[petsc-dev] [mpich-discuss] Is mpich/master:a8a2b30fd21 tested with Petsc?
    Min Si
    msi at anl.gov
    Tue Mar 27 22:57:39 CDT 2018
Hi Eric,
1 hour is normal for running the entire MPICH test suite. It looks like
your failures are either dynamic process (e.g., spawn) or fault
tolerance related tests. They should be irrelevant to the PETSc issue.
Min
On 2018/03/27 21:09, Eric Chamberland wrote:
> Hi Min and Matthew,
> In fact, I just ran an "hello word" on 2 processes and it works.  I do
> not have a more complicated example without PETSc since I have a
> Petsc-based source code...
> However, I just tried to launch "make testing" into the mpich
> directory and it ended with some failed tests  and it was very long:
> about an hour.  Is it normal?
> Please, see the attached file: summary.xml
> Thanks,
> Eric
> On 27/03/18 05:04 PM, Matthew Knepley wrote:
>> On Tue, Mar 27, 2018 at 4:59 PM, Min Si <msi at anl.gov
>> <mailto:msi at anl.gov>> wrote:
>>     Hi Eric,
>>     It will be great if you could give us a simple MPI program (not
>>     with PETSc) to reproduce this issue. If this is a problem happens
>>     only when PETSc is involved, the PETSc team can give you more
>>     suggestions.
>> Hi Min,
>> It is really easy to run PETSc at ANL. I am sure one of us can help
>> if you cannot reproduce this bug on your own.
>>   Thanks,
>>      Matt
>>     Thanks,
>>     Min
>>     On 2018/03/27 15:38, Eric Chamberland wrote:
>>         Hi,
>>         since more than 2 weeks that the master branch of mpich is
>>         still and it can be reproduced with a simple "make test"
>>         after a fresh installation of PETSc...
>>         Is anyone testing it?
>>         Is it supposed to be working?
>>         Just tell me if I should "follow" another mpich branch please.
>>         Thanks,
>>         Eric
>>         On 14/03/18 03:35 AM, Eric Chamberland wrote:
>>             Hi,
>>             fwiw, the actual mpich/master branch doesn't passes the
>>             PETSc "make test" after a fresh installation...  It hangs
>>             just afer the 1 MPI process test, meaning it is locked
>>             into the 2 process test:
>>             make
>>             PETSC_DIR=/pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/mpich-3.x-debug/petsc-3.8.3-debug
>>             PETSC_ARCH=arch-linux2-c-debug test
>>             Running test examples to verify correct installation
>>             Using
>>             and PETSC_ARCH=arch-linux2-c-debug
>>             C/C++ example src/snes/examples/tutorials/ex19 run
>>             successfully with 1 MPI process
>>             ^Cmakefile:151: recipe for target 'test' failed
>>             make: [test] Interrupt (ignored)
>>             thanks,
>>             Eric
>>             On 13/03/18 08:07 AM, Eric Chamberland wrote:
>>                 Hi,
>>                 each night we are testing mpich/master with our
>>                 petsc-based code. I don't know if PETSc team is doing
>>                 the same thing with mpich/master?   (Maybe it is a
>>                 good idea?)
>>                 Everything was fine (except the issue
>>                 https://github.com/pmodels/mpich/issues/2892
>>                 <https://github.com/pmodels/mpich/issues/2892>) up to
>>                 commit 7b8d64debd, but since commit
>>                 mpich:a8a2b30fd21), I have a segfault on a any
>>                 parallel nightly test.
