[petsc-dev] Is ./configure --help broken?
    Satish Balay
    balay at mcs.anl.gov
    Fri Mar 16 08:26:38 CDT 2018
On Fri, 16 Mar 2018, Matthew Knepley wrote:
> This works for me. Do you want to put it in your branch, or should I check
> it in?
>    Matt
> diff --git a/config/BuildSystem/RDict.py b/config/BuildSystem/RDict.py
> index 2dc745f..efc8b81 100755
> --- a/config/BuildSystem/RDict.py
> +++ b/config/BuildSystem/RDict.py
> @@ -218,7 +218,7 @@ Arg class, which wraps the usual value.'''
>              print
>              pass
>        dict.__setitem__(self, key, value)
> -      self.save()
> +      self.save(force = 0)
>      else:
>        return self.send(key, value)
>      return
How about reducing the number of times save is called - i.e try
calling it only once at the end. Would that work?
index 2dc745f1aa..98a2a16a29 100755
@@ -195,7 +195,7 @@ Arg class, which wraps the usual value.'''
     else:
       self.writeLogLine('__getitem__: Setting local type for '+key)
       dict.__setitem__(self, key, nargs.Arg(key))
-      self.save()
+      #self.save()
     self.writeLogLine('__getitem__: Setting local value for '+key)
     return dict.__getitem__(self, key).getValue()
             print '-----------------------------------------------------------------------'
             pass
-      self.save()
+      #self.save()
     else:
     return
@@ -232,14 +232,14 @@ Arg class, which wraps the usual value.'''
     dict.__getitem__(self, key).setValue(value)
     self.writeLogLine('__setitem__: Set value for '+key+' to '+str(dict.__getitem__(self, key)))
-    self.save()
+    #self.save()
     return
   def __delitem__(self, key):
     '''Checks for the key locally, and if not found consults the parent. Deletes the Arg completely.'''
     if dict.has_key(self, key):
       dict.__delitem__(self, key)
-      self.save()
+      #self.save()
     elif not self.parent is None:
       self.send(key)
     return
@@ -248,7 +248,7 @@ Arg class, which wraps the usual value.'''
     '''Clears both the local and parent dictionaries'''
     if dict.__len__(self):
       dict.clear(self)
-      self.save()
+      #self.save()
       self.send()
     return
My simple 'configure --prefix && make && make install' test appears to
work with the above change - but don't know if the random crashes in
nightlybuilds will come back or not..
Satish
