[petsc-dev] [mpich-discuss] Is mpich/master:a8a2b30fd21 tested with Petsc?
Jed Brown jed at jedbrown.org
Tue Mar 27 22:39:08 CDT 2018
I also observe repeatable deadlock with current MPICH 'master' in
seemingly benign places.
$ mpiexec -n 2 mpich-clang/tests/ksp/ksp/examples/tutorials/ex2
Rank 0:
#0  0x00007f950cb35dd0 in MPID_nem_tcp_connpoll () from /home/jed/usr/mpich-clang/lib/libmpi.so.0
#1  0x00007f950cb25896 in MPIDI_CH3I_Progress () from /home/jed/usr/mpich-clang/lib/libmpi.so.0
#2  0x00007f950ca20595 in MPIR_Waitall_impl () from /home/jed/usr/mpich-clang/lib/libmpi.so.0
#3  0x00007f950ca1fb2f in PMPI_Waitall () from /home/jed/usr/mpich-clang/lib/libmpi.so.0
#4  0x00007f950f4cf450 in PetscGatherMessageLengths (comm=-2080374780, nsends=1, nrecvs=1, ilengths=0x55e5560ab4b0, onodes=0x7ffd8bab4fc0, olengths=0x7ffd8bab4fb8) at /home/jed/petsc/src/sys/utils/mpimesg.c:127
#5  0x00007f950f6ada4a in VecScatterCreateLocal_PtoS_MPI1 (nx=7, inidx=0x55e5560a4880, ny=7, inidy=0x55e5560aae40, xin=0x55e5560a7870, yin=0x55e556098530, bs=1, ctx=0x55e5560a9ed0) at /home/jed/petsc/src/vec/vscat/impls/vpscat_mpi1.c:2145
#6  0x00007f950f6174d6 in VecScatterCreate_PtoS (ctx=0x55e5560a9ed0) at /home/jed/petsc/src/vec/vscat/impls/vscat.c:1319
#7  0x00007f950f60fdf7 in VecScatterCreate_vectype_private (ctx=0x55e5560a9ed0) at /home/jed/petsc/src/vec/vscat/impls/vscat.c:1605
#8  0x00007f950f60fac7 in VecScatterCreate_MPI1 (ctx=0x55e5560a9ed0) at /home/jed/petsc/src/vec/vscat/impls/vscat.c:1622
#9  0x00007f950f6b69a3 in VecScatterSetType (vscat=0x55e5560a9ed0, type=0x7f9510d535a1 "mpi1") at /home/jed/petsc/src/vec/vscat/interface/vscreate.c:65
#10 0x00007f950f6b8802 in VecScatterCreate (xin=0x55e5560a7870, ix=0x55e5560a18a0, yin=0x55e556098530, iy=0x55e5560a4ef0, newctx=0x55e556038ec0) at /home/jed/petsc/src/vec/vscat/interface/vscreate.c:313
#11 0x00007f950fe01a4c in MatSetUpMultiply_MPIAIJ (mat=0x55e556036350) at /home/jed/petsc/src/mat/impls/aij/mpi/mmaij.c:131
#12 0x00007f950fdbdf3a in MatAssemblyEnd_MPIAIJ (mat=0x55e556036350, mode=MAT_FINAL_ASSEMBLY) at /home/jed/petsc/src/mat/impls/aij/mpi/mpiaij.c:735
#13 0x00007f950f8fec0e in MatAssemblyEnd (mat=0x55e556036350, type=MAT_FINAL_ASSEMBLY) at /home/jed/petsc/src/mat/interface/matrix.c:5251
#14 0x000055e553da5488 in main (argc=1, args=0x7ffd8bab5918) at /home/jed/petsc/src/ksp/ksp/examples/tutorials/ex2.c:108
Rank 1:
#0  0x00007f3bf2bc1900 in MPIDI_CH3I_Progress () from /home/jed/usr/mpich-clang/lib/libmpi.so.0
#1  0x00007f3bf2abc595 in MPIR_Waitall_impl () from /home/jed/usr/mpich-clang/lib/libmpi.so.0
#2  0x00007f3bf2abbb2f in PMPI_Waitall () from /home/jed/usr/mpich-clang/lib/libmpi.so.0
#3  0x00007f3bf556b450 in PetscGatherMessageLengths (comm=-2080374782, nsends=1, nrecvs=1, ilengths=0x555adf6094b0, onodes=0x7fff53b10670, olengths=0x7fff53b10668) at /home/jed/petsc/src/sys/utils/mpimesg.c:127
#4  0x00007f3bf5749a4a in VecScatterCreateLocal_PtoS_MPI1 (nx=7, inidx=0x555adf602880, ny=7, inidy=0x555adf608e40, xin=0x555adf605870, yin=0x555adf5f6530, bs=1, ctx=0x555adf607ed0) at /home/jed/petsc/src/vec/vscat/impls/vpscat_mpi1.c:2145
#5  0x00007f3bf56b34d6 in VecScatterCreate_PtoS (ctx=0x555adf607ed0) at /home/jed/petsc/src/vec/vscat/impls/vscat.c:1319
#6  0x00007f3bf56abdf7 in VecScatterCreate_vectype_private (ctx=0x555adf607ed0) at /home/jed/petsc/src/vec/vscat/impls/vscat.c:1605
#7  0x00007f3bf56abac7 in VecScatterCreate_MPI1 (ctx=0x555adf607ed0) at /home/jed/petsc/src/vec/vscat/impls/vscat.c:1622
#8  0x00007f3bf57529a3 in VecScatterSetType (vscat=0x555adf607ed0, type=0x7f3bf6def5a1 "mpi1") at /home/jed/petsc/src/vec/vscat/interface/vscreate.c:65
#9  0x00007f3bf5754802 in VecScatterCreate (xin=0x555adf605870, ix=0x555adf5ff8a0, yin=0x555adf5f6530, iy=0x555adf602ef0, newctx=0x555adf596ec0) at /home/jed/petsc/src/vec/vscat/interface/vscreate.c:313
#10 0x00007f3bf5e9da4c in MatSetUpMultiply_MPIAIJ (mat=0x555adf594350) at /home/jed/petsc/src/mat/impls/aij/mpi/mmaij.c:131
#11 0x00007f3bf5e59f3a in MatAssemblyEnd_MPIAIJ (mat=0x555adf594350, mode=MAT_FINAL_ASSEMBLY) at /home/jed/petsc/src/mat/impls/aij/mpi/mpiaij.c:735
#12 0x00007f3bf599ac0e in MatAssemblyEnd (mat=0x555adf594350, type=MAT_FINAL_ASSEMBLY) at /home/jed/petsc/src/mat/interface/matrix.c:5251
#13 0x0000555addb47488 in main (argc=1, args=0x7fff53b10fc8) at /home/jed/petsc/src/ksp/ksp/examples/tutorials/ex2.c:108
This is the relevant code (barrier added while debugging).  I confirm in
the debugger that the tags match.
  MPI_Barrier(comm);
  /* Post the Irecv to get the message length-info */
  ierr = PetscMalloc1(nrecvs,olengths);CHKERRQ(ierr);
  for (i=0; i<nrecvs; i++) {
    ierr = MPI_Irecv((*olengths)+i,1,MPI_INT,MPI_ANY_SOURCE,tag,comm,r_waits+i);CHKERRQ(ierr);
  /* Post the Isends with the message length-info */
  for (i=0,j=0; i<size; ++i) {
    if (ilengths[i]) {
      ierr = MPI_Isend((void*)(ilengths+i),1,MPI_INT,i,tag,comm,s_waits+j);CHKERRQ(ierr);
      j++;
  /* Post waits on sends and receivs */
  if (nrecvs+nsends) {ierr = MPI_Waitall(nrecvs+nsends,r_waits,w_status);CHKERRQ(ierr);}
Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> writes:
> Hi Min and Matthew,
> In fact, I just ran an "hello word" on 2 processes and it works. I do
> not have a more complicated example without PETSc since I have a
> Petsc-based source code...
> However, I just tried to launch "make testing" into the mpich directory
> and it ended with some failed tests  and it was very long: about an
> hour.  Is it normal?
> Please, see the attached file: summary.xml
> Thanks,
> Eric
> On 27/03/18 05:04 PM, Matthew Knepley wrote:
>> On Tue, Mar 27, 2018 at 4:59 PM, Min Si <msi at anl.gov
>> <mailto:msi at anl.gov>> wrote:
>>     Hi Eric,
>>     It will be great if you could give us a simple MPI program (not
>>     with PETSc) to reproduce this issue. If this is a problem happens
>>     only when PETSc is involved, the PETSc team can give you more
>>     suggestions.
>> Hi Min,
>> It is really easy to run PETSc at ANL. I am sure one of us can help if
>> you cannot reproduce this bug on your own.
>>   Thanks,
>>      Matt
>>     Thanks,
>>     Min
>>     On 2018/03/27 15:38, Eric Chamberland wrote:
>>         Hi,
>>         since more than 2 weeks that the master branch of mpich is
>>         still and it can be reproduced with a simple "make test" after
>>         a fresh installation of PETSc...
>>         Is anyone testing it?
>>         Is it supposed to be working?
>>         Just tell me if I should "follow" another mpich branch please.
>>         Thanks,
>>         Eric
>>         On 14/03/18 03:35 AM, Eric Chamberland wrote:
>>             Hi,
>>             fwiw, the actual mpich/master branch doesn't passes the
>>             PETSc "make test" after a fresh installation...  It hangs
>>             just afer the 1 MPI process test, meaning it is locked
>>             into the 2 process test:
>>             make
>>             PETSC_DIR=/pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/mpich-3.x-debug/petsc-3.8.3-debug
>>             PETSC_ARCH=arch-linux2-c-debug test
>>             Running test examples to verify correct installation
>>             Using
>>             and PETSC_ARCH=arch-linux2-c-debug
>>             C/C++ example src/snes/examples/tutorials/ex19 run
>>             successfully with 1 MPI process
>>             ^Cmakefile:151: recipe for target 'test' failed
>>             make: [test] Interrupt (ignored)
>>             thanks,
>>             Eric
>>             On 13/03/18 08:07 AM, Eric Chamberland wrote:
>>                 Hi,
>>                 each night we are testing mpich/master with our
>>                 petsc-based code. I don't know if PETSc team is doing
>>                 the same thing with mpich/master?   (Maybe it is a
>>                 good idea?)
>>                 Everything was fine (except the issue
>>                 https://github.com/pmodels/mpich/issues/2892
>>                 <https://github.com/pmodels/mpich/issues/2892>) up to
>>                 commit 7b8d64debd, but since commit
>>                 mpich:a8a2b30fd21), I have a segfault on a any
>>                 parallel nightly test.
>>                 For example, a 2 process test ends at almost different
>>                 execution points:
>>                 rank 0:
>>                 #003: /lib64/libpthread.so.0(+0xf870) [0x7f25bf908870]
>>                 #004:
>>                 /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/BIB/bin/BIBMEFGD.opt()
>>                 [0x64a788]
>>                 #005: /lib64/libc.so.6(+0x35140) [0x7f25bca18140]
>>                 #006: /lib64/libc.so.6(__poll+0x2d) [0x7f25bcabfbfd]
>>                 #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9)
>>                 [0x7f25bd90ccc9]
>>                 #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c)
>>                 [0x7f25bd91255c]
>>                 #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xba657)
>>                 [0x7f25bd7e2657]
>>                 #010:
>>                 /opt/mpich-3.x_debug/lib/libmpi.so.0(PMPI_Waitall+0xe3)
>>                 [0x7f25bd7e3343]
>>                 #011:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscGatherMessageLengths+0x654)
>>                 [0x7f25c4bb3193]
>>                 #012:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x859)
>>                 [0x7f25c4e82d7f]
>>                 #013:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate+0x5684)
>>                 [0x7f25c4e4d055]
>>                 #014:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhostWithArray+0x688)
>>                 [0x7f25c4e01a39]
>>                 #015:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhost+0x179)
>>                 [0x7f25c4e020f6]
>>                 rank 1:
>>                 #002:
>>                 /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/GIREF/lib/libgiref_opt_Util.so(traitementSignal+0x2bd0)
>>                 [0x7f62df8e7310]
>>                 #003: /lib64/libc.so.6(+0x35140) [0x7f62d3bc9140]
>>                 #004: /lib64/libc.so.6(__poll+0x2d) [0x7f62d3c70bfd]
>>                 #005: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9)
>>                 [0x7f62d4abdcc9]
>>                 #006: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c)
>>                 [0x7f62d4ac355c]
>>                 #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12c9c5)
>>                 [0x7f62d4a059c5]
>>                 #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12e102)
>>                 [0x7f62d4a07102]
>>                 #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf17a1)
>>                 [0x7f62d49ca7a1]
>>                 #010: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3facf)
>>                 [0x7f62d4918acf]
>>                 #011: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d)
>>                 [0x7f62d4918c3d]
>>                 #012: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf18d8)
>>                 [0x7f62d49ca8d8]
>>                 #013: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fb88)
>>                 [0x7f62d4918b88]
>>                 #014: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d)
>>                 [0x7f62d4918c3d]
>>                 #015:
>>                 /opt/mpich-3.x_debug/lib/libmpi.so.0(MPI_Barrier+0x27b)
>>                 [0x7f62d4918edb]
>>                 #016:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscCommGetNewTag+0x3ff)
>>                 [0x7f62dbceb055]
>>                 #017:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscObjectGetNewTag+0x15d)
>>                 [0x7f62dbceaadb]
>>                 #018:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreateCommon_PtoS+0x1ee)
>>                 [0x7f62dc03625c]
>>                 #019:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x29c4)
>>                 [0x7f62dc035eea]
>>                 #020:
>>                 [0x7f62dbffe055]
>>                 #021:
>>                 [0x7f62dbfb2a39]
>>                 #022:
>>                 [0x7f62dbfb30f6]
>>                 Have some other users (PETSc users?) reported problem?
