[petsc-dev] Nested XML logging and stages
Lisandro Dalcin dalcinl at gmail.com
Thu May 17 19:54:14 CDT 2018
https://bitbucket.org/petsc/petsc/pull-requests/964/logxml-various-enhancements/diff
On Mon, 14 May 2018 at 23:51, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>    I am fine with the suggested changes.
> > On May 13, 2018, at 1:06 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> > It took me a while to figure out why my xml -log_view was empty. Nested
XML
> > logging and push/pop user-defined stages simply does not work, the
> > implementation cannot cope with this usage pattern.
> > Would it be OK to at ignore push/pop stages if XML is on, and then log
> > everything in the main stage, to at least get an non-empty xml log
file? I
> > guess this would require a private global flag.
> > Now that I am on it, could we add a command line option to set the XML
> > logging threshold? I would like to pass -log_threshold 0 to get
everything,
> > but surprisingly "0" is not a good value, NaNs are generated. So I
guess we
> > need something like PetscMax(threshold,1e-10).
> > Why PetscLogView_Nested() calls PetscLogNestedEnd() ? While convenient
and
> > quick to implement, it smells like bad API usage.
>    I don't see a nice alternative.
>     Barry
> > Lisandro Dalcin
> > Research Scientist
> > Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> > Extreme Computing Research Center (ECRC)
> > King Abdullah University of Science and Technology (KAUST)
> > http://ecrc.kaust.edu.sa/
> > 4700 King Abdullah University of Science and Technology
> > al-Khawarizmi Bldg (Bldg 1), Office # 0109
> > Thuwal 23955-6900, Kingdom of Saudi Arabia
> > http://www.kaust.edu.sa
> > Office Phone: +966 12 808-0459
Lisandro Dalcin
Research Scientist
