Barry,
> On 18/10/18 11:34 AM, Smith, Barry F. wrote:
>> Sorry about this problem. I think the change was only introduced in master and should not affect 3.10.x Please confirm that master is where the failed compile is?
> Yes, it's on master. I have tracked down the commit at which it started to fail: 6f222c9d1e, "type checking for Fortran" (Fri Sep 28).
>> Please send us the calling sequence of your routine that won't compile (cut and paste).
> I've attached a minimal example program which fails with the following error:
> call SNESSetConvergenceTest(snes, convergence, context, &
> 1
> Error: Actual argument at (1) to assumed-type dummy is of derived type with type-bound or FINAL procedures
> Cheers, Adrian
>>> On Oct 17, 2018, at 5:21 PM, Adrian Croucher <a.croucher at auckland.ac.nz> wrote:
>>> hi
>>> A colleague has just reported that my code no longer builds with PETSc 3.10.2, though it builds OK with 3.10.1.
>>> The problem appears to be the Fortran interface to SNESSetConvergenceTest(), which was changed at commit f9a1a4d.
>>> It now complains about the context argument we are passing in to this function ('cctx' in the interface, which is declared there as type(*)). The error is:
>>> "Error: Actual argument at (1) to assumed-type dummy is of derived type with type-bound or FINAL procedures"
>>> This is true, the argument being passed in is of derived type with type-bound procedures. Previously this didn't bother it, but it looks like it does now.
>>> Is its complaint legitimate? or perhaps a compiler bug? (this is using gcc 6.3.0)
>>> - Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
> <test_snes.F90>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181019/8263aa63/attachment.html>
Desc: test_snes.F90
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181019/8263aa63/attachment.obj>