>>                 Thanks,
>>                 Eric
>>                 ps: usual informations:
>>                 mpich logs:
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.system
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.system>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpich_version.txt
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpich_version.txt>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_c.txt
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_c.txt>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_m.txt
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_m.txt>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mi.txt
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_mi.txt>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_openmpa_config.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_openmpa_config.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpl_config.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpl_config.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_config.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_config.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_tools_topo_config.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_tools_topo_config.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpiexec_info.txt
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpiexec_info.txt>
>>                 Petsc logs:
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_configure.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_configure.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_make.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_make.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_default.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_default.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_RDict.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_RDict.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_CMakeLists.txt
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_CMakeLists.txt>
>>         _______________________________________________
>>         discuss mailing list discuss at mpich.org <mailto:discuss at mpich.org>
>>         To manage subscription options or unsubscribe:
>>         https://lists.mpich.org/mailman/listinfo/discuss
>>         <https://lists.mpich.org/mailman/listinfo/discuss>
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
> <?xml version='1.0' ?>
> <?xml-stylesheet href="TestResults.xsl" type="text/xsl" ?>
> <MPITESTRESULTS>
> <DATE>2018-03-27-20-30</DATE>
> <MPISOURCE></MPISOURCE>
> <MPITEST>
> <NAME>attrt</NAME>
> <NP>2</NP>
> <WORKDIR>./attr</WORKDIR>
> <STATUS>pass</STATUS>
> <TIME>0.0933301448822021</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attric</NAME>
> <NP>4</NP>
> <TIME>0.124228954315186</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrerr</NAME>
> <NP>1</NP>
> <TIME>0.0767178535461426</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrend</NAME>
> <NP>1</NP>
> <TIME>0.0731050968170166</TIME>
> </MPITEST>
> <MPITEST>
> <NP>4</NP>
> <TIME>0.122277021408081</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrend2</NAME>
> <NP>1</NP>
> <TIME>0.0754919052124023</TIME>
> </MPITEST>
> <MPITEST>
> <NP>5</NP>
> <TIME>0.141027927398682</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrerrcomm</NAME>
> <NP>1</NP>
> <TIME>0.072659969329834</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrerrtype</NAME>
> <NP>1</NP>
> <TIME>0.0723199844360352</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrdeleteget</NAME>
> <NP>1</NP>
> <TIME>0.074937105178833</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attr2type</NAME>
> <NP>1</NP>
> <TIME>0.0726120471954346</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrorder</NAME>
> <NP>1</NP>
> <TIME>0.0786969661712646</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrordercomm</NAME>
> <NP>1</NP>
> <TIME>0.0704970359802246</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrordertype</NAME>
> <NP>1</NP>
> <TIME>0.0761680603027344</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseattr2</NAME>
> <NP>1</NP>
> <TIME>0.0785770416259766</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseattrcomm</NAME>
> <NP>1</NP>
> <TIME>0.0942788124084473</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fkeyval</NAME>
> <NP>1</NP>
> <TIME>0.0709991455078125</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fkeyvalcomm</NAME>
> <NP>1</NP>
> <TIME>0.0704519748687744</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fkeyvaltype</NAME>
> <NP>1</NP>
> <TIME>0.0756239891052246</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>keyval_double_free</NAME>
> <NP>1</NP>
> <TIME>0.0758621692657471</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>keyval_double_free_comm</NAME>
> <NP>1</NP>
> <TIME>0.0740189552307129</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>keyval_double_free_type</NAME>
> <NP>1</NP>
> <TIME>0.100419998168945</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>keyval_double_free_win</NAME>
> <NP>1</NP>
> <TIME>0.0701000690460205</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allred</NAME>
> <NP>4</NP>
> <WORKDIR>./coll</WORKDIR>
> <TIME>0.133531808853149</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allred</NAME>
> <NP>7</NP>
> <TIME>0.176097869873047</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allred</NAME>
> <NP>4</NP>
> <TIME>0.135380983352661</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allredmany</NAME>
> <NP>4</NP>
> <TIME>0.664204120635986</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allred2</NAME>
> <NP>4</NP>
> <TIME>0.147978067398071</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allred3</NAME>
> <NP>10</NP>
> <TIME>0.204412937164307</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allred4</NAME>
> <NP>4</NP>
> <TIME>0.128396034240723</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allred5</NAME>
> <NP>5</NP>
> <TIME>0.143068075180054</TIME>
> </MPITEST>
> <MPITEST>
> <NP>10</NP>
> <TIME>0.21518611907959</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allred6</NAME>
> <NP>4</NP>
> <TIME>0.147965908050537</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.218183994293213</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>reduce</NAME>
> <NP>5</NP>
> <TIME>0.280114889144897</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>reduce</NAME>
> <NP>10</NP>
> <TIME>0.755266904830933</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>reduce_local</NAME>
> <NP>2</NP>
> <TIME>0.0951170921325684</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>op_commutative</NAME>
> <NP>2</NP>
> <TIME>0.0912930965423584</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>red3</NAME>
> <NP>10</NP>
> <TIME>0.233151197433472</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>red4</NAME>
> <NP>10</NP>
> <TIME>0.235527038574219</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>alltoall1</NAME>
> <NP>8</NP>
> <TIME>0.47490406036377</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>alltoallv</NAME>
> <NP>10</NP>
> <TIME>0.217301845550537</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>alltoallv0</NAME>
> <NP>10</NP>
> <TIME>0.281584978103638</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>alltoallw1</NAME>
> <NP>10</NP>
> <TIME>0.220078945159912</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>alltoallw2</NAME>
> <NP>10</NP>
> <TIME>0.226855039596558</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>alltoallw_zeros</NAME>
> <NP>1</NP>
> <TIME>0.0692718029022217</TIME>
> </MPITEST>
> <MPITEST>
> <NP>2</NP>
> <TIME>0.0946609973907471</TIME>
> </MPITEST>
> <MPITEST>
> <NP>5</NP>
> <TIME>0.139060020446777</TIME>
> </MPITEST>
> <MPITEST>
> <NP>8</NP>
> <TIME>0.17607307434082</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allgather2</NAME>
> <NP>10</NP>
> <TIME>0.249645233154297</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allgather3</NAME>
> <NP>10</NP>
> <TIME>0.24416708946228</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allgatherv2</NAME>
> <NP>10</NP>
> <TIME>0.260741949081421</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allgatherv3</NAME>
> <NP>10</NP>
> <TIME>0.274555921554565</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allgatherv4</NAME>
> <NP>4</NP>
> <TIME>0.487081050872803</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allgather_struct</NAME>
> <NP>10</NP>
> <TIME>0.218855857849121</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bcasttest</NAME>
> <NP>4</NP>
> <TIME>0.221165895462036</TIME>
> </MPITEST>
> <MPITEST>
> <NP>8</NP>
> <TIME>0.372392177581787</TIME>
> </MPITEST>
> <MPITEST>
> <NP>10</NP>
> <TIME>0.358638048171997</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bcast_full</NAME>
> <NP>4</NP>
> <TIME>237.555271863937</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bcast_min_datatypes</NAME>
> <NP>10</NP>
> <TIME>204.032071828842</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bcast_comm_world</NAME>
> <NP>10</NP>
> <TIME>113.614319801331</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bcastzerotype</NAME>
> <NP>1</NP>
> <TIME>0.0699419975280762</TIME>
> </MPITEST>
> <MPITEST>
> <NP>4</NP>
> <TIME>0.120114088058472</TIME>
> </MPITEST>
> <MPITEST>
> <NP>5</NP>
> <TIME>0.137501955032349</TIME>
> </MPITEST>
> <MPITEST>
> <NP>10</NP>
> <TIME>0.19035005569458</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll2</NAME>
> <NP>5</NP>
> <TIME>0.131021022796631</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll3</NAME>
> <NP>5</NP>
> <TIME>0.141463994979858</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll4</NAME>
> <NP>4</NP>
> <TIME>0.124334812164307</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll5</NAME>
> <NP>4</NP>
> <TIME>0.121370077133179</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll6</NAME>
> <NP>5</NP>
> <TIME>0.140211820602417</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll7</NAME>
> <NP>1</NP>
> <TIME>0.0762109756469727</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll7</NAME>
> <NP>2</NP>
> <TIME>0.0849668979644775</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll7</NAME>
> <NP>5</NP>
> <TIME>0.141697883605957</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll8</NAME>
> <NP>4</NP>
> <TIME>0.12468409538269</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll9</NAME>
> <NP>4</NP>
> <TIME>0.137745141983032</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll10</NAME>
> <NP>4</NP>
> <TIME>0.11351203918457</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll11</NAME>
> <NP>4</NP>
> <TIME>0.126526832580566</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll12</NAME>
> <NP>4</NP>
> <TIME>0.119683980941772</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>coll13</NAME>
> <NP>4</NP>
> <TIME>0.118872880935669</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>longuser</NAME>
> <NP>4</NP>
> <TIME>0.136920928955078</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>redscat</NAME>
> <NP>4</NP>
> <TIME>0.128253936767578</TIME>
> </MPITEST>
> <MPITEST>
> <NP>6</NP>
> <TIME>0.147740125656128</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>redscat2</NAME>
> <NP>4</NP>
> <TIME>0.126682043075562</TIME>
> </MPITEST>
> <MPITEST>
> <NP>5</NP>
> <TIME>0.135924100875854</TIME>
> </MPITEST>
> <MPITEST>
> <NP>10</NP>
> <TIME>0.219542980194092</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>redscat3</NAME>
> <NP>8</NP>
> <TIME>0.227970123291016</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>redscatinter</NAME>
> <NP>8</NP>
> <TIME>0.195115089416504</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>red_scat_block</NAME>
> <NP>4</NP>
> <TIME>0.103677034378052</TIME>
> </MPITEST>
> <MPITEST>
> <NP>5</NP>
> <TIME>0.128539085388184</TIME>
> </MPITEST>
> <MPITEST>
> <NP>8</NP>
> <TIME>0.183477878570557</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>red_scat_block2</NAME>
> <NP>4</NP>
> <TIME>0.125955104827881</TIME>
> </MPITEST>
> <MPITEST>
> <NP>5</NP>
> <TIME>0.138259887695312</TIME>
> </MPITEST>
> <MPITEST>
> <NP>10</NP>
> <TIME>0.213595867156982</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>redscatblk3</NAME>
> <NP>8</NP>
> <TIME>0.20882511138916</TIME>
> </MPITEST>
> <MPITEST>
> <NP>10</NP>
> <TIME>0.250569105148315</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>redscatbkinter</NAME>
> <NP>8</NP>
> <TIME>0.201464891433716</TIME>
> </MPITEST>
> <MPITEST>
> <NP>10</NP>
> <TIME>0.244191884994507</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>scantst</NAME>
> <NP>4</NP>
> <TIME>0.118768930435181</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>exscan</NAME>
> <NP>10</NP>
> <TIME>0.326385974884033</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>exscan2</NAME>
> <NP>5</NP>
> <TIME>0.134656190872192</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>gather</NAME>
> <NP>4</NP>
> <TIME>0.139287948608398</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>gather2</NAME>
> <NP>4</NP>
> <TIME>0.134318113327026</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>scattern</NAME>
> <NP>4</NP>
> <TIME>0.124268054962158</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>scatter2</NAME>
> <NP>4</NP>
> <TIME>0.109872817993164</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>scatter3</NAME>
> <NP>4</NP>
> <TIME>0.122224092483521</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>scatterv</NAME>
> <NP>4</NP>
> <TIME>0.137815952301025</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icbcast</NAME>
> <NP>4</NP>
> <TIME>0.132683992385864</TIME>
> </MPITEST>
> <MPITEST>
> <NP>10</NP>
> <TIME>0.245707988739014</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icallreduce</NAME>
> <NP>5</NP>
> <TIME>0.16129207611084</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.200841188430786</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icreduce</NAME>
> <NP>5</NP>
> <TIME>0.141062021255493</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.193809032440186</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icscatter</NAME>
> <NP>5</NP>
> <TIME>0.15556788444519</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.204313993453979</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icgather</NAME>
> <NP>5</NP>
> <TIME>0.153489828109741</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.200143098831177</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icallgather</NAME>
> <NP>5</NP>
> <TIME>0.188021183013916</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.261936902999878</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icbarrier</NAME>
> <NP>5</NP>
> <TIME>0.147365093231201</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.18481707572937</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icallgatherv</NAME>
> <NP>5</NP>
> <TIME>0.180018186569214</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.267714977264404</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icgatherv</NAME>
> <NP>5</NP>
> <TIME>0.160311937332153</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.217398881912231</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icscatterv</NAME>
> <NP>5</NP>
> <TIME>0.152240991592407</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.199938058853149</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icalltoall</NAME>
> <NP>5</NP>
> <TIME>0.195499897003174</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.260174989700317</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icalltoallv</NAME>
> <NP>5</NP>
> <TIME>0.139393091201782</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.185115814208984</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icalltoallw</NAME>
> <NP>5</NP>
> <TIME>0.138139009475708</TIME>
> </MPITEST>
> <MPITEST>
> <NP>7</NP>
> <TIME>0.196478128433228</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>opland</NAME>
> <NP>4</NP>
> <TIME>0.124415159225464</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>oplor</NAME>
> <NP>4</NP>
> <TIME>0.123144149780273</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>oplxor</NAME>
> <NP>4</NP>
> <TIME>0.125312089920044</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>oplxor</NAME>
> <NP>5</NP>
> <TIME>0.137664794921875</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>opband</NAME>
> <NP>4</NP>
> <TIME>0.127947807312012</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>opbor</NAME>
> <NP>4</NP>
> <TIME>0.126459836959839</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>opbxor</NAME>
> <NP>4</NP>
> <TIME>0.125327110290527</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>opbxor</NAME>
> <NP>5</NP>
> <TIME>0.13037109375</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>opprod</NAME>
> <NP>5</NP>
> <TIME>0.140099048614502</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>opprod</NAME>
> <NP>6</NP>
> <TIME>0.151695013046265</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>opsum</NAME>
> <NP>4</NP>
> <TIME>0.126162052154541</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>opmin</NAME>
