[petsc-dev] HDF5 read attribute from HDF5
Sat Mar 24 13:51:18 CDT 2018
This looks fine to me. I have put it in a branch
   https://bitbucket.org/petsc/petsc/branch/knepley/fix-hdf5-attribute
and into next. It should promote to master in a week or so.
     Matt
On Mon, Mar 19, 2018 at 3:18 PM, Marek Pecha <marek.pecha at vsb.cz> wrote:
> Hello,
> I would like to request new functionality into
> PetscViewerHDF5ReadAttribute method. In HDF5 file, I can assign attributes
> to groups not only to datasets however the method allows reading attributes
> only from datasets. I think a new feature should be implemented easily -
> generalisation of dataset as the object - after then you can read
> attributes assigned to groups as well as datasets. I did a simple
> implementation in the attached file.
> Thank you,
> Marek
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180324/682fae4f/attachment.html>
