[petsc-dev] We have SSL problems with some sites
    Satish Balay
    balay at mcs.anl.gov
    Wed Mar 21 21:00:44 CDT 2018
Works for me..
Satish
On linux:
balay at asterix /home/balay/petsc (master=)
$ ./configure --download-gmp PETSC_ARCH=arch-gmp
             Configuring PETSc to compile on your system
===============================================================================        It appears you do not have valgrind installed on your system.        We HIGHLY recommend you install it from www.valgrind.org        Or install valgrind-devel or equivalent using your package manager.        Then rerun ./configure        ===============================================================================        ===============================================================================        Trying to download https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2 for GMP        ===============================================================================        ===============================================================================        Running configure on GMP; this may take several minutes        ===============================================================================        ===============================================================================        Running make on GMP; this may take several minutes        ===============================================================================        <snip>
On Mac:
balay at ipro^~/petsc(master) $ ./configure --download-gmp PETSC_ARCH=arch-gmp
<snip>
On Thu, 22 Mar 2018, Matthew Knepley wrote:
> Nope, I get failure with that as well.
>    Matt
> On Wed, Mar 21, 2018 at 9:55 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > I get
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> > details):
> > Error during download/extract/detection of GMP:
> > Unable to download package GMP from: https://gmplib.org/download/
> > * If URL specified manually - perhaps there is a typo?
> > * If your network is disconnected - please reconnect and rerun ./configure
> > * Or perhaps you have a firewall blocking the download
> > * You can run with --with-packages-dir=/adirectory and ./configure will
> > instruct you what packages to download manually
> > * or you can download the above URL manually, to
> > /yourselectedlocation/gmp-6.0.0a.tar.bz2
> >   and use the configure option:
> >   --download-gmp=/yourselectedlocation/gmp-6.0.0a.tar.bz2
> > when configuring. I am trying with urllib2 instead.
> >   Matt
> > On Wed, Mar 21, 2018 at 9:52 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> both wget and curl work for me.. [both on linux and Mac]
> >> Satish
> >> ----------- linux --------------
> >> balay at asterix /home/balay/tmp
> >> $ wget https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2
> >> --2018-03-21 20:48:58--  https://gmplib.org/download/gm
> >> Resolving gmplib.org (gmplib.org)... 130.242.124.102
> >> Connecting to gmplib.org (gmplib.org)|130.242.124.102|:443... connected.
> >> HTTP request sent, awaiting response... 200 OK
> >> Length: 2319400 (2.2M) [application/octet-stream]
> >> Saving to: ‘gmp-6.0.0a.tar.bz2’
> >> gmp-6.0.0a.tar.bz2                          100%[=========================
> >>  2.21M   438KB/s    in 5.3s
> >> 2018-03-21 20:49:04 (431 KB/s) - ‘gmp-6.0.0a.tar.bz2’ saved
> >> [2319400/2319400]
> >> $ curl -O https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2
> >>   % Total    % Received % Xferd  Average Speed   Time    Time     Time
> >> Current
> >>                                  Dload  Upload   Total   Spent    Left
> >> Speed
> >> 100 2265k  100 2265k    0     0   371k      0  0:00:06  0:00:06 --:--:--
> >> 436k
> >> ------------- mac -------------------
> >> [petsc at ipro ~]$ curl -O https://gmplib.org/download/gm
> >> Current
> >> Speed
> >> 100 2265k  100 2265k    0     0  1223k      0  0:00:01  0:00:01 --:--:--
> >> 1223k
> >> [petsc at ipro ~]$ wget  https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2
> >> --2018-03-21
> >> <https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2--2018-03-21>
> >> 20:51:12--  https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2
> >> Saving to: ‘gmp-6.0.0a.tar.bz2.1’
> >> gmp-6.0.0a.tar.bz2.1                        100%[=========================
> >>  2.21M   423KB/s    in 6.1s
> >> 2018-03-21 20:51:19 (372 KB/s) - ‘gmp-6.0.0a.tar.bz2.1’ saved
> >> [2319400/2319400]
> >> [petsc at ipro ~]$
> >> > I fail when retrieving GMP, and I get
> >> >  4next $:/PETSc3/petsc/petsc-dev$ wget --secure-protocol=TLSv1
> >> > https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2 .
> >> > --2018-03-21 21:33:42--  https://gmplib.org/download/gm
> >> connected.
> >> > Unable to establish SSL connection.
> >> > --2018-03-21 21:33:43--  http://./
> >> > Resolving . (.)... failed: nodename nor servname provided, or not known.
> >> > wget: unable to resolve host address `.'
> >> >  4next $:/PETSc3/petsc/petsc-dev$ wget --no-check-certificate
> >> > --2018-03-21 21:34:20--  https://gmplib.org/download/gm
> >> connected.
> >> > --2018-03-21 21:34:20--  http://./
> >> >  130next $:/PETSc3/petsc/petsc-dev$ curl
> >> > https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2 > gmp-6.0.0a.tar.bz2
> >> > curl https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2 >
> >> gmp-6.0.0a.tar.bz2
> >> > Current
> >> > Speed
> >> > 100 2265k  100 2265k    0     0   288k      0  0:00:07  0:00:07 --:--:--
> >> > 408k
> >> > next $:/PETSc3/petsc/petsc-dev$ file gmp-6.0.0a.tar.bz2
> >> > gmp-6.0.0a.tar.bz2: bzip2 compressed data, block size = 900k
> >> > on my Mac.
> >> >    Matt
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which their
> > experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