> <NP>4</NP>
> <TIME>0.125760078430176</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>opminloc</NAME>
> <NP>4</NP>
> <TIME>0.12773609161377</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>opmax</NAME>
> <NP>5</NP>
> <TIME>0.138228893280029</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>opmaxloc</NAME>
> <NP>5</NP>
> <TIME>0.136422872543335</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>uoplong</NAME>
> <NP>4</NP>
> <TIME>0.942717790603638</TIME>
> </MPITEST>
> <MPITEST>
> <NP>11</NP>
> <TIME>1.02425718307495</TIME>
> </MPITEST>
> <MPITEST>
> <NP>16</NP>
> <TIME>1.18810701370239</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nonblocking</NAME>
> <NP>4</NP>
> <TIME>0.127158880233765</TIME>
> </MPITEST>
> <MPITEST>
> <NP>5</NP>
> <TIME>0.160429954528809</TIME>
> </MPITEST>
> <MPITEST>
> <NP>10</NP>
> <TIME>0.227702140808105</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nonblocking2</NAME>
> <NP>1</NP>
> <TIME>0.0700211524963379</TIME>
> </MPITEST>
> <MPITEST>
> <NP>4</NP>
> <TIME>0.124064207077026</TIME>
> </MPITEST>
> <MPITEST>
> <NP>5</NP>
> <TIME>0.153284072875977</TIME>
> </MPITEST>
> <MPITEST>
> <NP>10</NP>
> <TIME>0.226805925369263</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nonblocking3</NAME>
> <NP>1</NP>
> <TIME>0.925456047058105</TIME>
> </MPITEST>
> <MPITEST>
> <NP>4</NP>
> <TIME>7.83766388893127</TIME>
> </MPITEST>
> <MPITEST>
> <NP>5</NP>
> <TIME>10.1563260555267</TIME>
> </MPITEST>
> <MPITEST>
> <NP>10</NP>
> <TIME>29.6967561244965</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iallred</NAME>
> <NP>2</NP>
> <TIME>0.0799648761749268</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ibarrier</NAME>
> <NP>2</NP>
> <TIME>0.0987520217895508</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nballtoall1</NAME>
> <NP>8</NP>
> <TIME>0.432682991027832</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbcoll2</NAME>
> <NP>5</NP>
> <TIME>0.129651069641113</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbredscat</NAME>
> <NP>4</NP>
> <TIME>0.117622852325439</TIME>
> </MPITEST>
> <MPITEST>
> <NP>8</NP>
> <TIME>0.167437076568604</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbredscat3</NAME>
> <NP>8</NP>
> <TIME>0.216601848602295</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbredscatinter</NAME>
> <NP>8</NP>
> <TIME>0.191687107086182</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicbcast</NAME>
> <NP>8</NP>
> <TIME>0.19636607170105</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicallreduce</NAME>
> <NP>8</NP>
> <TIME>0.232084035873413</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicreduce</NAME>
> <NP>8</NP>
> <TIME>0.213788986206055</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicscatter</NAME>
> <NP>8</NP>
> <TIME>0.212414026260376</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicgather</NAME>
> <NP>8</NP>
> <TIME>0.22527289390564</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicallgather</NAME>
> <NP>8</NP>
> <TIME>0.295198917388916</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicbarrier</NAME>
> <NP>8</NP>
> <TIME>0.193183183670044</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicallgatherv</NAME>
> <NP>8</NP>
> <TIME>0.288758039474487</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicgatherv</NAME>
> <NP>8</NP>
> <TIME>0.218052864074707</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicscatterv</NAME>
> <NP>8</NP>
> <TIME>0.23921799659729</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicalltoall</NAME>
> <NP>8</NP>
> <TIME>0.299579858779907</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicalltoallv</NAME>
> <NP>8</NP>
> <TIME>0.174806118011475</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nbicalltoallw</NAME>
> <NP>8</NP>
> <TIME>0.19091796875</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>neighb_coll</NAME>
> <NP>4</NP>
> <TIME>0.117097854614258</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dup</NAME>
> <NP>2</NP>
> <WORKDIR>./comm</WORKDIR>
> <TIME>0.0782568454742432</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dupic</NAME>
> <NP>4</NP>
> <TIME>0.133162021636963</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commcreate1</NAME>
> <NP>8</NP>
> <TIME>0.183318853378296</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commname</NAME>
> <NP>4</NP>
> <TIME>0.120983839035034</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ic1</NAME>
> <NP>4</NP>
> <TIME>0.116915941238403</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ic2</NAME>
> <NP>33</NP>
> <TIME>0.537627935409546</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icgroup</NAME>
> <NP>8</NP>
> <TIME>0.194090127944946</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icm</NAME>
> <NP>8</NP>
> <TIME>0.185853958129883</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icsplit</NAME>
> <NP>8</NP>
> <TIME>0.195549964904785</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iccreate</NAME>
> <NP>8</NP>
> <TIME>0.197706937789917</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ctxalloc</NAME>
> <NP>2</NP>
> <TIME>8.10721492767334</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ctxsplit</NAME>
> <NP>4</NP>
> <TIME>6.42147898674011</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cmfree</NAME>
> <NP>4</NP>
> <TIME>0.348598957061768</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cmsplit</NAME>
> <NP>4</NP>
> <TIME>0.11878490447998</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cmsplit2</NAME>
> <NP>12</NP>
> <TIME>0.264687061309814</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>probe_intercomm</NAME>
> <NP>2</NP>
> <TIME>0.0858359336853027</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cmsplit_type</NAME>
> <NP>4</NP>
> <TIME>0.140922069549561</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_create_group</NAME>
> <NP>4</NP>
> <TIME>0.128362894058228</TIME>
> </MPITEST>
> <MPITEST>
> <NP>8</NP>
> <TIME>0.192928075790405</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_group_half</NAME>
> <NP>2</NP>
> <TIME>0.0887808799743652</TIME>
> </MPITEST>
> <MPITEST>
> <NP>4</NP>
> <TIME>0.123296976089478</TIME>
> </MPITEST>
> <MPITEST>
> <NP>8</NP>
> <TIME>0.199354887008667</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_group_rand</NAME>
> <NP>2</NP>
> <TIME>0.0921211242675781</TIME>
> </MPITEST>
> <MPITEST>
> <NP>4</NP>
> <TIME>0.117161989212036</TIME>
> </MPITEST>
> <MPITEST>
> <NP>8</NP>
> <TIME>0.19904899597168</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_idup</NAME>
> <NP>2</NP>
> <TIME>0.0935559272766113</TIME>
> </MPITEST>
> <MPITEST>
> <NP>4</NP>
> <TIME>0.116266965866089</TIME>
> </MPITEST>
> <MPITEST>
> <NP>9</NP>
> <TIME>0.214816093444824</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_idup_mul</NAME>
> <NP>2</NP>
> <TIME>0.085705041885376</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_idup_overlap</NAME>
> <NP>2</NP>
> <TIME>0.0905251502990723</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_idup_iallreduce</NAME>
> <NP>6</NP>
> <TIME>0.165296077728271</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_idup_nb</NAME>
> <NP>6</NP>
> <TIME>0.214349985122681</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_idup_isend</NAME>
> <NP>6</NP>
> <TIME>0.170833110809326</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_idup_comm</NAME>
> <NP>6</NP>
> <TIME>0.148485898971558</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_idup_comm2</NAME>
> <NP>6</NP>
> <TIME>0.153411149978638</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dup_with_info</NAME>
> <NP>2</NP>
> <TIME>0.0838470458984375</TIME>
> </MPITEST>
> <MPITEST>
> <NP>4</NP>
> <TIME>0.126369953155518</TIME>
> </MPITEST>
> <MPITEST>
> <NP>9</NP>
> <TIME>0.191745042800903</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_info</NAME>
> <NP>6</NP>
> <TIME>0.152220010757446</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_create_group_idup</NAME>
> <NP>4</NP>
> <TIME>0.11858081817627</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>contents</NAME>
> <NP>1</NP>
> <WORKDIR>./datatype</WORKDIR>
> <TIME>0.0518519878387451</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>gaddress</NAME>
> <NP>1</NP>
> <TIME>0.0679018497467041</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lbub</NAME>
> <NP>1</NP>
> <TIME>0.073173999786377</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>localpack</NAME>
> <NP>1</NP>
> <TIME>0.0739409923553467</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>simple_pack</NAME>
> <NP>1</NP>
> <TIME>0.0733940601348877</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>simple_pack_external</NAME>
> <NP>1</NP>
> <TIME>0.0753941535949707</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>simple_pack_external2</NAME>
> <NP>1</NP>
> <TIME>0.0726890563964844</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>transpose_pack</NAME>
> <NP>1</NP>
> <TIME>0.0726950168609619</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>slice_pack</NAME>
> <NP>1</NP>
> <TIME>0.0787649154663086</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>struct_pack</NAME>
> <NP>1</NP>
> <TIME>0.0830490589141846</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>structpack2</NAME>
> <NP>1</NP>
> <TIME>0.0709002017974854</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typecommit</NAME>
> <NP>1</NP>
> <TIME>0.0727720260620117</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typename</NAME>
> <NP>1</NP>
> <TIME>0.0702469348907471</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typefree</NAME>
> <NP>1</NP>
> <TIME>0.0678040981292725</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>zeroparms</NAME>
> <NP>1</NP>
> <TIME>0.0678410530090332</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>concurrent_irecv</NAME>
> <NP>3</NP>
> <TIME>0.104927062988281</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>getpartelm</NAME>
> <NP>2</NP>
> <TIME>0.0954110622406006</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>tresized</NAME>
> <NP>2</NP>
> <TIME>0.0883700847625732</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>tresized2</NAME>
> <NP>2</NP>
> <TIME>0.0908510684967041</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendrecvt2</NAME>
> <NP>2</NP>
> <TIME>0.0948801040649414</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendrecvt4</NAME>
> <NP>2</NP>
> <TIME>0.0939040184020996</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>tmatchsize</NAME>
> <NP>1</NP>
> <TIME>0.0722060203552246</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>tfree</NAME>
> <NP>2</NP>
> <TIME>0.0887010097503662</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typelb</NAME>
> <NP>1</NP>
> <TIME>0.0684161186218262</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>contigstruct</NAME>
> <NP>1</NP>
> <TIME>0.0761301517486572</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>struct_zero_count</NAME>
> <NP>1</NP>
> <TIME>0.0738060474395752</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>blockindexed_zero_count</NAME>
> <NP>1</NP>
> <TIME>0.0721199512481689</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>blockindexed_misc</NAME>
> <NP>1</NP>
> <TIME>0.0731098651885986</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>indexed_misc</NAME>
> <NP>1</NP>
> <TIME>0.0717308521270752</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>subarray_pack</NAME>
> <NP>1</NP>
> <TIME>0.0743038654327393</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>subarray</NAME>
> <NP>2</NP>
> <TIME>0.0849330425262451</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>darray_pack</NAME>
> <NP>1</NP>
> <TIME>0.0715959072113037</TIME>
> </MPITEST>
> <MPITEST>
> <NP>9</NP>
> <TIME>0.212347030639648</TIME>
> </MPITEST>
> <MPITEST>
> <NP>72</NP>
> <TIME>1.08390283584595</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>darray_cyclic</NAME>
> <NP>12</NP>
> <TIME>0.235510110855103</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>pairtype_size_extent</NAME>
> <NP>1</NP>
> </MPITEST>
> <MPITEST>
> <NAME>simple_commit</NAME>
> <NP>1</NP>
> <TIME>0.0734419822692871</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>simple_size_extent</NAME>
> <NP>1</NP>
> <TIME>0.0729100704193115</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>struct_no_real_types</NAME>
> <NP>1</NP>
> <TIME>0.0765380859375</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>struct_empty_el</NAME>
> <NP>1</NP>
> <TIME>0.0716650485992432</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>contig_zero_count</NAME>
> <NP>1</NP>
> <TIME>0.0820720195770264</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>simple_resized</NAME>
> <NP>1</NP>
> <TIME>0.069688081741333</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>unusual_noncontigs</NAME>
> <NP>1</NP>
> <TIME>0.0711441040039062</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>hindexed_zeros</NAME>
> <NP>1</NP>
> <TIME>0.0743870735168457</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lots_of_types</NAME>
> <NP>1</NP>
> <TIME>0.131277084350586</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_elements_pairtype</NAME>
> <NP>1</NP>
> <TIME>0.0749011039733887</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>unpack</NAME>
> <NP>1</NP>
> <TIME>0.0729990005493164</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>struct_ezhov</NAME>
> <NP>1</NP>
> <TIME>0.074570894241333</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>zeroblks</NAME>
> <NP>1</NP>
> <TIME>0.0709750652313232</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>struct_derived_zeros</NAME>
> <NP>1</NP>
> <TIME>0.0667710304260254</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>struct_verydeep</NAME>
> <NP>1</NP>
> <TIME>0.0734720230102539</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_elements</NAME>
> <NP>1</NP>
> <TIME>0.0744438171386719</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>hindexed_block</NAME>
> <NP>1</NP>
> <TIME>0.0738170146942139</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>hindexed_block_contents</NAME>
> <NP>1</NP>
> <TIME>0.087007999420166</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>vecblklen</NAME>
> <NP>1</NP>
> <TIME>0.0714049339294434</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>hvecblklen</NAME>
> <NP>1</NP>
> <TIME>0.066105842590332</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>longdouble</NAME>
> <NP>1</NP>
> <TIME>0.0721399784088135</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dataalign</NAME>
> <NP>2</NP>
> <TIME>0.0868840217590332</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cxx_types</NAME>
> <NP>1</NP>
> <TIME>0.0704920291900635</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>adderr</NAME>
> <NP>1</NP>
> <WORKDIR>./errhan</WORKDIR>
> <TIME>0.0726661682128906</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commcall</NAME>
> <NP>2</NP>
> <TIME>0.20556902885437</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>errfatal</NAME>
> <NP>1</NP>
> <TIME>0</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>predef_eh</NAME>
> <NP>1</NP>
> <TIME>0.0716259479522705</TIME>
> </MPITEST>
> <MPITEST>
> <NP>2</NP>
> <TIME>0.0876369476318359</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>errstring2</NAME>
> <NP>1</NP>
> <TIME>0.0732748508453369</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dynamic_errcode_predefined_errclass</NAME>
> <NP>1</NP>
> <TIME>0.0625460147857666</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>groupcreate</NAME>
> <NP>4</NP>
> <WORKDIR>./group</WORKDIR>
> <TIME>0.122853994369507</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>grouptest</NAME>
> <NP>8</NP>
> <TIME>0.188297033309937</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>grouptest2</NAME>
> <NP>4</NP>
> <TIME>0.119318008422852</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>groupnullincl</NAME>
> <NP>4</NP>
> <TIME>0.123502016067505</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>gtranks</NAME>
> <NP>8</NP>
> <TIME>0.180782079696655</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>gtranksperf</NAME>
> <NP>20</NP>
> <TIME>10.3509202003479</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infodup</NAME>
> <NP>1</NP>
> <WORKDIR>./info</WORKDIR>
> <TIME>0.0648670196533203</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infodel</NAME>
> <NP>1</NP>
> <TIME>0.0716099739074707</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infovallen</NAME>
> <NP>1</NP>
> <TIME>0.075145959854126</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infoorder</NAME>
> <NP>1</NP>
> <TIME>0.0693728923797607</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infomany</NAME>
> <NP>1</NP>
> <TIME>0.177711963653564</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infomany2</NAME>
> <NP>1</NP>
> <TIME>0.196565866470337</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infotest</NAME>
> <NP>1</NP>
> <TIME>0.0709760189056396</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infoget</NAME>
> <NP>1</NP>
> <TIME>0.0699918270111084</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infoenv</NAME>
> <NP>1</NP>
