[petsc-dev] [mpich-discuss] Is mpich/master:a8a2b30fd21 tested with Petsc?
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Tue Mar 27 21:09:39 CDT 2018
Hi Min and Matthew,
In fact, I just ran an "hello word" on 2 processes and it works. I do
not have a more complicated example without PETSc since I have a
Petsc-based source code...
However, I just tried to launch "make testing" into the mpich directory
and it ended with some failed tests and it was very long: about an
hour. Is it normal?
Please, see the attached file: summary.xml
Eric
On 27/03/18 05:04 PM, Matthew Knepley wrote:
> On Tue, Mar 27, 2018 at 4:59 PM, Min Si <msi at anl.gov
> <mailto:msi at anl.gov>> wrote:
> Hi Eric,
> It will be great if you could give us a simple MPI program (not
> with PETSc) to reproduce this issue. If this is a problem happens
> only when PETSc is involved, the PETSc team can give you more
> suggestions.
> Hi Min,
> It is really easy to run PETSc at ANL. I am sure one of us can help if
> you cannot reproduce this bug on your own.
> Thanks,
> Matt
> Thanks,
> Min
> On 2018/03/27 15:38, Eric Chamberland wrote:
> Hi,
> since more than 2 weeks that the master branch of mpich is
> still and it can be reproduced with a simple "make test" after
> a fresh installation of PETSc...
> Is anyone testing it?
> Is it supposed to be working?
> Just tell me if I should "follow" another mpich branch please.
> Thanks,
> Eric
> On 14/03/18 03:35 AM, Eric Chamberland wrote:
> Hi,
> fwiw, the actual mpich/master branch doesn't passes the
> PETSc "make test" after a fresh installation... It hangs
> just afer the 1 MPI process test, meaning it is locked
> into the 2 process test:
> make
> PETSC_DIR=/pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/mpich-3.x-debug/petsc-3.8.3-debug
> PETSC_ARCH=arch-linux2-c-debug test
> Running test examples to verify correct installation
> Using
> and PETSC_ARCH=arch-linux2-c-debug
> C/C++ example src/snes/examples/tutorials/ex19 run
> successfully with 1 MPI process
> ^Cmakefile:151: recipe for target 'test' failed
> make: [test] Interrupt (ignored)
> thanks,
> Eric
> On 13/03/18 08:07 AM, Eric Chamberland wrote:
> Hi,
> each night we are testing mpich/master with our
> petsc-based code. I don't know if PETSc team is doing
> the same thing with mpich/master? (Maybe it is a
> good idea?)
> Everything was fine (except the issue
> https://github.com/pmodels/mpich/issues/2892
> <https://github.com/pmodels/mpich/issues/2892>) up to
> commit 7b8d64debd, but since commit
> mpich:a8a2b30fd21), I have a segfault on a any
> parallel nightly test.
> For example, a 2 process test ends at almost different
> execution points:
> rank 0:
> #003: /lib64/libpthread.so.0(+0xf870) [0x7f25bf908870]
> #004:
> /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/BIB/bin/BIBMEFGD.opt()
> [0x64a788]
> #005: /lib64/libc.so.6(+0x35140) [0x7f25bca18140]
> #006: /lib64/libc.so.6(__poll+0x2d) [0x7f25bcabfbfd]
> #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9)
> [0x7f25bd90ccc9]
> #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c)
> [0x7f25bd91255c]
> #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xba657)
> [0x7f25bd7e2657]
> #010:
> /opt/mpich-3.x_debug/lib/libmpi.so.0(PMPI_Waitall+0xe3)
> [0x7f25bd7e3343]
> #011:
> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscGatherMessageLengths+0x654)
> [0x7f25c4bb3193]
> #012:
> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x859)
> [0x7f25c4e82d7f]
> #013:
> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate+0x5684)
> [0x7f25c4e4d055]
> #014:
> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhostWithArray+0x688)
> [0x7f25c4e01a39]
> #015:
> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhost+0x179)
> [0x7f25c4e020f6]
> rank 1:
> #002:
> /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/GIREF/lib/libgiref_opt_Util.so(traitementSignal+0x2bd0)
> [0x7f62df8e7310]
> #003: /lib64/libc.so.6(+0x35140) [0x7f62d3bc9140]
> #004: /lib64/libc.so.6(__poll+0x2d) [0x7f62d3c70bfd]
> #005: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9)
> [0x7f62d4abdcc9]
> #006: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c)
> [0x7f62d4ac355c]
> #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12c9c5)
> [0x7f62d4a059c5]
> #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12e102)
> [0x7f62d4a07102]
> #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf17a1)
> [0x7f62d49ca7a1]
> #010: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3facf)
> [0x7f62d4918acf]
> #011: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d)
> [0x7f62d4918c3d]
> #012: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf18d8)
> [0x7f62d49ca8d8]
> #013: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fb88)
> [0x7f62d4918b88]
> #014: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d)
> [0x7f62d4918c3d]
> #015:
> /opt/mpich-3.x_debug/lib/libmpi.so.0(MPI_Barrier+0x27b)
> [0x7f62d4918edb]
> #016:
> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscCommGetNewTag+0x3ff)
> [0x7f62dbceb055]
> #017:
> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscObjectGetNewTag+0x15d)
> [0x7f62dbceaadb]
> #018:
> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreateCommon_PtoS+0x1ee)
> [0x7f62dc03625c]
> #019:
> /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x29c4)
> [0x7f62dc035eea]
> #020:
> [0x7f62dbffe055]
> #021:
> [0x7f62dbfb2a39]
> #022:
> [0x7f62dbfb30f6]
> Have some other users (PETSc users?) reported problem?
> Thanks,
> Eric
> ps: usual informations:
> mpich logs:
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.log
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.log>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.system
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.system>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpich_version.txt
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpich_version.txt>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_c.txt
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_c.txt>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_m.txt
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_m.txt>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mi.txt
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_mi.txt>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_openmpa_config.log
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_openmpa_config.log>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpl_config.log
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpl_config.log>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_config.log
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_config.log>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_tools_topo_config.log
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_tools_topo_config.log>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpiexec_info.txt
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpiexec_info.txt>
> Petsc logs:
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_configure.log
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_configure.log>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_make.log
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_make.log>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_default.log
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_default.log>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_RDict.log
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_RDict.log>
> http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_CMakeLists.txt
> <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_CMakeLists.txt>
> discuss mailing list discuss at mpich.org <mailto:discuss at mpich.org>
> To manage subscription options or unsubscribe:
> https://lists.mpich.org/mailman/listinfo/discuss
> <https://lists.mpich.org/mailman/listinfo/discuss>
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180327/7d8a1ed4/attachment-0001.html>
Type: text/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180327/7d8a1ed4/attachment-0001.xml>
