[petsc-dev] Install location for MPIUNI mpi.h
Mon May 14 13:41:46 CDT 2018
I have the following changes in balay/mpiuni-include/jed
- mpi.mod -> mpiuni.mod
- remove -Iinclde/petsc/mpiuni
If ok - they can be pulled into jed/mpiuni-include/maint
Satish
On Wed, 25 Apr 2018, Satish Balay wrote:
> On Wed, 25 Apr 2018, Jed Brown wrote:
> > Bitbucket keeps saying "Something went wrong while creating your pull
> > request." but you can look at the branch
> > https://bitbucket.org/petsc/petsc/branch/jed/mpiuni-include/maint
> > @balay Can we simply remove the MPIUNI includes from MPI.py or should we
> > remove it later?
> Best to remove now - to check if there are issues?
> also Fix mpif.h usage code?
> There is also mpi.mod - that might need renaming [to comply with not installing in /usr/include?]
> So rename to mpiuni.mod? [and rename mpi.h to mpiuni.h etc?]
> Looks like this change is more of a 'master change'..
> >  What --download packages are supported when using
> > MPIUNI?  I don't see any examples.
> Yeah - our tests are basic here. I don't remember if any externalpackages compiled with mpiuni
> Satish