> <TIME>0.070889949798584</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>exitst1</NAME>
> <NP>2</NP>
> <WORKDIR>./init</WORKDIR>
> <TIME>0</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>exitst2</NAME>
> <NP>4</NP>
> <TIME>0</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>initstat</NAME>
> <NP>1</NP>
> <TIME>0.0726838111877441</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>timeout</NAME>
> <NP>2</NP>
> <TIME>0</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>version</NAME>
> <NP>1</NP>
> <TIME>0.0764679908752441</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>finalized</NAME>
> <NP>1</NP>
> <TIME>0.0708901882171631</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrself</NAME>
> <NP>1</NP>
> <TIME>0.0723800659179688</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>library_version</NAME>
> <NP>1</NP>
> <TIME>0.0717868804931641</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>mpi_t_str</NAME>
> <NP>1</NP>
> <WORKDIR>./mpi_t</WORKDIR>
> <TIME>0.073246955871582</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>mpit_vars</NAME>
> <NP>1</NP>
> <TIME>0.0707149505615234</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cvarwrite</NAME>
> <NP>1</NP>
> <TIME>0.0755929946899414</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>getindex</NAME>
> <NP>1</NP>
> <TIME>0.0733699798583984</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendrecv1</NAME>
> <NP>4</NP>
> <WORKDIR>./pt2pt</WORKDIR>
> <TIME>64.6136031150818</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendrecv2</NAME>
> <NP>2</NP>
> <TIME>0.0862419605255127</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendrecv3</NAME>
> <NP>2</NP>
> <TIME>4.09942078590393</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendflood</NAME>
> <NP>8</NP>
> <TIME>6.86659502983093</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendself</NAME>
> <NP>1</NP>
> <TIME>8.03027200698853</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendall</NAME>
> <NP>4</NP>
> <TIME>0.135864019393921</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>anyall</NAME>
> <NP>2</NP>
> <TIME>0.0946071147918701</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>eagerdt</NAME>
> <NP>2</NP>
> <TIME>2.08347797393799</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>pingping</NAME>
> <NP>2</NP>
> <TIME>75.9698581695557</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bottom</NAME>
> <NP>2</NP>
> <TIME>0.0805349349975586</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bsend1</NAME>
> <NP>1</NP>
> <TIME>0.0738909244537354</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bsend2</NAME>
> <NP>1</NP>
> <TIME>0.0733180046081543</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bsend3</NAME>
> <NP>1</NP>
> <TIME>0.0739729404449463</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bsend4</NAME>
> <NP>1</NP>
> <TIME>0.0777778625488281</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bsend5</NAME>
> <NP>4</NP>
> <TIME>0.122244119644165</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bsendalign</NAME>
> <NP>2</NP>
> <TIME>0.0936338901519775</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bsendpending</NAME>
> <NP>2</NP>
> <TIME>8.09166717529297</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>isendself</NAME>
> <NP>1</NP>
> <TIME>0.0698540210723877</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>isendirecv</NAME>
> <NP>10</NP>
> <TIME>0.204400062561035</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bsendfrag</NAME>
> <NP>2</NP>
> <TIME>0.0871560573577881</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icsend</NAME>
> <NP>4</NP>
> <TIME>0.125166893005371</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rqstatus</NAME>
> <NP>2</NP>
> <TIME>0.0821971893310547</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rqfreeb</NAME>
> <NP>4</NP>
> <TIME>0.117895841598511</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>greq1</NAME>
> <NP>1</NP>
> <TIME>0.0676388740539551</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>probe_unexp</NAME>
> <NP>4</NP>
> <TIME>0.148428916931152</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>probenull</NAME>
> <NP>1</NP>
> <TIME>0.0715720653533936</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rcancel</NAME>
> <NP>2</NP>
> <TIME>0.0850191116333008</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cancelanysrc</NAME>
> <NP>2</NP>
> <TIME>0.0905759334564209</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>isendselfprobe</NAME>
> <NP>1</NP>
> <TIME>0.0694038867950439</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>inactivereq</NAME>
> <NP>1</NP>
> <TIME>0.0752739906311035</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>waittestnull</NAME>
> <NP>1</NP>
> <TIME>0.0728249549865723</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>waitany_null</NAME>
> <NP>1</NP>
> <TIME>0.0700840950012207</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>large_message</NAME>
> <NP>3</NP>
> <TIME>12.6185750961304</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>mprobe</NAME>
> <NP>2</NP>
> <TIME>0.0961830615997314</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>big_count_status</NAME>
> <NP>1</NP>
> <TIME>0.0702049732208252</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>many_isend</NAME>
> <NP>3</NP>
> <TIME>0.101047992706299</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>manylmt</NAME>
> <NP>2</NP>
> <TIME>1.27871894836426</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>huge_underflow</NAME>
> <NP>2</NP>
> <TIME>0.0878100395202637</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>huge_anysrc</NAME>
> <NP>2</NP>
> <TIME>1.45319104194641</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>huge_dupcomm</NAME>
> <NP>2</NP>
> <TIME>0.213444948196411</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dtype_send</NAME>
> <NP>2</NP>
> <TIME>0.0921320915222168</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>recv_any</NAME>
> <NP>2</NP>
> <TIME>0.0866811275482178</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>irecv_any</NAME>
> <NP>2</NP>
> <TIME>0.0894119739532471</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winname</NAME>
> <NP>2</NP>
> <WORKDIR>./rma</WORKDIR>
> <TIME>0.0907289981842041</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allocmem</NAME>
> <NP>2</NP>
> <TIME>0.0917508602142334</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>putfence1</NAME>
> <NP>2</NP>
> <TIME>79.0367398262024</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>putfidx</NAME>
> <NP>4</NP>
> <TIME>0.121719121932983</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>getfence1</NAME>
> <NP>2</NP>
> <TIME>87.5063908100128</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>accfence1</NAME>
> <NP>4</NP>
> <TIME>86.2915349006653</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>adlb_mimic1</NAME>
> <NP>3</NP>
> <TIME>0.344286918640137</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>accfence2</NAME>
> <NP>4</NP>
> <TIME>0.150130033493042</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>putpscw1</NAME>
> <NP>4</NP>
> <TIME>85.3216278553009</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>accpscw1</NAME>
> <NP>4</NP>
> <TIME>85.4276759624481</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>getgroup</NAME>
> <NP>4</NP>
> <TIME>0.127645015716553</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>transpose1</NAME>
> <NP>2</NP>
> <TIME>0.102123022079468</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>transpose2</NAME>
> <NP>2</NP>
> <TIME>0.0794579982757568</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>transpose3</NAME>
> <NP>2</NP>
> <TIME>0.0868699550628662</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>transpose3_shm</NAME>
> <NP>2</NP>
> <TIME>0.0835921764373779</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>transpose5</NAME>
> <NP>2</NP>
> <TIME>0.381050109863281</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>transpose6</NAME>
> <NP>1</NP>
> <TIME>0.0696661472320557</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>transpose7</NAME>
> <NP>2</NP>
> <TIME>0.108606100082397</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test1</NAME>
> <NP>2</NP>
> <TIME>0.0820291042327881</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test2</NAME>
> <NP>2</NP>
> <TIME>0.090878963470459</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test2_shm</NAME>
> <NP>2</NP>
> <TIME>0.0879027843475342</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test3</NAME>
> <NP>2</NP>
> <TIME>0.118033170700073</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test3_shm</NAME>
> <NP>2</NP>
> <TIME>0.120600938796997</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test4</NAME>
> <NP>2</NP>
> <TIME>0.100176095962524</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test5</NAME>
> <NP>2</NP>
> <TIME>0.106035947799683</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lockcontention</NAME>
> <NP>3</NP>
> <TIME>0.109182834625244</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lockcontention2</NAME>
> <NP>4</NP>
> <TIME>0.256263017654419</TIME>
> </MPITEST>
> <MPITEST>
> <NP>8</NP>
> <TIME>0.463616132736206</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lockcontention3</NAME>
> <NP>8</NP>
> <TIME>0.168402194976807</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lockopts</NAME>
> <NP>2</NP>
> <TIME>0.0828268527984619</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lock_dt</NAME>
> <NP>2</NP>
> <TIME>66.2305710315704</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lock_dt_flush</NAME>
> <NP>2</NP>
> <TIME>64.6720299720764</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lock_dt_flushlocal</NAME>
> <NP>2</NP>
> <TIME>68.6412959098816</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lockall_dt</NAME>
> <NP>4</NP>
> <TIME>163.841109991074</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lockall_dt_flush</NAME>
> <NP>4</NP>
> <TIME>161.186873912811</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lockall_dt_flushall</NAME>
> <NP>4</NP>
> <TIME>157.364437103271</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lockall_dt_flushlocal</NAME>
> <NP>4</NP>
> <TIME>172.540486097336</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lockall_dt_flushlocalall</NAME>
> <NP>4</NP>
> <TIME>169.922899961472</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lock_contention_dt</NAME>
> <NP>4</NP>
> <TIME>161.577991962433</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>transpose4</NAME>
> <NP>2</NP>
> <TIME>0.0793728828430176</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fetchandadd</NAME>
> <NP>7</NP>
> <TIME>0.164403915405273</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fetchandadd_tree</NAME>
> <NP>7</NP>
> <TIME>0.17205810546875</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>wintest</NAME>
> <NP>2</NP>
> <TIME>0.082003116607666</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>wintest_shm</NAME>
> <NP>2</NP>
> <TIME>0.0887908935546875</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>contig_displ</NAME>
> <NP>1</NP>
> <TIME>0.0723450183868408</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test1_am</NAME>
> <NP>2</NP>
> <TIME>0.0843410491943359</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test2_am</NAME>
> <NP>2</NP>
> <TIME>0.0890600681304932</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test2_am_shm</NAME>
> <NP>2</NP>
> <TIME>0.092106819152832</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test3_am</NAME>
> <NP>2</NP>
> <TIME>0.118459939956665</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test3_am_shm</NAME>
> <NP>2</NP>
> <TIME>0.122542142868042</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test4_am</NAME>
> <NP>2</NP>
> <TIME>0.0935521125793457</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test5_am</NAME>
> <NP>2</NP>
> <TIME>0.108788967132568</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fetchandadd_am</NAME>
> <NP>7</NP>
> <TIME>0.169721841812134</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fetchandadd_tree_am</NAME>
> <NP>7</NP>
> <TIME>0.176353931427002</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>accfence2_am</NAME>
> <NP>4</NP>
> <TIME>0.126887083053589</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>test1_dt</NAME>
> <NP>2</NP>
> <TIME>0.0863959789276123</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nullpscw</NAME>
> <NP>7</NP>
> <TIME>0.16736102104187</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nullpscw_shm</NAME>
> <NP>7</NP>
> <TIME>0.171932935714722</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrorderwin</NAME>
> <NP>1</NP>
> <TIME>0.0706660747528076</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>wincall</NAME>
> <NP>2</NP>
> <TIME>0.155297040939331</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseattrwin</NAME>
> <NP>1</NP>
> <TIME>0.0719799995422363</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fkeyvalwin</NAME>
> <NP>1</NP>
> <TIME>0.0724470615386963</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>selfrma</NAME>
> <NP>1</NP>
> <TIME>0.0736701488494873</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>mixedsync</NAME>
> <NP>4</NP>
> <TIME>0.124660015106201</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>epochtest</NAME>
> <NP>4</NP>
> <TIME>212.524266004562</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>locknull</NAME>
> <NP>2</NP>
> <TIME>0.0898258686065674</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rmanull</NAME>
> <NP>2</NP>
> <TIME>0.0878329277038574</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rmazero</NAME>
> <NP>2</NP>
> <TIME>0.0926549434661865</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>strided_acc_indexed</NAME>
> <NP>2</NP>
> <TIME>0.0870609283447266</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>strided_acc_onelock</NAME>
> <NP>2</NP>
> <TIME>0.220396995544434</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>strided_acc_subarray</NAME>
> <NP>2</NP>
> <TIME>0.140377998352051</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>strided_get_indexed</NAME>
> <NP>2</NP>
> <TIME>0.0880918502807617</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>strided_putget_indexed</NAME>
> <NP>4</NP>
> <TIME>0.126231908798218</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>strided_putget_indexed_shared</NAME>
> <NP>4</NP>
> <TIME>0.109392166137695</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>strided_getacc_indexed</NAME>
> <NP>4</NP>
> <TIME>0.12160587310791</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>strided_getacc_indexed_shared</NAME>
> <NP>4</NP>
> <TIME>0.122956991195679</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>window_creation</NAME>
> <NP>2</NP>
> <TIME>0.238745927810669</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>contention_put</NAME>
> <NP>4</NP>
> <TIME>0.359392166137695</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>contention_putget</NAME>
> <NP>4</NP>
> <TIME>0.640354156494141</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>put_base</NAME>
> <NP>2</NP>
> <TIME>0.208927154541016</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>put_bottom</NAME>
> <NP>2</NP>
> <TIME>0.167581081390381</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_flavors</NAME>
> <NP>4</NP>
> <TIME>0.117844820022583</TIME>
> </MPITEST>
> <MPITEST>
> <NP>3</NP>
> <TIME>0.104053974151611</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>manyrma2</NAME>
> <NP>2</NP>
> <TIME>3.36715888977051</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>manyrma2_shm</NAME>
> <NP>2</NP>
> <TIME>3.55549311637878</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>manyrma3</NAME>
> <NP>2</NP>
> <TIME>0.0906860828399658</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_shared</NAME>
> <NP>4</NP>
> <TIME>0.120254993438721</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_shared_create_allocshm</NAME>
> <NP>4</NP>
> <TIME>0.112033128738403</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_shared_create_no_allocshm</NAME>
> <NP>4</NP>
> <TIME>0.120121002197266</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_shared_noncontig</NAME>
> <NP>4</NP>
> <TIME>0.123739957809448</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_shared_noncontig_put</NAME>
> <NP>4</NP>
> <TIME>0.128467082977295</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_zero</NAME>
> <NP>4</NP>
> <TIME>0.123021125793457</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_dynamic_acc</NAME>
> <NP>4</NP>
> <TIME>0.132023096084595</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_acc_local</NAME>
> <NP>1</NP>
> <TIME>0.0734760761260986</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>linked_list</NAME>
> <NP>4</NP>
> <TIME>0.140550136566162</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>linked_list_fop</NAME>
> <NP>4</NP>
> <TIME>0.137847900390625</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>compare_and_swap</NAME>
> <NP>4</NP>
> <TIME>0.142489910125732</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fetch_and_op_char</NAME>
