[petsc-dev] Is ./configure --help broken?
Fri Mar 16 08:37:06 CDT 2018
On Fri, Mar 16, 2018 at 9:26 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 16 Mar 2018, Matthew Knepley wrote:
> > This works for me. Do you want to put it in your branch, or should I
> check
> > it in?
> >    Matt
> > diff --git a/config/BuildSystem/RDict.py b/config/BuildSystem/RDict.py
> > index 2dc745f..efc8b81 100755
> > --- a/config/BuildSystem/RDict.py
> > +++ b/config/BuildSystem/RDict.py
> > @@ -218,7 +218,7 @@ Arg class, which wraps the usual value.'''
> >              print
> >              pass
> >        dict.__setitem__(self, key, value)
> > -      self.save()
> > +      self.save(force = 0)
> >      else:
> >        return self.send(key, value)
> >      return
> How about reducing the number of times save is called - i.e try
> calling it only once at the end. Would that work?
> index 2dc745f1aa..98a2a16a29 100755
> @@ -195,7 +195,7 @@ Arg class, which wraps the usual value.'''
>      else:
>        self.writeLogLine('__getitem__: Setting local type for '+key)
>        dict.__setitem__(self, key, nargs.Arg(key))
> -      self.save()
> +      #self.save()
>      self.writeLogLine('__getitem__: Setting local value for '+key)
>      return dict.__getitem__(self, key).getValue()
>              print '-----------------------------
>              pass
> -      self.save()
> +      #self.save()
>      else:
>      return
> @@ -232,14 +232,14 @@ Arg class, which wraps the usual value.'''
>      dict.__getitem__(self, key).setValue(value)
>      self.writeLogLine('__setitem__: Set value for '+key+' to
> '+str(dict.__getitem__(self, key)))
> -    self.save()
> +    #self.save()
>      return
>    def __delitem__(self, key):
>      '''Checks for the key locally, and if not found consults the parent.
> Deletes the Arg completely.'''
>      if dict.has_key(self, key):
>        dict.__delitem__(self, key)
> -      self.save()
> +      #self.save()
>      elif not self.parent is None:
>        self.send(key)
>      return
> @@ -248,7 +248,7 @@ Arg class, which wraps the usual value.'''
>      '''Clears both the local and parent dictionaries'''
>      if dict.__len__(self):
>        dict.clear(self)
> -      self.save()
> +      #self.save()
>        self.send()
>      return
> My simple 'configure --prefix && make && make install' test appears to
> work with the above change - but don't know if the random crashes in
> nightlybuilds will come back or not..
I do not want to do that until its rewritten. There is already a save call
at the end which was not working.
   Matt
> Satish
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180316/8cdc0f8d/attachment.html>
