[petsc-dev] Fortran interface problem in v.3.10.2
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Wed Oct 17 17:34:10 CDT 2018
   Sorry about this problem. I think the change was only introduced in master and should not affect 3.10.x Please confirm that master is where the failed compile is?
   Please send us the calling sequence of your routine that won't compile (cut and paste).
    Barry
> On Oct 17, 2018, at 5:21 PM, Adrian Croucher <a.croucher at auckland.ac.nz> wrote:
> hi
> A colleague has just reported that my code no longer builds with PETSc 3.10.2, though it builds OK with 3.10.1.
> The problem appears to be the Fortran interface to SNESSetConvergenceTest(), which was changed at commit f9a1a4d.
> It now complains about the context argument we are passing in to this function ('cctx' in the interface, which is declared there as type(*)). The error is:
> "Error: Actual argument at (1) to assumed-type dummy is of derived type with type-bound or FINAL procedures"
> This is true, the argument being passed in is of derived type with type-bound procedures. Previously this didn't bother it, but it looks like it does now.
> Is its complaint legitimate? or perhaps a compiler bug? (this is using gcc 6.3.0)
> - Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