> <NP>4</NP>
> <TIME>0.182651996612549</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fetch_and_op_short</NAME>
> <NP>4</NP>
> <TIME>0.191374063491821</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fetch_and_op_int</NAME>
> <NP>4</NP>
> <TIME>0.191785097122192</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fetch_and_op_long</NAME>
> <NP>4</NP>
> <TIME>0.181775093078613</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fetch_and_op_double</NAME>
> <NP>4</NP>
> <TIME>0.169083833694458</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fetch_and_op_long_double</NAME>
> <NP>4</NP>
> <TIME>0.177875995635986</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_accumulate_double</NAME>
> <NP>4</NP>
> <TIME>0.316479921340942</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_accumulate_double_derived</NAME>
> <NP>4</NP>
> <TIME>0.365038156509399</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_accumulate_int</NAME>
> <NP>4</NP>
> <TIME>0.291225910186768</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_accumulate_int_derived</NAME>
> <NP>4</NP>
> <TIME>0.326061010360718</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_accumulate_long</NAME>
> <NP>4</NP>
> <TIME>0.306962013244629</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_accumulate_long_derived</NAME>
> <NP>4</NP>
> <TIME>0.352745056152344</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_accumulate_short</NAME>
> <NP>4</NP>
> <TIME>0.2849440574646</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_accumulate_short_derived</NAME>
> <NP>4</NP>
> <TIME>0.336804151535034</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>flush</NAME>
> <NP>4</NP>
> <TIME>0.135915994644165</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>reqops</NAME>
> <NP>4</NP>
> <TIME>0.185104846954346</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>req_example</NAME>
> <NP>4</NP>
> <TIME>0.117877960205078</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>req_example_shm</NAME>
> <NP>4</NP>
> <TIME>0.129901170730591</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rput_local_comp</NAME>
> <NP>2</NP>
> <TIME>0.146147966384888</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>racc_local_comp</NAME>
> <NP>2</NP>
> <TIME>0.16358208656311</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_info</NAME>
> <NP>4</NP>
> <TIME>0.123887062072754</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>linked_list_lockall</NAME>
> <NP>4</NP>
> <TIME>0.136044979095459</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>pscw_ordering</NAME>
> <NP>4</NP>
> <TIME>0.127579927444458</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>pscw_ordering_shm</NAME>
> <NP>4</NP>
> <TIME>0.114877939224243</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>linked_list_bench_lock_all</NAME>
> <NP>4</NP>
> <TIME>0.184492826461792</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>linked_list_bench_lock_excl</NAME>
> <NP>4</NP>
> <TIME>0.24475884437561</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>linked_list_bench_lock_shr</NAME>
> <NP>4</NP>
> <TIME>0.220859050750732</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>linked_list_bench_lock_shr_nocheck</NAME>
> <NP>4</NP>
> <TIME>0.188109874725342</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>mutex_bench</NAME>
> <NP>4</NP>
> <TIME>0.227771997451782</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>mutex_bench_shared</NAME>
> <NP>4</NP>
> <TIME>0.127354860305786</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>mutex_bench_shm</NAME>
> <NP>4</NP>
> <TIME>0.251540899276733</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>mutex_bench_shm_ordered</NAME>
> <NP>4</NP>
> <TIME>0.247223854064941</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rma_contig</NAME>
> <NP>2</NP>
> <TIME>58.2597780227661</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>badrma</NAME>
> <NP>2</NP>
> <TIME>0.0846998691558838</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>acc_loc</NAME>
> <NP>4</NP>
> <TIME>0.126274108886719</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>acc_ordering</NAME>
> <NP>2</NP>
> <TIME>0.0858919620513916</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fence_shm</NAME>
> <NP>2</NP>
> <TIME>0.0852358341217041</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_shared_zerobyte</NAME>
> <NP>4</NP>
> <TIME>0.114665985107422</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_shared_put_flush_get</NAME>
> <NP>4</NP>
> <TIME>0.121641159057617</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_struct</NAME>
> <NP>2</NP>
> <TIME>0.0899059772491455</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>at_complete</NAME>
> <NP>2</NP>
> <TIME>0.368239164352417</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>atomic_rmw_fop</NAME>
> <NP>3</NP>
> <TIME>0.407527923583984</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>atomic_rmw_cas</NAME>
> <NP>3</NP>
> <TIME>1.07837295532227</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>atomic_rmw_gacc</NAME>
> <NP>3</NP>
> <TIME>13.6138298511505</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>atomic_get</NAME>
> <NP>3</NP>
> <TIME>9.27443099021912</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>aint</NAME>
> <NP>2</NP>
> <TIME>0.0799031257629395</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>acc_pairtype</NAME>
> <NP>2</NP>
> <TIME>0.0888400077819824</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>manyget</NAME>
> <NP>2</NP>
> <TIME>3.54855108261108</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>derived_acc_flush_local</NAME>
> <NP>3</NP>
> <TIME>2.65830397605896</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>large_acc_flush_local</NAME>
> <NP>3</NP>
> <TIME>8.43871116638184</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>large_small_acc</NAME>
> <NP>2</NP>
> <TIME>0.0923459529876709</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_shared_put_flush_load</NAME>
> <NP>3</NP>
> <TIME>0.104167938232422</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_shared_acc_flush_load</NAME>
> <NP>3</NP>
> <TIME>0.106745958328247</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_shared_gacc_flush_load</NAME>
> <NP>3</NP>
> <TIME>0.0972640514373779</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_shared_fop_flush_load</NAME>
> <NP>3</NP>
> <TIME>0.103920936584473</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_shared_cas_flush_load</NAME>
> <NP>3</NP>
> <TIME>0.10202693939209</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>put_flush_get</NAME>
> <NP>3</NP>
> <TIME>1.27072501182556</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>acc_flush_get</NAME>
> <NP>3</NP>
> <TIME>1.33259606361389</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>gacc_flush_get</NAME>
> <NP>3</NP>
> <TIME>1.16482996940613</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fop_flush_get</NAME>
> <NP>3</NP>
> <TIME>1.10914516448975</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cas_flush_get</NAME>
> <NP>3</NP>
> <TIME>1.23103594779968</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rget_unlock</NAME>
> <NP>2</NP>
> <TIME>0.0952908992767334</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>overlap_wins_put</NAME>
> <NP>3</NP>
> <TIME>0.10884690284729</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>overlap_wins_acc</NAME>
> <NP>3</NP>
> <TIME>0.105414867401123</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>overlap_wins_gacc</NAME>
> <NP>3</NP>
> <TIME>0.106019973754883</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>overlap_wins_fop</NAME>
> <NP>3</NP>
> <TIME>0.107034206390381</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>overlap_wins_cas</NAME>
> <NP>3</NP>
> <TIME>0.120964050292969</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lock_nested</NAME>
> <NP>3</NP>
> <TIME>0.0986359119415283</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rget_testall</NAME>
> <NP>2</NP>
> <TIME>0.0880789756774902</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>namepub</NAME>
> <NP>2</NP>
> <WORKDIR>./spawn</WORKDIR>
> <TIME>0.0769309997558594</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawn1</NAME>
> <NP>1</NP>
> <TIME>0.158007144927979</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawn2</NAME>
> <NP>1</NP>
> <TIME>0.228478908538818</TIME>
> <STATUS>fail</STATUS>
> <TESTDIFF>
>  No Errors
> Fatal error in MPI_Finalize: Unknown error class, error stack:
> MPI_Finalize(333).........................: MPI_Finalize failed
> MPI_Finalize(252).........................:
> MPID_Finalize(111)........................:
> MPIDI_CH3U_VC_WaitForClose(386)...........: an error occurred while the device was waiting for all open connections to close
> MPIDI_CH3i_Progress_wait(242).............: an error occurred while handling an event returned by MPIDI_CH3I_Sock_Wait()
> MPIDI_CH3I_Progress_handle_sock_event(479):
> MPIDI_CH3I_Socki_handle_read(4013)........: connection failure (set=0,sock=4,errno=104:Connection reset by peer)
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>spawninfo1</NAME>
> <NP>1</NP>
> <TIME>0.146191120147705</TIME>
> <TESTDIFF>
>  No Errors
> MPIDI_CH3I_Socki_handle_read(4013)........: connection failure (set=0,sock=2,errno=104:Connection reset by peer)
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>spawnminfo1</NAME>
> <NP>1</NP>
> <TIME>0.150587797164917</TIME>
> <TESTDIFF>
>  No Errors
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>spawnintra</NAME>
> <NP>1</NP>
> <TIME>0.151432037353516</TIME>
> <TESTDIFF>
>  No Errors
> MPIDI_CH3I_Socki_handle_read(4013)........: connection failure (set=0,sock=1,errno=104:Connection reset by peer)
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NP>2</NP>
> <TIME>0.162929058074951</TIME>
> <TESTDIFF>
>  No Errors
> MPIDI_CH3I_Socki_handle_read(4013)........: connection failure (set=0,sock=3,errno=104:Connection reset by peer)
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>spawnargv</NAME>
> <NP>1</NP>
> <TIME>0.151921987533569</TIME>
> <TESTDIFF>
>  No Errors
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>spawnmanyarg</NAME>
> <NP>1</NP>
> <TIME>0.470457077026367</TIME>
> <TESTDIFF>
>  No Errors
> MPIDI_CH3I_Socki_handle_read(4013)........: connection failure (set=0,sock=9,errno=104:Connection reset by peer)
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>spawnmult2</NAME>
> <NP>2</NP>
> <TIME>0.168694019317627</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spaconacc</NAME>
> <NP>1</NP>
> <TIME>0.187411069869995</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spaconacc2</NAME>
> <NP>1</NP>
> <TIME>0.198820114135742</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>selfconacc</NAME>
> <NP>2</NP>
> <TIME>0.0735728740692139</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spaiccreate</NAME>
> <NP>2</NP>
> <TIME>0.158139944076538</TIME>
> <TESTDIFF>
>  No Errors
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>spaiccreate2</NAME>
> <NP>2</NP>
> <TIME>0.158308982849121</TIME>
> <TESTDIFF>
>  No Errors
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>taskmaster</NAME>
> <NP>1</NP>
> <TIME>6.22101306915283</TIME>
> </MPITEST>
> <MPITEST>
> <NP>2</NP>
> <TIME>5.67409205436707</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>join</NAME>
> <NP>2</NP>
> <TIME>0.0872609615325928</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>disconnect_reconnect</NAME>
> <NP>3</NP>
> <TIME>0.327396154403687</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>disconnect_reconnect2</NAME>
> <NP>3</NP>
> <TIME>0.402704000473022</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>disconnect_reconnect3</NAME>
> <NP>3</NP>
> <TIME>0.383519887924194</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>multiple_ports</NAME>
> <NP>3</NP>
> <TIME>3.11186599731445</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>multiple_ports2</NAME>
> <NP>4</NP>
> <TIME>4.12817096710205</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>disconnect</NAME>
> <NP>3</NP>
> <TIME>0.179970026016235</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>disconnect2</NAME>
> <NP>3</NP>
> <TIME>0.185276985168457</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>disconnect3</NAME>
> <NP>3</NP>
> <TIME>0.190285921096802</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>concurrent_spawns</NAME>
> <NP>1</NP>
> <TIME>1.0178689956665</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>pgroup_connect_test</NAME>
> <NP>4</NP>
> <TIME>0.11017918586731</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>pgroup_intercomm_test</NAME>
> <NP>4</NP>
> <TIME>0.124139070510864</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawn_rootargs</NAME>
> <NP>10</NP>
> <TIME>0.954456090927124</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cartmap1</NAME>
> <NP>4</NP>
> <WORKDIR>./topo</WORKDIR>
> <TIME>0.118160009384155</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cartzero</NAME>
> <NP>4</NP>
> <TIME>0.120638132095337</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cartshift1</NAME>
> <NP>4</NP>
> <TIME>0.127601146697998</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cartsuball</NAME>
> <NP>4</NP>
> <TIME>0.113382816314697</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cartcreates</NAME>
> <NP>4</NP>
> <TIME>0.123159170150757</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dims1</NAME>
> <NP>4</NP>
> <TIME>0.128957986831665</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dims2</NAME>
> <NP>1</NP>
> <TIME>0.0693280696868896</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dims3</NAME>
> <NP>1</NP>
> <TIME>0.0696489810943604</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dims4</NAME>
> <NP>1</NP>
> <TIME>0.0839729309082031</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dims5</NAME>
> <NP>1</NP>
> <TIME>0.628308057785034</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>graphmap1</NAME>
> <NP>4</NP>
> <TIME>0.112588882446289</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>topotest</NAME>
> <NP>4</NP>
> <TIME>0.118993043899536</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>topodup</NAME>
> <NP>4</NP>
> <TIME>0.116497993469238</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>graphcr</NAME>
> <NP>4</NP>
> <TIME>0.129645109176636</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>graphcr2</NAME>
> <NP>4</NP>
> <TIME>0.131664037704468</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>distgraph1</NAME>
> <NP>4</NP>
> <TIME>0.140829086303711</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dgraph_unwgt</NAME>
> <NP>4</NP>
> <TIME>0.123724937438965</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendrecvl</NAME>
> <NP>2</NP>
> <WORKDIR>./perf</WORKDIR>
> <TIME>0.171825885772705</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>non_zero_root</NAME>
> <NP>4</NP>
> <TIME>0.478394985198975</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>timer</NAME>
> <NP>1</NP>
> <TIME>0.0743567943572998</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commcreatep</NAME>
> <NP>16</NP>
> <TIME>0.31522798538208</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rdwrord</NAME>
> <NP>4</NP>
> <WORKDIR>./io</WORKDIR>
> <TIME>0.128545999526978</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rdwrzero</NAME>
> <NP>4</NP>
> <TIME>0.118782043457031</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>getextent</NAME>
> <NP>2</NP>
> <TIME>0.0846388339996338</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>setinfo</NAME>
> <NP>4</NP>
> <TIME>0.12224006652832</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>setviewcur</NAME>
> <NP>4</NP>
> <TIME>0.126224994659424</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_noncontig</NAME>
> <NP>2</NP>
> <TIME>0.0950069427490234</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>async</NAME>
> <NP>4</NP>
> <TIME>0.12787389755249</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>async_any</NAME>
> <NP>4</NP>
> <TIME>0.11828088760376</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>userioerr</NAME>
> <NP>1</NP>
> <TIME>0.071951150894165</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>resized</NAME>
> <NP>1</NP>
> <TIME>0.0653841495513916</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>resized2</NAME>
> <NP>1</NP>
> <TIME>0.0749568939208984</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bigtype</NAME>
> <NP>1</NP>
> <TIME>11.4102110862732</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>hindexed_io</NAME>
> <NP>1</NP>
> <TIME>0.0742650032043457</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>tst_fileview</NAME>
> <NP>1</NP>
> <TIME>0.411098957061768</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>simple_collective</NAME>
> <NP>1</NP>
> <TIME>0.0770378112792969</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>external32_derived_dtype</NAME>
> <NP>1</NP>
> <TIME>0.0738418102264404</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_bigtype</NAME>
> <NP>1</NP>
> <TIME>11.76220703125</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_hindexed_io</NAME>
