[petsc-dev] Test Code Coverage (gcov) page is missing
Fri Mar 16 21:26:17 CDT 2018
On Fri, 16 Mar 2018, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> > On Fri, 16 Mar 2018, Junchao Zhang wrote:
> >> The coverage page at http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/index.html
> >> is missing. When I read certain PETSc code, I feel some if conditions will
> >> never be met (i.e., there are dead statements). To confirm that, I want to
> >> know which tests run into that condition.
> > Thanks - its updated now.
> > Jed,
> > I must have messedup the testing of the latest gcov changes..
> > [thwomp:petsc/nightlylogs/gcov] petsc> cat ~/nightlylogs/archive/2018/03/16/gcov-snapshot-update.log
> > Traceback (most recent call last):
> >   File "/sandbox/petsc/petsc.clone/lib/petsc/bin/maint/gcov.py", line 18, in <module>
> >     PETSC_ARCH = os.environ['PETSC_ARCH']
> >   File "/usr/lib/python2.7/UserDict.py", line 23, in __getitem__
> >     raise KeyError(key)
> > KeyError: 'PETSC_ARCH'
> > So the issue is - this script is run in 2 different modes:
> > lib/petsc/bin/maint/gcov.py:        print "         ./gcov.py -run_gcov      "
> > lib/petsc/bin/maint/gcov.py:        print "         ./gcov.py -merge_gcov [LOC] tarballs"
> > For the second mode is with [LOC] - i.e there is no prior build - i.e no PETSC_ARCH
> > So how about the following change?
> > diff --git a/lib/petsc/bin/maint/gcov.py b/lib/petsc/bin/maint/gcov.py
> > index 6d0e1e0..0a49978 100755
> > --- a/lib/petsc/bin/maint/gcov.py
> > +++ b/lib/petsc/bin/maint/gcov.py
> > @@ -14,10 +14,6 @@ import operator
> >  import sys
> >  from   time import gmtime,strftime
> > -PETSC_DIR = os.environ['PETSC_DIR']
> > -PETSC_ARCH = os.environ['PETSC_ARCH']
> > -OBJDIR = os.path.join(PETSC_DIR, PETSC_ARCH, 'obj')
> So OBJDIR is only used in one place (so can just define it in that
> scope) and PETSC_ARCH is only ever used to define OBJDIR.
> But PETSC_DIR is needed by make_htmlpage (so both modes require it).
> Not tested, but I assume this would work:
> diff --git i/lib/petsc/bin/maint/gcov.py w/lib/petsc/bin/maint/gcov.py
> index 6d0e1e0342..f4072c3076 100755
> --- i/lib/petsc/bin/maint/gcov.py
> +++ w/lib/petsc/bin/maint/gcov.py
> @@ -15,8 +15,6 @@ import sys
>  def run_gcov(gcov_dir):
> @@ -38,6 +36,8 @@ def run_gcov(gcov_dir):
>              csrc_file = file_name.endswith('.c')
>              if csrc_file:
>                  c_file = file_name.split('.c')[0]
> +                PETSC_ARCH = os.environ['PETSC_ARCH']
> +                OBJDIR = os.path.join(PETSC_DIR, PETSC_ARCH, 'obj')
>                  objpath = os.path.join(OBJDIR, os.path.relpath(c_file, PETSC_DIR))
>                  gcov_graph_file = objpath+".gcno"
>                  gcov_data_file  = objpath+".gcda"
Thanks - pushed your version to master.
Satish
