[petsc-dev] Test Code Coverage (gcov) page is missing
Jed Brown
jed at jedbrown.org
Fri Mar 16 11:35:48 CDT 2018
Satish Balay <balay at mcs.anl.gov> writes:
> On Fri, 16 Mar 2018, Junchao Zhang wrote:
>> The coverage page at http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/index.html
>> is missing. When I read certain PETSc code, I feel some if conditions will
>> never be met (i.e., there are dead statements). To confirm that, I want to
>> know which tests run into that condition.
> Thanks - its updated now.
> Jed,
> I must have messedup the testing of the latest gcov changes..
> [thwomp:petsc/nightlylogs/gcov] petsc> cat ~/nightlylogs/archive/2018/03/16/gcov-snapshot-update.log
> Traceback (most recent call last):
> File "/sandbox/petsc/petsc.clone/lib/petsc/bin/maint/gcov.py", line 18, in <module>
> PETSC_ARCH = os.environ['PETSC_ARCH']
> File "/usr/lib/python2.7/UserDict.py", line 23, in __getitem__
> raise KeyError(key)
> KeyError: 'PETSC_ARCH'
> So the issue is - this script is run in 2 different modes:
> lib/petsc/bin/maint/gcov.py: print " ./gcov.py -run_gcov "
> lib/petsc/bin/maint/gcov.py: print " ./gcov.py -merge_gcov [LOC] tarballs"
> For the second mode is with [LOC] - i.e there is no prior build - i.e no PETSC_ARCH
> So how about the following change?
> diff --git a/lib/petsc/bin/maint/gcov.py b/lib/petsc/bin/maint/gcov.py
> index 6d0e1e0..0a49978 100755
> --- a/lib/petsc/bin/maint/gcov.py
> +++ b/lib/petsc/bin/maint/gcov.py
> @@ -14,10 +14,6 @@ import operator
> import sys
> from time import gmtime,strftime
> -PETSC_DIR = os.environ['PETSC_DIR']
> -PETSC_ARCH = os.environ['PETSC_ARCH']
> -OBJDIR = os.path.join(PETSC_DIR, PETSC_ARCH, 'obj')
So OBJDIR is only used in one place (so can just define it in that
scope) and PETSC_ARCH is only ever used to define OBJDIR.
But PETSC_DIR is needed by make_htmlpage (so both modes require it).
Not tested, but I assume this would work:
diff --git i/lib/petsc/bin/maint/gcov.py w/lib/petsc/bin/maint/gcov.py
index 6d0e1e0342..f4072c3076 100755
--- i/lib/petsc/bin/maint/gcov.py
+++ w/lib/petsc/bin/maint/gcov.py
@@ -15,8 +15,6 @@ import sys
def run_gcov(gcov_dir):
@@ -38,6 +36,8 @@ def run_gcov(gcov_dir):
csrc_file = file_name.endswith('.c')
if csrc_file:
c_file = file_name.split('.c')[0]
+ PETSC_ARCH = os.environ['PETSC_ARCH']
+ OBJDIR = os.path.join(PETSC_DIR, PETSC_ARCH, 'obj')
objpath = os.path.join(OBJDIR, os.path.relpath(c_file, PETSC_DIR))
gcov_graph_file = objpath+".gcno"
gcov_data_file = objpath+".gcda"
