[petsc-dev] Test Code Coverage (gcov) page is missing
Satish Balay
balay at mcs.anl.gov
Fri Mar 16 10:40:26 CDT 2018
On Fri, 16 Mar 2018, Junchao Zhang wrote:
> The coverage page at http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/index.html
> is missing. When I read certain PETSc code, I feel some if conditions will
> never be met (i.e., there are dead statements). To confirm that, I want to
> know which tests run into that condition.
Thanks - its updated now.
Jed,
I must have messedup the testing of the latest gcov changes..
[thwomp:petsc/nightlylogs/gcov] petsc> cat ~/nightlylogs/archive/2018/03/16/gcov-snapshot-update.log
Traceback (most recent call last):
File "/sandbox/petsc/petsc.clone/lib/petsc/bin/maint/gcov.py", line 18, in <module>
PETSC_ARCH = os.environ['PETSC_ARCH']
File "/usr/lib/python2.7/UserDict.py", line 23, in __getitem__
raise KeyError(key)
KeyError: 'PETSC_ARCH'
So the issue is - this script is run in 2 different modes:
lib/petsc/bin/maint/gcov.py: print " ./gcov.py -run_gcov "
lib/petsc/bin/maint/gcov.py: print " ./gcov.py -merge_gcov [LOC] tarballs"
For the second mode is with [LOC] - i.e there is no prior build - i.e no PETSC_ARCH
So how about the following change?
diff --git a/lib/petsc/bin/maint/gcov.py b/lib/petsc/bin/maint/gcov.py
index 6d0e1e0..0a49978 100755
--- a/lib/petsc/bin/maint/gcov.py
+++ b/lib/petsc/bin/maint/gcov.py
@@ -14,10 +14,6 @@ import operator
import sys
from time import gmtime,strftime
-PETSC_DIR = os.environ['PETSC_DIR']
-PETSC_ARCH = os.environ['PETSC_ARCH']
-OBJDIR = os.path.join(PETSC_DIR, PETSC_ARCH, 'obj')
def run_gcov(gcov_dir):
# 1. Runs gcov
@@ -389,11 +385,15 @@ def make_htmlpage(gcov_dir,LOC,tarballs):
def main():
+ global PETSC_DIR,PETSC_ARCH,OBJDIR
USER = os.environ['USER']
gcov_dir = "/tmp/gcov-"+USER
+ PETSC_DIR = os.environ['PETSC_DIR']
if (sys.argv[1] == "-run_gcov"):
print "Running gcov and creating tarball"
+ PETSC_ARCH = os.environ['PETSC_ARCH']
+ OBJDIR = os.path.join(PETSC_DIR, PETSC_ARCH, 'obj')
run_gcov(gcov_dir)
make_tarball(gcov_dir)
elif (sys.argv[1] == "-merge_gcov"):
Satish
