[petsc-dev] Fwd: segv with triangle
    Balay, Satish
    balay at mcs.anl.gov
    Fri Nov 23 10:06:59 CST 2018
I see the taball is off triangle-1.3 - and the repo has 1.6 related changes.
So I'm adding this patch in maint-1.3 branch - and created https://bitbucket.org/petsc/pkg-triangle
Matt would have to check and see if we need to switch to 1.6 version..
Satish
On Fri, 23 Nov 2018, Balay, Satish via petsc-dev wrote:
> Updated tarball for now
> I see we had an old Triangle repo with hg. I should migrate it to git and use it for these changes..
> Satish
> On Thu, 22 Nov 2018, Stefano Zampini wrote:
> > Satish,
> > I have reported this issue to Matt some time ago but he probably forgot to
> > fix it.
> > Attached is new tarball for Triangle that fixes the issues with the Intel
> > compilers in next-tmp here
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/11/21/examples_next-tmp_arch-pardiso_grind.log
> > The changes are minimal, here is the diff
> > diff -r Triangle/src/triangle.c TriangleOld/src/triangle.c
> > 326,327d325
> > < #else /* Stefano Zampini - Thu Nov 22 10:35:29 +03 2018: we need to
> > include stdlib.h for malloc */
> > <   #include <stdlib.h>
> > Could you please upload it?
> > Thanks
> > Stefano
> > ---------- Forwarded message ---------
> > From: Stefano Zampini <stefano.zampini at gmail.com>
> > Date: lun 15 mag 2017 alle ore 00:23
> > Subject: Re: segv with triangle
> > To: Matthew Knepley <knepley at gmail.com>
> > Matt, I did some test, and it seems related with your NO_PETSC_MALLOC define
> > you should include <stdlib.h> if NO_PETSC_MALLOC is not defined.
> > Adding the header file fixed the problem
> > On May 14, 2017, at 9:24 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Sun, May 14, 2017 at 10:58 AM, Stefano Zampini <stefano.zampini at gmail.com
> > > wrote:
> > > And using the latest intel compiler. Could it be causing the problem?
> > Possibly. I would
> > a) Do a build with gcc. Last time this came up, the gcc build worked. The
> > triangle source is huge, and
> >     some compilers just shit the bed with their optimizations.
> > b) If that works, we might back off some optimizations
> > c) If not, we can get a valgrind trace, but I have never personally seen a
> > triangle bug
> >   Thanks,
> >      Matt
> > > On May 14, 2017, at 5:44 PM, Stefano Zampini <stefano.zampini at gmail.com>
> > > wrote:
> > > Forgot to say that it is a brand new installation I did, using the latest
> > > next
> > > On May 14, 2017, at 5:36 PM, Stefano Zampini <stefano.zampini at gmail.com>
> > > wrote:
> > > Matt,
> > > this is from next, on a machine I have never run on
> > > #0  0x00007ffff74735a1 in poolinit (pool=0x7ffff7dd9b80 <triangles>,
> > > bytecount=72, itemcount=4092, wtype=POINTER, alignment=4) at
> > > src/triangle.c:3227
> > > #1  0x00007ffff7473fe0 in initializetrisegpools () at src/triangle.c:3597
> > > #2  0x00007ffff748e5e6 in delaunay () at src/triangle.c:8648
> > > #3  0x00007ffff749870c in triangulate (triswitches=0x7fffffffb020 "pqezQ",
> > > in=0x7fffffffb1f0, out=0x7fffffffb298, vorout=0x0) at src/triangle.c:12993
> > > #4  0x00007ffff5e2ed22 in DMPlexGenerate_Triangle (boundary=0x8218f0,
> > > interpolate=PETSC_FALSE, dm=0x7fffffffc580)
> > >     at
> > > /marconi/home/userexternal/lpavarin/petsc/src/dm/impls/plex/plexgenerate.c:269
> > > #5  0x00007ffff5e3830c in DMPlexGenerate (boundary=0x8218f0, name=0x0,
> > > interpolate=PETSC_FALSE, mesh=0x7fffffffc580)
> > >     at
> > > /marconi/home/userexternal/lpavarin/petsc/src/dm/impls/plex/plexgenerate.c:1097
> > > #6  0x00007ffff5b50da4 in DMPlexCreateBoxMesh (comm=1140850688, dim=2,
> > > numFaces=2, interpolate=PETSC_FALSE, dm=0x7fffffffc580)
> > >     at
> > > /marconi/home/userexternal/lpavarin/petsc/src/dm/impls/plex/plexcreate.c:491
> > > #7  0x0000000000404ffa in CreateMesh (comm=1140850688,
> > > user=0x7fffffffc538, dm=0x7fffffffc580)
> > >     at
> > > /marconi/home/userexternal/lpavarin/petsc/src/snes/examples/tutorials/ex62.c:305
> > > #8  0x0000000000408b95 in main (argc=1, argv=0x7fffffffcba8) at
> > > /marconi/home/userexternal/lpavarin/petsc/src/snes/examples/tutorials/ex62.c:485
