[petsc-dev] configure issues with new MKL and --with-mkl_sparse_optimize=0
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu Nov 22 00:59:19 CST 2018
Richard,
I just noticed that PETSc master does not build with the options
    '--with-mkl_pardiso-dir=/soft/com/packages/intel/18/u3/mkl',
    '--with-mkl_sparse_optimize=0',
This is on frog at MCS, but it will be the same on other machines as the
macros configuration
PETSC_HAVE_MKL_SPARSE_OPTIMIZE not defined
PETSC_HAVE_MKL_SPARSE_SP2M defined
does not seem to be supported.
/nfs2/szampini/src/petsc/src/mat/impls/aij/seq/aijmkl/aijmkl.c(797): error:
struct "<unnamed>" has no field "csrA"
    csrA = a->csrA;
Could you please take a look? Why is the mkl_sparse_sp2m package flagged as
lookforbydefault in the configure scripts?
Thanks
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181122/a58cce8e/attachment.html>
