[petsc-dev] configure issues with new MKL and --with-mkl_sparse_optimize=0
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu Nov 22 01:01:14 CST 2018
Sorry, I meant "grind" not "frog" as MCS machine
Il giorno gio 22 nov 2018 alle ore 09:59 Stefano Zampini <
stefano.zampini at gmail.com> ha scritto:
> Richard,
> I just noticed that PETSc master does not build with the options
>     '--with-mkl_pardiso-dir=/soft/com/packages/intel/18/u3/mkl',
>     '--with-mkl_sparse_optimize=0',
> This is on frog at MCS, but it will be the same on other machines as the
> macros configuration
> PETSC_HAVE_MKL_SPARSE_OPTIMIZE not defined
> PETSC_HAVE_MKL_SPARSE_SP2M defined
> does not seem to be supported.
> /nfs2/szampini/src/petsc/src/mat/impls/aij/seq/aijmkl/aijmkl.c(797):
> error: struct "<unnamed>" has no field "csrA"
>     csrA = a->csrA;
> Could you please take a look? Why is the mkl_sparse_sp2m package flagged
> as lookforbydefault in the configure scripts?
> Thanks
> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181122/92e01e12/attachment.html>
