[petsc-dev] We have SSL problems with some sites
Wed Mar 21 20:55:34 CDT 2018
Nope, I get failure with that as well.
   Matt
On Wed, Mar 21, 2018 at 9:55 PM, Matthew Knepley <knepley at gmail.com> wrote:
> I get
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Error during download/extract/detection of GMP:
> Unable to download package GMP from: https://gmplib.org/download/
> gmp/gmp-6.0.0a.tar.bz2
> * If URL specified manually - perhaps there is a typo?
> * If your network is disconnected - please reconnect and rerun ./configure
> * Or perhaps you have a firewall blocking the download
> * You can run with --with-packages-dir=/adirectory and ./configure will
> instruct you what packages to download manually
> * or you can download the above URL manually, to
> /yourselectedlocation/gmp-6.0.0a.tar.bz2
>   and use the configure option:
>   --download-gmp=/yourselectedlocation/gmp-6.0.0a.tar.bz2
> when configuring. I am trying with urllib2 instead.
>   Matt
> On Wed, Mar 21, 2018 at 9:52 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> both wget and curl work for me.. [both on linux and Mac]
>> Satish
>> ----------- linux --------------
>> balay at asterix /home/balay/tmp
>> $ wget https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2
>> --2018-03-21 20:48:58--  https://gmplib.org/download/gm
>> Resolving gmplib.org (gmplib.org)... 130.242.124.102
>> Connecting to gmplib.org (gmplib.org)|130.242.124.102|:443... connected.
>> HTTP request sent, awaiting response... 200 OK
>> Length: 2319400 (2.2M) [application/octet-stream]
>> Saving to: ‘gmp-6.0.0a.tar.bz2’
>> gmp-6.0.0a.tar.bz2                          100%[=========================
>>  2.21M   438KB/s    in 5.3s
>> 2018-03-21 20:49:04 (431 KB/s) - ‘gmp-6.0.0a.tar.bz2’ saved
>> [2319400/2319400]
>> $ curl -O https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2
>>   % Total    % Received % Xferd  Average Speed   Time    Time     Time
>> Current
>>                                  Dload  Upload   Total   Spent    Left
>> Speed
>> 100 2265k  100 2265k    0     0   371k      0  0:00:06  0:00:06 --:--:--
>> 436k
>> ------------- mac -------------------
>> [petsc at ipro ~]$ curl -O https://gmplib.org/download/gm
>> Current
>> Speed
>> 100 2265k  100 2265k    0     0  1223k      0  0:00:01  0:00:01 --:--:--
>> 1223k
>> [petsc at ipro ~]$ wget  https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2
>> --2018-03-21
>> <https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2--2018-03-21>
>> 20:51:12--  https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2
>> Saving to: ‘gmp-6.0.0a.tar.bz2.1’
>> gmp-6.0.0a.tar.bz2.1                        100%[=========================
>>  2.21M   423KB/s    in 6.1s
>> 2018-03-21 20:51:19 (372 KB/s) - ‘gmp-6.0.0a.tar.bz2.1’ saved
>> [2319400/2319400]
>> [petsc at ipro ~]$
>> On Thu, 22 Mar 2018, Matthew Knepley wrote:
>> > I fail when retrieving GMP, and I get
>> >  4next $:/PETSc3/petsc/petsc-dev$ wget --secure-protocol=TLSv1
>> > https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2 .
>> > --2018-03-21 21:33:42--  https://gmplib.org/download/gm
>> connected.
>> > Unable to establish SSL connection.
>> > --2018-03-21 21:33:43--  http://./
>> > Resolving . (.)... failed: nodename nor servname provided, or not known.
>> > wget: unable to resolve host address `.'
>> >  4next $:/PETSc3/petsc/petsc-dev$ wget --no-check-certificate
>> > --2018-03-21 21:34:20--  https://gmplib.org/download/gm
>> connected.
>> > --2018-03-21 21:34:20--  http://./
>> >  130next $:/PETSc3/petsc/petsc-dev$ curl
>> > https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2 > gmp-6.0.0a.tar.bz2
>> > curl https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2 >
>> gmp-6.0.0a.tar.bz2
>> > Current
>> > Speed
>> > 100 2265k  100 2265k    0     0   288k      0  0:00:07  0:00:07 --:--:--
>> > 408k
>> > next $:/PETSc3/petsc/petsc-dev$ file gmp-6.0.0a.tar.bz2
>> > gmp-6.0.0a.tar.bz2: bzip2 compressed data, block size = 900k
>> > on my Mac.
>> >    Matt
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180321/b0b84437/attachment-0001.html>
