[petsc-dev] We have SSL problems with some sites
Thu Mar 22 04:47:37 CDT 2018
On Wed, Mar 21, 2018 at 10:00 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Works for me..
Well, I am not kidding when I say it fails for me. How do I debug this?
   Matt
> Satish
> On linux:
> balay at asterix /home/balay/petsc (master=)
> $ ./configure --download-gmp PETSC_ARCH=arch-gmp
>              Configuring PETSc to compile on your system
>                          It appears you do not have valgrind installed on
> your system.
>                                                    We HIGHLY recommend you
> install it from www.valgrind.org
>   Or install valgrind-devel or equivalent using your package manager.
>                            Then rerun ./configure
>                          Trying to download https://gmplib.org/download/
> gmp/gmp-6.0.0a.tar.bz2 for GMP
>    Running configure on GMP; this may take several minutes
>                          Running make on GMP; this may take several
> minutes
>     <snip>
> On Mac:
> balay at ipro^~/petsc(master) $ ./configure --download-gmp
> PETSC_ARCH=arch-gmp
> minutes
> <snip>
> On Thu, 22 Mar 2018, Matthew Knepley wrote:
> > Nope, I get failure with that as well.
> >    Matt
> > On Wed, Mar 21, 2018 at 9:55 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > I get
> > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for
> > > details):
> > > Error during download/extract/detection of GMP:
> > > Unable to download package GMP from: https://gmplib.org/download/
> > > * If URL specified manually - perhaps there is a typo?
> > > * If your network is disconnected - please reconnect and rerun
> ./configure
> > > * Or perhaps you have a firewall blocking the download
> > > * You can run with --with-packages-dir=/adirectory and ./configure
> will
> > > instruct you what packages to download manually
> > > * or you can download the above URL manually, to
> > > /yourselectedlocation/gmp-6.0.0a.tar.bz2
> > >   and use the configure option:
> > >   --download-gmp=/yourselectedlocation/gmp-6.0.0a.tar.bz2
> > > when configuring. I am trying with urllib2 instead.
> > >   Matt
> > > On Wed, Mar 21, 2018 at 9:52 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > >> both wget and curl work for me.. [both on linux and Mac]
> > >> Satish
> > >> ----------- linux --------------
> > >> balay at asterix /home/balay/tmp
> > >> $ wget https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2
> > >> --2018-03-21 20:48:58--  https://gmplib.org/download/gm
> > >> Resolving gmplib.org (gmplib.org)... 130.242.124.102
> > >> Connecting to gmplib.org (gmplib.org)|130.242.124.102|:443...
> connected.
> > >> HTTP request sent, awaiting response... 200 OK
> > >> Length: 2319400 (2.2M) [application/octet-stream]
> > >> Saving to: ‘gmp-6.0.0a.tar.bz2’
> > >> gmp-6.0.0a.tar.bz2
> 100%[=========================
> > >>  2.21M   438KB/s    in 5.3s
> > >> 2018-03-21 20:49:04 (431 KB/s) - ‘gmp-6.0.0a.tar.bz2’ saved
> > >> [2319400/2319400]
> > >> $ curl -O https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2
> > >>   % Total    % Received % Xferd  Average Speed   Time    Time     Time
> > >> Current
> > >>                                  Dload  Upload   Total   Spent    Left
> > >> Speed
> > >> 100 2265k  100 2265k    0     0   371k      0  0:00:06  0:00:06
> > >> 436k
> > >> ------------- mac -------------------
> > >> [petsc at ipro ~]$ curl -O https://gmplib.org/download/gm
> > >> Current
> > >> Speed
> > >> 100 2265k  100 2265k    0     0  1223k      0  0:00:01  0:00:01
> > >> 1223k
> > >> [petsc at ipro ~]$ wget  https://gmplib.org/download/
> > >> --2018-03-21
> > >> <https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2--2018-03-21>
> > >> 20:51:12--  https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2
> connected.
> > >> Saving to: ‘gmp-6.0.0a.tar.bz2.1’
> > >>  2.21M   423KB/s    in 6.1s
> > >> 2018-03-21 20:51:19 (372 KB/s) - ‘gmp-6.0.0a.tar.bz2.1’ saved
> > >> [2319400/2319400]
> > >> [petsc at ipro ~]$
> > >> > I fail when retrieving GMP, and I get
> > >> >  4next $:/PETSc3/petsc/petsc-dev$ wget --secure-protocol=TLSv1
> > >> > https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2 .
> > >> > --2018-03-21 21:33:42--  https://gmplib.org/download/gm
> > >> connected.
> > >> > Unable to establish SSL connection.
> > >> > --2018-03-21 21:33:43--  http://./
> > >> > Resolving . (.)... failed: nodename nor servname provided, or not
> known.
> > >> > wget: unable to resolve host address `.'
> > >> >  4next $:/PETSc3/petsc/petsc-dev$ wget --no-check-certificate
> > >> > --2018-03-21 21:34:20--  https://gmplib.org/download/gm
> > >> connected.
> > >> > --2018-03-21 21:34:20--  http://./
> known.
> > >> >  130next $:/PETSc3/petsc/petsc-dev$ curl
> > >> > https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2 >
> gmp-6.0.0a.tar.bz2
> > >> > curl https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2 >
> > >> gmp-6.0.0a.tar.bz2
>  Time
> > >> > Current
> Left
> > >> > Speed
> > >> > 100 2265k  100 2265k    0     0   288k      0  0:00:07  0:00:07
> > >> > 408k
> > >> > next $:/PETSc3/petsc/petsc-dev$ file gmp-6.0.0a.tar.bz2
> > >> > gmp-6.0.0a.tar.bz2: bzip2 compressed data, block size = 900k
> > >> > on my Mac.
> > >> >    Matt
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to which
> their
> > > experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180322/c34fe3a4/attachment-0001.html>
