[petsc-dev] configure issues with new MKL and --with-mkl_sparse_optimize=0
Mills, Richard Tran rtmills at anl.gov
Mon Nov 26 18:12:27 CST 2018
Hi Stefano,
Apologies for the slow reply; I was out for the US Thanksgiving Holiday.
You've found an error in the logic for the MKL configure tests: Your MKL does indeed have mkl_sparse_sp2m(), but since this depends on having mkl_sparse_optimize() and you have specified '--with-mkl_sparse_optimize=0', PETSC_HAVE_MKL_SPARSE_SP2M either ought to not be defined, or in my AIJMKL code I should only enable the SP2M code if PETSC_HAVE_MKL_SPARSE_OPTIMIZE is defined. I think I like the former option better. For those more familiar with BuildSystem than I am, I think I can do this by putting the following in setupDependencies() in mkl_sparse_sp2m.py:
    self.mkl_sparse_optimize  = framework.require('config.packages.mkl_sparse_optimize', self)
    self.deps                           = [self.blasLapack,self.mkl_sparse_optimize]
Is that all that is required?
--Richard
On 11/21/18 10:59 PM, Stefano Zampini wrote:
Richard,
I just noticed that PETSc master does not build with the options
    '--with-mkl_pardiso-dir=/soft/com/packages/intel/18/u3/mkl',
This is on frog at MCS, but it will be the same on other machines as the macros configuration
PETSC_HAVE_MKL_SPARSE_OPTIMIZE not defined
PETSC_HAVE_MKL_SPARSE_SP2M defined
does not seem to be supported.
/nfs2/szampini/src/petsc/src/mat/impls/aij/seq/aijmkl/aijmkl.c(797): error: struct "<unnamed>" has no field "csrA"
    csrA = a->csrA;
Could you please take a look? Why is the mkl_sparse_sp2m package flagged as lookforbydefault in the configure scripts?
Thanks
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181127/8fd634b0/attachment.html>