> <NP>1</NP>
> <TIME>0.0693099498748779</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_rdwrord</NAME>
> <NP>4</NP>
> <TIME>0.126873016357422</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_setviewcur</NAME>
> <NP>4</NP>
> <TIME>0.124082088470459</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_aggregation1</NAME>
> <NP>4</NP>
> <TIME>0.203712940216064</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_aggregation2</NAME>
> <NP>4</NP>
> <TIME>0.12844705581665</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_coll_test</NAME>
> <NP>4</NP>
> <TIME>0.132144927978516</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_darray_read</NAME>
> <NP>4</NP>
> <TIME>0.12725305557251</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_hindexed</NAME>
> <NP>4</NP>
> <TIME>0.119229078292847</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_noncontig_coll</NAME>
> <NP>2</NP>
> <TIME>9.95266485214233</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_noncontig_coll2</NAME>
> <NP>4</NP>
> <TIME>0.199080944061279</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_types_with_zeros</NAME>
> <NP>2</NP>
> <TIME>0.0925369262695312</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrmpi1f</NAME>
> <NP>1</NP>
> <WORKDIR>./f77/attr</WORKDIR>
> <TIME>0.0850009918212891</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseattrf</NAME>
> <NP>1</NP>
> <TIME>0.0673120021820068</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseattr2f</NAME>
> <NP>1</NP>
> <TIME>0.0685679912567139</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commattrf</NAME>
> <NP>1</NP>
> <TIME>0.0725278854370117</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commattr2f</NAME>
> <NP>1</NP>
> <TIME>0.069221019744873</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commattr3f</NAME>
> <NP>1</NP>
> <TIME>0.0687510967254639</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commattr4f</NAME>
> <NP>1</NP>
> <TIME>0.0682768821716309</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typeattrf</NAME>
> <NP>1</NP>
> <TIME>0.0744218826293945</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typeattr2f</NAME>
> <NP>1</NP>
> <TIME>0.0699019432067871</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typeattr3f</NAME>
> <NP>1</NP>
> <TIME>0.0701570510864258</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>uallreducef</NAME>
> <NP>4</NP>
> <WORKDIR>./f77/coll</WORKDIR>
> <TIME>0.121012210845947</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>exscanf</NAME>
> <NP>5</NP>
> <TIME>0.133509159088135</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>alltoallwf</NAME>
> <NP>7</NP>
> <TIME>0.167248010635376</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>alltoallvf</NAME>
> <NP>7</NP>
> <TIME>0.164567947387695</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>inplacef</NAME>
> <NP>4</NP>
> <TIME>0.121473073959351</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>reducelocalf</NAME>
> <NP>2</NP>
> <TIME>0.0900359153747559</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>redscatf</NAME>
> <NP>4</NP>
> <TIME>0.122048139572144</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>split_typef</NAME>
> <NP>4</NP>
> <TIME>0.120668888092041</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nonblockingf</NAME>
> <NP>4</NP>
> <TIME>0.119163036346436</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>vw_inplacef</NAME>
> <NP>4</NP>
> <TIME>0.1177659034729</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>red_scat_blockf</NAME>
> <NP>4</NP>
> <TIME>0.12415599822998</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nonblocking_inpf</NAME>
> <NP>4</NP>
> <TIME>0.123234033584595</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typenamef</NAME>
> <NP>1</NP>
> <WORKDIR>./f77/datatype</WORKDIR>
> <TIME>0.0724530220031738</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typename3f</NAME>
> <NP>1</NP>
> <TIME>0.0712299346923828</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typesnamef</NAME>
> <NP>1</NP>
> <TIME>0.0711178779602051</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typecntsf</NAME>
> <NP>1</NP>
> <TIME>0.070688009262085</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typem2f</NAME>
> <NP>1</NP>
> <TIME>0.0718998908996582</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typesubf</NAME>
> <NP>1</NP>
> <TIME>0.0667269229888916</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>packef</NAME>
> <NP>1</NP>
> <TIME>0.0706958770751953</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>gaddressf</NAME>
> <NP>1</NP>
> <TIME>0.0698378086090088</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allctypesf</NAME>
> <NP>1</NP>
> <TIME>0.065622091293335</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>hindex1f</NAME>
> <NP>1</NP>
> <TIME>0.0736942291259766</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>hindexed_blockf</NAME>
> <NP>1</NP>
> <TIME>0.0740659236907959</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bottom</NAME>
> <NP>2</NP>
> <TIME>0.0854461193084717</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>statusesf</NAME>
> <NP>1</NP>
> <WORKDIR>./f77/pt2pt</WORKDIR>
> <TIME>0.0748090744018555</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>greqf</NAME>
> <NP>1</NP>
> <TIME>0.0722880363464355</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendf</NAME>
> <NP>2</NP>
> <TIME>0.0878078937530518</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rsendf</NAME>
> <NP>2</NP>
> <TIME>0.0876789093017578</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ssendf</NAME>
> <NP>2</NP>
> <TIME>0.0886540412902832</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>isendf</NAME>
> <NP>2</NP>
> <TIME>0.0874559879302979</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>irsendf</NAME>
> <NP>2</NP>
> <TIME>0.085719108581543</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>issendf</NAME>
> <NP>2</NP>
> <TIME>0.085385799407959</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>psendf</NAME>
> <NP>2</NP>
> <TIME>0.0857770442962646</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>prsendf</NAME>
> <NP>2</NP>
> <TIME>0.0911581516265869</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>pssendf</NAME>
> <NP>2</NP>
> <TIME>0.0852749347686768</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendrecvf</NAME>
> <NP>2</NP>
> <TIME>0.095041036605835</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendrecvreplf</NAME>
> <NP>2</NP>
> <TIME>0.0829989910125732</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>mprobef</NAME>
> <NP>2</NP>
> <TIME>0.0868690013885498</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infotestf</NAME>
> <NP>1</NP>
> <WORKDIR>./f77/info</WORKDIR>
> <TIME>0.0746738910675049</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infotest2f</NAME>
> <NP>1</NP>
> <TIME>0.0753390789031982</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>namepubf</NAME>
> <NP>2</NP>
> <WORKDIR>./f77/spawn</WORKDIR>
> <TIME>0.0829319953918457</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawnf</NAME>
> <NP>1</NP>
> <TIME>0.15523886680603</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawnargvf</NAME>
> <NP>1</NP>
> <TIME>0.152647018432617</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>connaccf</NAME>
> <NP>2</NP>
> <TIME>0.0888791084289551</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawnmultf</NAME>
> <NP>1</NP>
> <TIME>0.153861045837402</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawnmult2f</NAME>
> <NP>2</NP>
> <TIME>0.143976926803589</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwriteatf</NAME>
> <NP>4</NP>
> <WORKDIR>./f77/io</WORKDIR>
> <TIME>0.533286809921265</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwritef</NAME>
> <NP>4</NP>
> <TIME>0.561429023742676</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwriteshf</NAME>
> <NP>4</NP>
> <TIME>4.31697702407837</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writef</NAME>
> <NP>4</NP>
> <TIME>0.368510961532593</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeatf</NAME>
> <NP>4</NP>
> <TIME>0.387544870376587</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeallf</NAME>
> <NP>4</NP>
> <TIME>1.59190821647644</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeshf</NAME>
> <NP>4</NP>
> <TIME>3.0810170173645</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeordf</NAME>
> <NP>4</NP>
> <TIME>3.01215696334839</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeatallf</NAME>
> <NP>4</NP>
> <TIME>1.46528005599976</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeatallbef</NAME>
> <NP>4</NP>
> <TIME>1.56570601463318</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeallbef</NAME>
> <NP>4</NP>
> <TIME>1.73111891746521</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeordbef</NAME>
> <NP>4</NP>
> <TIME>2.97038793563843</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fileerrf</NAME>
> <NP>1</NP>
> <TIME>0.0742180347442627</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fileinfof</NAME>
> <NP>3</NP>
> <TIME>0.0961940288543701</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>shpositionf</NAME>
> <NP>4</NP>
> <TIME>0.12107515335083</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>atomicityf</NAME>
> <NP>8</NP>
> <TIME>0.19758415222168</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>miscfilef</NAME>
> <NP>4</NP>
> <STATUS>pass</STATUS>
> <TIME>0.18585205078125</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>setviewcurf</NAME>
> <NP>4</NP>
> <TIME>0.127150058746338</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>c2f2ciof</NAME>
> <NP>1</NP>
> <TIME>0.0703780651092529</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>c2fmultio</NAME>
> <NP>1</NP>
> <TIME>0.072580099105835</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_setviewcurf</NAME>
> <NP>4</NP>
> <TIME>0.125735998153687</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwriteatallf</NAME>
> <NP>4</NP>
> <TIME>1.50459384918213</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winscale1f</NAME>
> <NP>4</NP>
> <WORKDIR>./f77/rma</WORKDIR>
> <TIME>0.118920803070068</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winfencef</NAME>
> <NP>4</NP>
> <TIME>0.115972995758057</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>wingetf</NAME>
> <NP>5</NP>
> <TIME>0.12664008140564</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winscale2f</NAME>
> <NP>4</NP>
> <TIME>0.12497615814209</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winerrf</NAME>
> <NP>1</NP>
> <TIME>0.0580849647521973</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winnamef</NAME>
> <NP>1</NP>
> <TIME>0.0577499866485596</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>wingroupf</NAME>
> <NP>4</NP>
> <TIME>0.121740818023682</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winaccf</NAME>
> <NP>4</NP>
> <TIME>0.129521131515503</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>c2f2cwinf</NAME>
> <NP>1</NP>
> <TIME>0.0742599964141846</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseattrwinf</NAME>
> <NP>1</NP>
> <TIME>0.0726668834686279</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winattrf</NAME>
> <NP>1</NP>
> <TIME>0.0596179962158203</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winattr2f</NAME>
> <NP>1</NP>
> <TIME>0.0683679580688477</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>aintf</NAME>
> <NP>2</NP>
> <TIME>0.0863702297210693</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseenvf</NAME>
> <NP>1</NP>
> <WORKDIR>./f77/init</WORKDIR>
> <TIME>0.0695710182189941</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commnamef</NAME>
> <NP>2</NP>
> <WORKDIR>./f77/comm</WORKDIR>
> <TIME>0.0827898979187012</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commerrf</NAME>
> <NP>2</NP>
> <TIME>0.0878260135650635</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>c2f2cf</NAME>
> <NP>1</NP>
> <WORKDIR>./f77/ext</WORKDIR>
> <TIME>0.0701191425323486</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>c2fmult</NAME>
> <NP>1</NP>
> <TIME>0.0672659873962402</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ctypesinf</NAME>
> <NP>1</NP>
> <TIME>0.0737400054931641</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allocmemf</NAME>
> <NP>1</NP>
> <TIME>0.0722379684448242</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cartcrf</NAME>
> <NP>4</NP>
> <WORKDIR>./f77/topo</WORKDIR>
> <TIME>0.113845109939575</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dgraph_wgtf</NAME>
> <NP>4</NP>
> <TIME>0.112581014633179</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dgraph_unwgtf</NAME>
> <NP>4</NP>
> <TIME>0.115466117858887</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>profile1f</NAME>
> <NP>2</NP>
> <WORKDIR>./f77/profile</WORKDIR>
> <TIME>0.0861790180206299</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrtx</NAME>
> <NP>2</NP>
> <WORKDIR>./cxx/attr</WORKDIR>
> <TIME>0.0896470546722412</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attricx</NAME>
> <NP>4</NP>
> <TIME>0.120862007141113</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseattrcommx</NAME>
> <NP>1</NP>
> <TIME>0.0587770938873291</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fkeyvalcommx</NAME>
> <NP>1</NP>
> <TIME>0.0708680152893066</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fkeyvaltypex</NAME>
> <NP>1</NP>
> <TIME>0.0716590881347656</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bsend1cxx</NAME>
> <NP>2</NP>
> <WORKDIR>./cxx/pt2pt</WORKDIR>
> <TIME>0.0857119560241699</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendrecvx</NAME>
> <NP>2</NP>
> <TIME>0.0823359489440918</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commname2</NAME>
> <NP>4</NP>
> <WORKDIR>./cxx/comm</WORKDIR>
> <TIME>0.119338989257812</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>arcomplex</NAME>
> <NP>4</NP>
> <WORKDIR>./cxx/coll</WORKDIR>
> <TIME>0.118666887283325</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>uallredx</NAME>
> <NP>5</NP>
> <TIME>0.137440919876099</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>uallreduce</NAME>
> <NP>5</NP>
> <TIME>0.143809080123901</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ureduce</NAME>
> <NP>5</NP>
> <TIME>0.156033992767334</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ureducelocal</NAME>
> <NP>5</NP>
> <TIME>0.194337844848633</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>uscan</NAME>
> <NP>5</NP>
> <TIME>0.142906904220581</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>uexscan</NAME>
> <NP>5</NP>
> <TIME>0.138534069061279</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>alltoallw2x</NAME>
> <NP>10</NP>
> <TIME>0.204027891159058</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icbcastx</NAME>
> <NP>4</NP>
> <TIME>0.116377115249634</TIME>
> </MPITEST>
> <MPITEST>
> <NP>10</NP>
> <TIME>0.228738069534302</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icallreducex</NAME>
> <NP>5</NP>
> <TIME>0.150272846221924</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icreducex</NAME>
> <NP>5</NP>
> <TIME>0.139081001281738</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icscatterx</NAME>
> <NP>5</NP>
> <TIME>0.14826488494873</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icgatherx</NAME>
> <NP>5</NP>
> <TIME>0.144917011260986</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icallgatherx</NAME>
> <NP>5</NP>
> <TIME>0.170108079910278</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icbarrierx</NAME>
> <NP>5</NP>
> <TIME>0.130705118179321</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icallgathervx</NAME>
> <NP>5</NP>
> <TIME>0.15550684928894</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icgathervx</NAME>
> <NP>5</NP>
> <TIME>0.14216685295105</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icscattervx</NAME>
> <NP>5</NP>
> <TIME>0.143685817718506</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>icalltoallx</NAME>
> <NP>5</NP>
> <TIME>0.148084878921509</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>reduceboolx</NAME>
> <NP>5</NP>
> <TIME>0.153132915496826</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>redscatblk</NAME>
> <NP>4</NP>
> <TIME>0.138857841491699</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commcallx</NAME>
> <NP>2</NP>
> <WORKDIR>./cxx/errhan</WORKDIR>
> <TIME>0.209397077560425</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseenv</NAME>
> <NP>1</NP>
> <WORKDIR>./cxx/init</WORKDIR>
> <TIME>0.0750689506530762</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>initstatx</NAME>
> <NP>1</NP>
> <TIME>0.0716061592102051</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>initstat2x</NAME>
> <NP>1</NP>
> <TIME>0.0676219463348389</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infodupx</NAME>
> <NP>1</NP>
> <WORKDIR>./cxx/info</WORKDIR>
> <TIME>0.0776669979095459</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infodelx</NAME>
> <NP>1</NP>
> <TIME>0.0742270946502686</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infovallenx</NAME>
> <NP>1</NP>