>>                 For example, a 2 process test ends at almost
>>                 different execution points:
>>                 rank 0:
>>                 #003: /lib64/libpthread.so.0(+0xf870) [0x7f25bf908870]
>>                 #004:
>>                 /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/BIB/bin/BIBMEFGD.opt()
>>                 [0x64a788]
>>                 #005: /lib64/libc.so.6(+0x35140) [0x7f25bca18140]
>>                 #006: /lib64/libc.so.6(__poll+0x2d) [0x7f25bcabfbfd]
>>                 #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9)
>>                 [0x7f25bd90ccc9]
>>                 #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c)
>>                 [0x7f25bd91255c]
>>                 #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xba657)
>>                 [0x7f25bd7e2657]
>>                 #010:
>>                 /opt/mpich-3.x_debug/lib/libmpi.so.0(PMPI_Waitall+0xe3)
>>                 [0x7f25bd7e3343]
>>                 #011:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscGatherMessageLengths+0x654)
>>                 [0x7f25c4bb3193]
>>                 #012:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x859)
>>                 [0x7f25c4e82d7f]
>>                 #013:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate+0x5684)
>>                 [0x7f25c4e4d055]
>>                 #014:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhostWithArray+0x688)
>>                 [0x7f25c4e01a39]
>>                 #015:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhost+0x179)
>>                 [0x7f25c4e020f6]
>>                 rank 1:
>>                 #002:
>>                 /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/GIREF/lib/libgiref_opt_Util.so(traitementSignal+0x2bd0)
>>                 [0x7f62df8e7310]
>>                 #003: /lib64/libc.so.6(+0x35140) [0x7f62d3bc9140]
>>                 #004: /lib64/libc.so.6(__poll+0x2d) [0x7f62d3c70bfd]
>>                 #005: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9)
>>                 [0x7f62d4abdcc9]
>>                 #006: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c)
>>                 [0x7f62d4ac355c]
>>                 #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12c9c5)
>>                 [0x7f62d4a059c5]
>>                 #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12e102)
>>                 [0x7f62d4a07102]
>>                 #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf17a1)
>>                 [0x7f62d49ca7a1]
>>                 #010: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3facf)
>>                 [0x7f62d4918acf]
>>                 #011: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d)
>>                 [0x7f62d4918c3d]
>>                 #012: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf18d8)
>>                 [0x7f62d49ca8d8]
>>                 #013: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fb88)
>>                 [0x7f62d4918b88]
>>                 #014: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d)
>>                 [0x7f62d4918c3d]
>>                 #015:
>>                 /opt/mpich-3.x_debug/lib/libmpi.so.0(MPI_Barrier+0x27b)
>>                 [0x7f62d4918edb]
>>                 #016:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscCommGetNewTag+0x3ff)
>>                 [0x7f62dbceb055]
>>                 #017:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscObjectGetNewTag+0x15d)
>>                 [0x7f62dbceaadb]
>>                 #018:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreateCommon_PtoS+0x1ee)
>>                 [0x7f62dc03625c]
>>                 #019:
>>                 /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x29c4)
>>                 [0x7f62dc035eea]
>>                 #020:
>>                 [0x7f62dbffe055]
>>                 #021:
>>                 [0x7f62dbfb2a39]
>>                 #022:
>>                 [0x7f62dbfb30f6]
>>                 Have some other users (PETSc users?) reported problem?
>>                 Thanks,
>>                 Eric
>>                 ps: usual informations:
>>                 mpich logs:
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.system
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_config.system>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpich_version.txt
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpich_version.txt>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_c.txt
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_c.txt>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_m.txt
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_m.txt>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mi.txt
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_mi.txt>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_openmpa_config.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_openmpa_config.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpl_config.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpl_config.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_config.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_config.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_tools_topo_config.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_hydra_tools_topo_config.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpiexec_info.txt
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpiexec_info.txt>
>>                 Petsc logs:
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_configure.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_configure.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_make.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_make.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_default.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_default.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_RDict.log
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_RDict.log>
>>                 http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_CMakeLists.txt
>>                 <http://www.giref.ulaval.ca/%7Ecmpgiref/dernier_mpich/2018.03.12.05h39m54s_CMakeLists.txt>
>>         _______________________________________________
>>         discuss mailing list discuss at mpich.org <mailto:discuss at mpich.org>
>>         To manage subscription options or unsubscribe:
>>         https://lists.mpich.org/mailman/listinfo/discuss
>>         <https://lists.mpich.org/mailman/listinfo/discuss>
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180327/e05b3d0a/attachment-0001.html>
