[petsc-dev] Fwd: segv with triangle
Balay, Satish balay at mcs.anl.gov
Fri Nov 23 09:30:41 CST 2018
Updated tarball for now
I see we had an old Triangle repo with hg. I should migrate it to git and use it for these changes..
Satish
On Thu, 22 Nov 2018, Stefano Zampini wrote:
> Satish,
> I have reported this issue to Matt some time ago but he probably forgot to
> fix it.
> Attached is new tarball for Triangle that fixes the issues with the Intel
> compilers in next-tmp here
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/11/21/examples_next-tmp_arch-pardiso_grind.log
> The changes are minimal, here is the diff
> diff -r Triangle/src/triangle.c TriangleOld/src/triangle.c
> 326,327d325
> < #else /* Stefano Zampini - Thu Nov 22 10:35:29 +03 2018: we need to
> include stdlib.h for malloc */
> <   #include <stdlib.h>
> Could you please upload it?
> Thanks
> Stefano
> ---------- Forwarded message ---------
> From: Stefano Zampini <stefano.zampini at gmail.com>
> Date: lun 15 mag 2017 alle ore 00:23
> Subject: Re: segv with triangle
> To: Matthew Knepley <knepley at gmail.com>
> Matt, I did some test, and it seems related with your NO_PETSC_MALLOC define
> you should include <stdlib.h> if NO_PETSC_MALLOC is not defined.
> Adding the header file fixed the problem
> On May 14, 2017, at 9:24 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, May 14, 2017 at 10:58 AM, Stefano Zampini <stefano.zampini at gmail.com
> > wrote:
> > And using the latest intel compiler. Could it be causing the problem?
> Possibly. I would
> a) Do a build with gcc. Last time this came up, the gcc build worked. The
> triangle source is huge, and
>     some compilers just shit the bed with their optimizations.
> b) If that works, we might back off some optimizations
> c) If not, we can get a valgrind trace, but I have never personally seen a
> triangle bug
>   Thanks,
>      Matt
> > On May 14, 2017, at 5:44 PM, Stefano Zampini <stefano.zampini at gmail.com>
> > wrote:
> > Forgot to say that it is a brand new installation I did, using the latest
> > next
> > On May 14, 2017, at 5:36 PM, Stefano Zampini <stefano.zampini at gmail.com>
> > wrote:
> > Matt,
> > this is from next, on a machine I have never run on
> > #0  0x00007ffff74735a1 in poolinit (pool=0x7ffff7dd9b80 <triangles>,
> > bytecount=72, itemcount=4092, wtype=POINTER, alignment=4) at
> > src/triangle.c:3227
> > #1  0x00007ffff7473fe0 in initializetrisegpools () at src/triangle.c:3597
> > #2  0x00007ffff748e5e6 in delaunay () at src/triangle.c:8648
> > #3  0x00007ffff749870c in triangulate (triswitches=0x7fffffffb020 "pqezQ",
> > in=0x7fffffffb1f0, out=0x7fffffffb298, vorout=0x0) at src/triangle.c:12993
> > #4  0x00007ffff5e2ed22 in DMPlexGenerate_Triangle (boundary=0x8218f0,
> > interpolate=PETSC_FALSE, dm=0x7fffffffc580)
> >     at
> > /marconi/home/userexternal/lpavarin/petsc/src/dm/impls/plex/plexgenerate.c:269
> > #5  0x00007ffff5e3830c in DMPlexGenerate (boundary=0x8218f0, name=0x0,
> > interpolate=PETSC_FALSE, mesh=0x7fffffffc580)
> >     at
> > /marconi/home/userexternal/lpavarin/petsc/src/dm/impls/plex/plexgenerate.c:1097
> > #6  0x00007ffff5b50da4 in DMPlexCreateBoxMesh (comm=1140850688, dim=2,
> > numFaces=2, interpolate=PETSC_FALSE, dm=0x7fffffffc580)
> >     at
> > /marconi/home/userexternal/lpavarin/petsc/src/dm/impls/plex/plexcreate.c:491
> > #7  0x0000000000404ffa in CreateMesh (comm=1140850688,
> > user=0x7fffffffc538, dm=0x7fffffffc580)
> >     at
> > /marconi/home/userexternal/lpavarin/petsc/src/snes/examples/tutorials/ex62.c:305
> > #8  0x0000000000408b95 in main (argc=1, argv=0x7fffffffcba8) at
> > /marconi/home/userexternal/lpavarin/petsc/src/snes/examples/tutorials/ex62.c:485