> <TIME>0.0746419429779053</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infoorderx</NAME>
> <NP>1</NP>
> <TIME>0.0722470283508301</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>packsizex</NAME>
> <NP>1</NP>
> <WORKDIR>./cxx/datatype</WORKDIR>
> <TIME>0.0663228034973145</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typecntsx</NAME>
> <NP>1</NP>
> <TIME>0.0753099918365479</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typenamex</NAME>
> <NP>1</NP>
> <TIME>0.0712528228759766</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typemiscx</NAME>
> <NP>1</NP>
> <TIME>0.0737130641937256</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwriteatx</NAME>
> <NP>4</NP>
> <WORKDIR>./cxx/io</WORKDIR>
> <TIME>0.526083946228027</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwritex</NAME>
> <NP>4</NP>
> <TIME>0.53234601020813</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwriteshx</NAME>
> <NP>4</NP>
> <TIME>4.26504898071289</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writex</NAME>
> <NP>4</NP>
> <TIME>0.351983070373535</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeatx</NAME>
> <NP>4</NP>
> <TIME>0.394251108169556</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeallx</NAME>
> <NP>4</NP>
> <TIME>1.65679502487183</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeshx</NAME>
> <NP>4</NP>
> <TIME>3.00603199005127</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeordx</NAME>
> <NP>4</NP>
> <TIME>2.84891486167908</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeatallx</NAME>
> <NP>4</NP>
> <TIME>1.628986120224</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeatallbex</NAME>
> <NP>4</NP>
> <TIME>1.43802499771118</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeallbex</NAME>
> <NP>4</NP>
> <TIME>1.65896797180176</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeordbex</NAME>
> <NP>4</NP>
> <TIME>2.88306307792664</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwriteatnosx</NAME>
> <NP>4</NP>
> <TIME>0.540616035461426</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwritenosx</NAME>
> <NP>4</NP>
> <TIME>0.54047703742981</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwriteshnosx</NAME>
> <NP>4</NP>
> <TIME>4.25632190704346</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writenosx</NAME>
> <NP>4</NP>
> <TIME>0.415482044219971</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeatnosx</NAME>
> <NP>4</NP>
> <TIME>0.370788097381592</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeallnosx</NAME>
> <NP>4</NP>
> <TIME>1.5787308216095</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeshnosx</NAME>
> <NP>4</NP>
> <TIME>2.99413084983826</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeordnosx</NAME>
> <NP>4</NP>
> <TIME>2.96482801437378</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeatallnosx</NAME>
> <NP>4</NP>
> <TIME>1.30819392204285</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeatallbenosx</NAME>
> <NP>4</NP>
> <TIME>1.48804187774658</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeallbenosx</NAME>
> <NP>4</NP>
> <TIME>1.85117983818054</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeordbenosx</NAME>
> <NP>4</NP>
> <TIME>2.7881019115448</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fileerrx</NAME>
> <NP>1</NP>
> <TIME>0.0755739212036133</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fileinfox</NAME>
> <NP>3</NP>
> <TIME>0.11155104637146</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>filemiscx</NAME>
> <NP>4</NP>
> <TIME>0.172790050506592</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>shpositionx</NAME>
> <NP>4</NP>
> <TIME>0.118265151977539</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>seekavail</NAME>
> <NP>1</NP>
> <TIME>0.070652961730957</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>namepubx</NAME>
> <NP>2</NP>
> <WORKDIR>./cxx/spawn</WORKDIR>
> <TIME>0.0867362022399902</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawnintrax</NAME>
> <NP>1</NP>
> <TIME>0.167046070098877</TIME>
> <TESTDIFF>
>  No Errors
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NP>2</NP>
> <TIME>0.165004014968872</TIME>
> <TESTDIFF>
>  No Errors
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>spawnargvx</NAME>
> <NP>1</NP>
> <TIME>0.145987987518311</TIME>
> <TESTDIFF>
>  No Errors
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>selfconaccx</NAME>
> <NP>2</NP>
> <TIME>0.0911471843719482</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winnamex</NAME>
> <NP>1</NP>
> <WORKDIR>./cxx/rma</WORKDIR>
> <TIME>0.0716910362243652</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>wincallx</NAME>
> <NP>1</NP>
> <TIME>0.0743510723114014</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>getgroupx</NAME>
> <NP>4</NP>
> <TIME>0.121744871139526</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winfencex</NAME>
> <NP>4</NP>
> <TIME>0.126389980316162</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winscale1x</NAME>
> <NP>4</NP>
> <TIME>0.118727922439575</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winscale2x</NAME>
> <NP>4</NP>
> <TIME>0.118641138076782</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fkeyvalwinx</NAME>
> <NP>1</NP>
> <TIME>0.0712668895721436</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrmpi1f90</NAME>
> <NP>1</NP>
> <WORKDIR>./f90/attr</WORKDIR>
> <TIME>0.0734148025512695</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseattrf90</NAME>
> <NP>1</NP>
> <TIME>0.0719029903411865</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseattr2f90</NAME>
> <NP>1</NP>
> <TIME>0.0734438896179199</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commattrf90</NAME>
> <NP>1</NP>
> <TIME>0.073868989944458</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commattr2f90</NAME>
> <NP>1</NP>
> <TIME>0.0706028938293457</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commattr3f90</NAME>
> <NP>1</NP>
> <TIME>0.0735828876495361</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commattr4f90</NAME>
> <NP>1</NP>
> <TIME>0.0731589794158936</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typeattrf90</NAME>
> <NP>1</NP>
> <TIME>0.0611169338226318</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typeattr2f90</NAME>
> <NP>1</NP>
> <TIME>0.0595030784606934</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typeattr3f90</NAME>
> <NP>1</NP>
> </MPITEST>
> <MPITEST>
> <NAME>fandcattrf90</NAME>
> <NP>1</NP>
> <TIME>0.0724899768829346</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseattr3f90</NAME>
> <NP>1</NP>
> <TIME>0.0745759010314941</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>attrlangf90</NAME>
> <NP>1</NP>
> <TIME>0.0746431350708008</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>uallreducef90</NAME>
> <NP>4</NP>
> <WORKDIR>./f90/coll</WORKDIR>
> <TIME>0.125061988830566</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>exscanf90</NAME>
> <NP>5</NP>
> <TIME>0.139776945114136</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>alltoallwf90</NAME>
> <NP>7</NP>
> <TIME>0.16494607925415</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>alltoallvf90</NAME>
> <NP>7</NP>
> <TIME>0.16814112663269</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>inplacef90</NAME>
> <NP>4</NP>
> <TIME>0.124346971511841</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>reducelocalf90</NAME>
> <NP>2</NP>
> <TIME>0.0869958400726318</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>redscatf90</NAME>
> <NP>4</NP>
> <TIME>0.125761985778809</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>split_typef90</NAME>
> <NP>4</NP>
> <TIME>0.122484922409058</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nonblockingf90</NAME>
> <NP>4</NP>
> <TIME>0.126758813858032</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>vw_inplacef90</NAME>
> <NP>4</NP>
> <TIME>0.123525142669678</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>red_scat_blockf90</NAME>
> <NP>4</NP>
> <TIME>0.119614124298096</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nonblocking_inpf90</NAME>
> <NP>4</NP>
> <TIME>0.129062175750732</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commnamef90</NAME>
> <NP>2</NP>
> <WORKDIR>./f90/comm</WORKDIR>
> <TIME>0.0831100940704346</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commerrf90</NAME>
> <NP>2</NP>
> <TIME>0.0878231525421143</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>c2f2cf90</NAME>
> <NP>1</NP>
> <WORKDIR>./f90/ext</WORKDIR>
> <TIME>0.0737490653991699</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>c2f90mult</NAME>
> <NP>1</NP>
> <TIME>0.0686898231506348</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ctypesinf90</NAME>
> <NP>1</NP>
> <TIME>0.0698349475860596</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allocmemf90</NAME>
> <NP>1</NP>
> <TIME>0.0625929832458496</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infotestf90</NAME>
> <NP>1</NP>
> <WORKDIR>./f90/info</WORKDIR>
> <TIME>0.0658559799194336</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>infotest2f90</NAME>
> <NP>1</NP>
> <TIME>0.0593528747558594</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseenvf90</NAME>
> <NP>1</NP>
> <WORKDIR>./f90/init</WORKDIR>
> <TIME>0.0772459506988525</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwriteatf90</NAME>
> <NP>4</NP>
> <WORKDIR>./f90/io</WORKDIR>
> <TIME>0.52808403968811</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwritef90</NAME>
> <NP>4</NP>
> <TIME>0.53515887260437</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwriteshf90</NAME>
> <NP>4</NP>
> <TIME>4.14790892601013</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writef90</NAME>
> <NP>4</NP>
> <TIME>0.405668020248413</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeatf90</NAME>
> <NP>4</NP>
> <TIME>0.408502101898193</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeallf90</NAME>
> <NP>4</NP>
> <TIME>1.6434850692749</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeshf90</NAME>
> <NP>4</NP>
> <TIME>3.09082984924316</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeordf90</NAME>
> <NP>4</NP>
> <TIME>2.92518305778503</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeatallf90</NAME>
> <NP>4</NP>
> <TIME>1.38312602043152</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeatallbef90</NAME>
> <NP>4</NP>
> <TIME>1.36431503295898</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeallbef90</NAME>
> <NP>4</NP>
> <TIME>1.61739897727966</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>writeordbef90</NAME>
> <NP>4</NP>
> <TIME>2.81878399848938</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fileerrf90</NAME>
> <NP>1</NP>
> <TIME>0.0735299587249756</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fileinfof90</NAME>
> <NP>3</NP>
> <TIME>0.107464075088501</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>shpositionf90</NAME>
> <NP>4</NP>
> <TIME>0.110713005065918</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>atomicityf90</NAME>
> <NP>8</NP>
> <TIME>0.187489986419678</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>miscfilef90</NAME>
> <NP>4</NP>
> <TIME>0.182344913482666</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>setviewcurf90</NAME>
> <NP>4</NP>
> <TIME>0.135235071182251</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>c2f2ciof90</NAME>
> <NP>1</NP>
> <TIME>0.0691471099853516</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>c2f90multio</NAME>
> <NP>1</NP>
> <TIME>0.0711290836334229</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>i_setviewcurf90</NAME>
> <NP>4</NP>
> <TIME>0.129880905151367</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iwriteatallf90</NAME>
> <NP>4</NP>
> <TIME>1.47132706642151</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sizeof2</NAME>
> <NP>1</NP>
> <WORKDIR>./f90/misc</WORKDIR>
> <TIME>0.0741441249847412</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>statusesf90</NAME>
> <NP>1</NP>
> <WORKDIR>./f90/pt2pt</WORKDIR>
> <TIME>0.0680420398712158</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>greqf90</NAME>
> <NP>1</NP>
> <TIME>0.0719079971313477</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendf90</NAME>
> <NP>2</NP>
> <TIME>0.0911109447479248</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rsendf90</NAME>
> <NP>2</NP>
> <TIME>0.0902628898620605</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ssendf90</NAME>
> <NP>2</NP>
> <TIME>0.0865879058837891</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>isendf90</NAME>
> <NP>2</NP>
> <TIME>0.0896921157836914</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>irsendf90</NAME>
> <NP>2</NP>
> <TIME>0.0863420963287354</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>issendf90</NAME>
> <NP>2</NP>
> <TIME>0.0886268615722656</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>psendf90</NAME>
> <NP>2</NP>
> <TIME>0.0819931030273438</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>prsendf90</NAME>
> <NP>2</NP>
> <TIME>0.0816650390625</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>pssendf90</NAME>
> <NP>2</NP>
> <TIME>0.0863401889801025</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendrecvf90</NAME>
> <NP>2</NP>
> <TIME>0.0884048938751221</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendrecvreplf90</NAME>
> <NP>2</NP>
> <TIME>0.0874159336090088</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>mprobef90</NAME>
> <NP>2</NP>
> <TIME>0.094959020614624</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typenamef90</NAME>
> <NP>1</NP>
> <WORKDIR>./f90/datatype</WORKDIR>
> <TIME>0.0718879699707031</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typename3f90</NAME>
> <NP>1</NP>
> <TIME>0.0689029693603516</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typesnamef90</NAME>
> <NP>1</NP>
> <TIME>0.0721931457519531</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typecntsf90</NAME>
> <NP>1</NP>
> <TIME>0.071699857711792</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typem2f90</NAME>
> <NP>1</NP>
> <TIME>0.0735070705413818</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>typesubf90</NAME>
> <NP>1</NP>
> <TIME>0.0728728771209717</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>packef90</NAME>
> <NP>1</NP>
> <TIME>0.0732438564300537</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>gaddressf90</NAME>
> <NP>1</NP>
> <TIME>0.0703539848327637</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allctypesf90</NAME>
> <NP>1</NP>
> <TIME>0.0719649791717529</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>hindex1f90</NAME>
> <NP>1</NP>
> <TIME>0.0730788707733154</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>hindexed_blockf90</NAME>
> <NP>1</NP>
> <TIME>0.0736021995544434</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bottom</NAME>
> <NP>2</NP>
> <TIME>0.0884659290313721</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>structf</NAME>
> <NP>2</NP>
> <TIME>0.0864989757537842</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>indtype</NAME>
> <NP>2</NP>
> <TIME>0.0833070278167725</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>createf90</NAME>
> <NP>1</NP>
> <TIME>0.0798661708831787</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sizeof</NAME>
> <NP>1</NP>
> <TIME>0.0742509365081787</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>kinds</NAME>
> <NP>2</NP>
> <TIME>0.0909171104431152</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>trf90</NAME>
> <NP>1</NP>
> <TIME>0.0746560096740723</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_elem_d</NAME>
> <NP>2</NP>
> <TIME>0.0860769748687744</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>get_elem_u</NAME>
> <NP>2</NP>
> <TIME>0.084446907043457</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>createf90types</NAME>
> <NP>1</NP>
> <WORKDIR>./f90/f90types</WORKDIR>
> <TIME>0.0730419158935547</TIME>
> </MPITEST>
> <MPITEST>
> <NP>1</NP>
> <TIME>0.145277976989746</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winscale1f90</NAME>
> <NP>4</NP>
> <WORKDIR>./f90/rma</WORKDIR>
> <TIME>0.122819185256958</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winfencef90</NAME>
> <NP>4</NP>
> <TIME>0.127620935440063</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>wingetf90</NAME>
> <NP>5</NP>
> <TIME>0.132025003433228</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winscale2f90</NAME>
> <NP>4</NP>
> <TIME>0.115222930908203</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winerrf90</NAME>
> <NP>1</NP>
> <TIME>0.0731351375579834</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winnamef90</NAME>
> <NP>1</NP>
> <TIME>0.0706679821014404</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>wingroupf90</NAME>
> <NP>4</NP>
> <TIME>0.123701095581055</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winaccf90</NAME>
> <NP>4</NP>
> <TIME>0.119988918304443</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>c2f2cwinf90</NAME>
> <NP>1</NP>
> <TIME>0.0693569183349609</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>baseattrwinf90</NAME>
> <NP>1</NP>
> <TIME>0.0705299377441406</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winattrf90</NAME>
