[petsc-dev] Is ./configure --help broken?
Matthew Knepley
knepley at gmail.com
Fri Mar 16 08:11:25 CDT 2018
On Fri, Mar 16, 2018 at 9:03 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 15, 2018 at 9:30 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Thu, 15 Mar 2018, Stefano Zampini wrote:
>> > it seems we can no longer print the available configure options in
>> master
>> > [szampini at localhost petsc]$ ./configure --help
>> > Configuring PETSc to compile on your system
>> Hm - its just taking a long time.. The trigger is this change.
>> 603e7a67219475153ffb5c1693e4f8ee41f93af7 is the first bad commit
>> commit 603e7a67219475153ffb5c1693e4f8ee41f93af7
>> Author: Satish Balay <balay at mcs.anl.gov>
>> Date: Thu Mar 8 20:02:30 2018 -0600
>> rdict: attempt to workarround (not always reproduceable) error
>> *** Using PETSC_DIR=/home/sandbox/petsc/petsc.next
>> PETSC_ARCH=arch-linux-opt-misc ***
>> No cached configure in RDict at /home/sandbox/petsc/petsc.next
>> /arch-linux-opt-misc/lib/petsc/conf/RDict.db
>> :040000 040000 654ea5265523cbcbb50b1104be63b5c7899b4478
>> 01384d9a268f7c89859c64f9f091bee066d47cda M config
>> But I see script.py has code:
>> if self.hasHelpFlag():
>> self.argDB.readonly = True
>> This code is not getting triggered '-h'/--help - I don't know if this is
>> the correct behavior. Matt?
> Satish, I don't think this can be our fix. This writes to disk every time
> a value is changed. We need to know
> why the forced write at the end of configure was not working. This makes
> everything forced.
> I will look at why readonly is not working.
This works for me. Do you want to put it in your branch, or should I check
it in?
Matt
diff --git a/config/BuildSystem/RDict.py b/config/BuildSystem/RDict.py
index 2dc745f..efc8b81 100755
--- a/config/BuildSystem/RDict.py
+++ b/config/BuildSystem/RDict.py
@@ -218,7 +218,7 @@ Arg class, which wraps the usual value.'''
print
pass
dict.__setitem__(self, key, value)
- self.save()
+ self.save(force = 0)
else:
return self.send(key, value)
return
> Matt
>> Same slowdown with --with-packages-dir= [which behaves as help in one
>> case - and no-help in the other case].. And we have this chane to fix
>> its its misbehavior with --prefix
>> 6ffe0648adde44dfc4a394659acd0d3e40176240
>> Satish
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180316/6809d247/attachment.html>