> <NP>1</NP>
> <TIME>0.0740499496459961</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winattr2f90</NAME>
> <NP>1</NP>
> <TIME>0.0730850696563721</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>aintf90</NAME>
> <NP>2</NP>
> <TIME>0.0801820755004883</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>namepubf90</NAME>
> <NP>2</NP>
> <WORKDIR>./f90/spawn</WORKDIR>
> <TIME>0.088068962097168</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawnf90</NAME>
> <NP>1</NP>
> <TIME>0.147098064422607</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawnargvf90</NAME>
> <NP>1</NP>
> <TIME>0.157328128814697</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>connaccf90</NAME>
> <NP>2</NP>
> <TIME>0.0825910568237305</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawnmultf90</NAME>
> <NP>1</NP>
> <TIME>0.161619901657104</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawnmult2f90</NAME>
> <NP>2</NP>
> <TIME>0.163341045379639</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawnargvf03</NAME>
> <NP>1</NP>
> <TIME>0.145040035247803</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>spawnmultf03</NAME>
> <NP>1</NP>
> <TIME>0.146586894989014</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>wtimef90</NAME>
> <NP>1</NP>
> <WORKDIR>./f90/timer</WORKDIR>
> <TIME>0.0728318691253662</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cartcrf90</NAME>
> <NP>4</NP>
> <WORKDIR>./f90/topo</WORKDIR>
> <TIME>0.126941204071045</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dgraph_wgtf90</NAME>
> <NP>4</NP>
> <TIME>0.113095045089722</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dgraph_unwgtf90</NAME>
> <NP>4</NP>
> <TIME>0.128242015838623</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>profile1f90</NAME>
> <NP>2</NP>
> <WORKDIR>./f90/profile</WORKDIR>
> <TIME>0.0809640884399414</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>keyvalmis</NAME>
> <NP>1</NP>
> <WORKDIR>./errors/attr</WORKDIR>
> <TIME>0.0574350357055664</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>noalias</NAME>
> <NP>2</NP>
> <WORKDIR>./errors/coll</WORKDIR>
> <TIME>0.0890989303588867</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nb_noalias</NAME>
> <NP>2</NP>
> <TIME>0.0826659202575684</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>noalias2</NAME>
> <NP>4</NP>
> <TIME>0.116487979888916</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>noalias3</NAME>
> <NP>4</NP>
> <TIME>0.120805978775024</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>rerr</NAME>
> <NP>2</NP>
> <TIME>0.0871310234069824</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>nb_rerr</NAME>
> <NP>2</NP>
> <TIME>0.086939811706543</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>reduce_local</NAME>
> <NP>1</NP>
> <TIME>0.0724670886993408</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>bcastlength</NAME>
> <NP>4</NP>
> <TIME>0.115355968475342</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ibcastlength</NAME>
> <NP>4</NP>
> <TIME>0.122375965118408</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cfree</NAME>
> <NP>4</NP>
> <WORKDIR>./errors/comm</WORKDIR>
> <TIME>0.113522052764893</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ccreate1</NAME>
> <NP>8</NP>
> <TIME>0.182398080825806</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>userdup</NAME>
> <NP>4</NP>
> <TIME>0.122168064117432</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>manysplit</NAME>
> <NP>4</NP>
> <TIME>0.63823390007019</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>too_many_comms</NAME>
> <NP>4</NP>
> <TIME>0.514928102493286</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>too_many_icomms</NAME>
> <NP>4</NP>
> <TIME>0.600313901901245</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>too_many_comms2</NAME>
> <NP>4</NP>
> <TIME>0.510926008224487</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>too_many_comms3</NAME>
> <NP>4</NP>
> <TIME>1.18538308143616</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>too_many_icomms2</NAME>
> <NP>4</NP>
> <TIME>0.57210898399353</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_create_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0721890926361084</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_create_group_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0713469982147217</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_get_info_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0684709548950195</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_group_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0733680725097656</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_size_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.072890043258667</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_split_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0705170631408691</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_split_type_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0728130340576172</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>intercomm_create_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0722157955169678</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>type_contiguous_nullarg</NAME>
> <NP>1</NP>
> <WORKDIR>./errors/datatype</WORKDIR>
> <TIME>0.0640869140625</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>type_extent_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0717248916625977</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>type_get_extent_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0699329376220703</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>type_get_true_extent_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0762670040130615</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>type_get_true_extent_x_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0739848613739014</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>type_lb_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0735421180725098</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>type_ub_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0694470405578613</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>type_size_x_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0688529014587402</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>type_vector_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0723350048065186</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>gerr</NAME>
> <NP>1</NP>
> <WORKDIR>./errors/group</WORKDIR>
> <TIME>0.0707540512084961</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>group_difference_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0692319869995117</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>group_intersection_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.072113037109375</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>group_range_excl_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0716769695281982</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>group_range_incl_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0713331699371338</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>group_rank_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0672760009765625</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>group_size_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0602819919586182</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>group_translate_ranks_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0695171356201172</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>group_union_nullarg</NAME>
> <NP>1</NP>
> <TIME>0.0708730220794678</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>proberank</NAME>
> <NP>1</NP>
> <WORKDIR>./errors/pt2pt</WORKDIR>
> <TIME>0.0691688060760498</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>truncmsg1</NAME>
> <NP>2</NP>
> <TIME>0.0869200229644775</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>truncmsg2</NAME>
> <NP>2</NP>
> <TIME>0.0905699729919434</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>errinstatts</NAME>
> <NP>2</NP>
> <TIME>0.0881030559539795</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>errinstatta</NAME>
> <NP>2</NP>
> <TIME>0.0873501300811768</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>errinstatws</NAME>
> <NP>2</NP>
> <TIME>0.0867648124694824</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>errinstatwa</NAME>
> <NP>2</NP>
> <TIME>0.0841331481933594</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cartsmall</NAME>
> <NP>4</NP>
> <WORKDIR>./errors/topo</WORKDIR>
> <TIME>0.122482061386108</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winerr</NAME>
> <NP>2</NP>
> <WORKDIR>./errors/rma</WORKDIR>
> <TIME>0.0876049995422363</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>winerr2</NAME>
> <NP>2</NP>
> <TIME>0.0740280151367188</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>cas_type_check</NAME>
> <NP>2</NP>
> <TIME>2.14480996131897</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_sync_unlock</NAME>
> <NP>2</NP>
> <TIME>0.0877940654754639</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_sync_free_pt</NAME>
> <NP>2</NP>
> <TIME>0.0879900455474854</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_sync_free_at</NAME>
> <NP>2</NP>
> <TIME>0.0827391147613525</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_sync_complete</NAME>
> <NP>2</NP>
> <TIME>0.084874153137207</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_sync_lock_at</NAME>
> <NP>2</NP>
> <TIME>0.0845332145690918</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_sync_lock_pt</NAME>
> <NP>2</NP>
> <TIME>0.0893850326538086</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_sync_lock_fence</NAME>
> <NP>2</NP>
> <TIME>0.0863218307495117</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_sync_nested</NAME>
> <NP>2</NP>
> <TIME>0.0847890377044678</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>win_sync_op</NAME>
> <NP>2</NP>
> <TIME>0.0887770652770996</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>badport</NAME>
> <NP>2</NP>
> <WORKDIR>./errors/spawn</WORKDIR>
> <TIME>0.0776200294494629</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>unpub</NAME>
> <NP>1</NP>
> <TIME>0.069005012512207</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>lookup_name</NAME>
> <NP>1</NP>
> <TIME>0.0737261772155762</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>connect_timeout_no_accept</NAME>
> <NP>2</NP>
> <TIME>25.0865631103516</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>connect_timeout_mismatch</NAME>
> <NP>2</NP>
> <TIME>0.088594913482666</TIME>
> </MPITEST>
> <MPITEST>
> <NP>5</NP>
> <TIME>25.1357250213623</TIME>
> </MPITEST>
> <MPITEST>
> <NP>5</NP>
> <TIME>0.13117504119873</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fileerrret</NAME>
> <NP>1</NP>
> <WORKDIR>./errors/io</WORKDIR>
> <TIME>0.0654418468475342</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>openerr</NAME>
> <NP>1</NP>
> <TIME>0.072396993637085</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>file_errhdl</NAME>
> <NP>1</NP>
> <TIME>0.0739409923553467</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>uerrhandf</NAME>
> <NP>1</NP>
> <WORKDIR>./errors/f77/io</WORKDIR>
> <TIME>0.0688390731811523</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>errgetx</NAME>
> <NP>1</NP>
> <WORKDIR>./errors/cxx/errhan</WORKDIR>
> <TIME>0.0672180652618408</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>errsetx</NAME>
> <NP>1</NP>
> <TIME>0.0695888996124268</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>throwtest</NAME>
> <NP>1</NP>
> <TIME>0.0732018947601318</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>commerrx</NAME>
> <NP>2</NP>
> <TIME>0.0917630195617676</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>fileerrretx</NAME>
> <NP>1</NP>
> <WORKDIR>./errors/cxx/io</WORKDIR>
> <TIME>0.0705640316009521</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>errgetfilex</NAME>
> <NP>1</NP>
> <TIME>0.07222580909729</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>throwtestfilex</NAME>
> <NP>1</NP>
> <TIME>0.0754899978637695</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>uerrhandf90</NAME>
> <NP>1</NP>
> <WORKDIR>./errors/f90/io</WORKDIR>
> <TIME>0.0695769786834717</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>threads</NAME>
> <NP>2</NP>
> <WORKDIR>./threads/pt2pt</WORKDIR>
> <TIME>17.3229110240936</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>threaded_sr</NAME>
> <NP>2</NP>
> <TIME>3.08655595779419</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>alltoall</NAME>
> <NP>4</NP>
> <TIME>1.84778189659119</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>sendselfth</NAME>
> <NP>1</NP>
> <TIME>0.0696859359741211</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>multisend</NAME>
> <NP>2</NP>
> <TIME>0.0805289745330811</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>multisend2</NAME>
> <NP>5</NP>
> <TIME>1.51637005805969</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>multisend3</NAME>
> <NP>5</NP>
> <TIME>0.218149900436401</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>multisend4</NAME>
> <NP>5</NP>
> <TIME>0.444805860519409</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>greq_wait</NAME>
> <NP>1</NP>
> <TIME>9.07199883460999</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>greq_test</NAME>
> <NP>1</NP>
> <TIME>9.07371115684509</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ibsend</NAME>
> <NP>2</NP>
> <TIME>0.107457876205444</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>ctxdup</NAME>
> <NP>4</NP>
> <WORKDIR>./threads/comm</WORKDIR>
> <TIME>1.11906695365906</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>dup_leak_test</NAME>
> <NP>2</NP>
> <TIME>2.74484586715698</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_dup_deadlock</NAME>
> <NP>4</NP>
> <TIME>1.12533187866211</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_create_threads</NAME>
> <NP>4</NP>
> <TIME>0.441538095474243</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_create_group_threads</NAME>
> <NP>4</NP>
> <TIME>0.265141010284424</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_create_group_threads2</NAME>
> <NP>4</NP>
> <TIME>0.34257984161377</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>idup_deadlock</NAME>
> <NP>4</NP>
> <TIME>0.121576070785522</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>comm_idup</NAME>
> <NP>4</NP>
> <TIME>180.33131313324</TIME>
> <TESTDIFF>
> [mpiexec at lorien] APPLICATION TIMED OUT
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>ctxidup</NAME>
> <NP>4</NP>
> <TIME>1.14184999465942</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>idup_nb</NAME>
> <NP>4</NP>
> <TIME>18.1934969425201</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>idup_comm_gen</NAME>
> <NP>4</NP>
> <TIME>0.156306028366089</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>initth</NAME>
> <NP>1</NP>
> <WORKDIR>./threads/init</WORKDIR>
> <TIME>0.0675761699676514</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>initth</NAME>
> <NP>2</NP>
> <TIME>0.0848090648651123</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>mpit_threading</NAME>
> <NP>1</NP>
> <WORKDIR>./threads/mpi_t</WORKDIR>
> <TIME>0.0818259716033936</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>multispawn</NAME>
> <NP>1</NP>
> <WORKDIR>./threads/spawn</WORKDIR>
> <TIME>0.355624914169312</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>th_taskmaster</NAME>
> <NP>1</NP>
> <TIME>4.61515307426453</TIME>
> </MPITEST>
> <MPITEST>
> <NP>2</NP>
> <TIME>4.76016402244568</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>multirma</NAME>
> <NP>2</NP>
> <WORKDIR>./threads/rma</WORKDIR>
> <TIME>13.116791009903</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>multiget</NAME>
> <NP>2</NP>
> <TIME>1.16117405891418</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>multifence</NAME>
> <NP>3</NP>
> <TIME>0.10953688621521</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>allred</NAME>
> <NP>2</NP>
> <WORKDIR>./threads/coll</WORKDIR>
> <TIME>1.10431599617004</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>iallred</NAME>
> <NP>2</NP>
> <TIME>1.08454394340515</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>abort</NAME>
> <NP>2</NP>
> <WORKDIR>./ft</WORKDIR>
> <TIME>0</TIME>
> </MPITEST>
> <MPITEST>
> <NAME>senddead</NAME>
> <NP>2</NP>
> <TIME>0</TIME>
> <TESTDIFF>
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>recvdead</NAME>
> <NP>2</NP>
> <TIME>0</TIME>
> <TESTDIFF>
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>isenddead</NAME>
> <NP>2</NP>
> <TIME>0</TIME>
> <TESTDIFF>
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>irecvdead</NAME>
> <NP>2</NP>
> <TIME>0</TIME>
> <TESTDIFF>
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>agree_shrink</NAME>
> <NP>4</NP>
> <TIME>0</TIME>
> <TESTDIFF>
> </TESTDIFF>
> </MPITEST>
> <MPITEST>
> <NAME>collparmt</NAME>
> <NP>16</NP>
> <WORKDIR>./impls/mpich/mpi_t</WORKDIR>
> <TIME>0.317162990570068</TIME>
> </MPITEST>
