[petsc-dev] Is ./configure --help broken?
Fri Mar 16 08:03:36 CDT 2018
On Thu, Mar 15, 2018 at 9:30 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 15 Mar 2018, Stefano Zampini wrote:
> > it seems we can no longer print the available configure options in master
> > [szampini at localhost petsc]$ ./configure --help
> >              Configuring PETSc to compile on your system
> Hm - its just taking a long time.. The trigger is this change.
> 603e7a67219475153ffb5c1693e4f8ee41f93af7 is the first bad commit
> commit 603e7a67219475153ffb5c1693e4f8ee41f93af7
> Author: Satish Balay <balay at mcs.anl.gov>
> Date:   Thu Mar 8 20:02:30 2018 -0600
>     rdict: attempt to workarround (not always reproduceable) error
>     *** Using PETSC_DIR=/home/sandbox/petsc/petsc.next
> PETSC_ARCH=arch-linux-opt-misc ***
>         No cached configure in RDict at /home/sandbox/petsc/petsc.
> next/arch-linux-opt-misc/lib/petsc/conf/RDict.db
> :040000 040000 654ea5265523cbcbb50b1104be63b5c7899b4478
> 01384d9a268f7c89859c64f9f091bee066d47cda M      config
> But I see script.py has code:
>    if self.hasHelpFlag():
>       self.argDB.readonly = True
> This code is not getting triggered '-h'/--help - I don't know if this is
> the correct behavior. Matt?
Satish, I don't think this can be our fix. This writes to disk every time a
value is changed. We need to know
why the forced write at the end of configure was not working. This makes
everything forced.
I will look at why readonly is not working.
  Matt
> Same slowdown with --with-packages-dir= [which behaves as help in one
> case - and no-help in the other case].. And we have this chane to fix
> its its misbehavior with --prefix
> 6ffe0648adde44dfc4a394659acd0d3e40176240
> Satish
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180316/d71c0439/attachment.html>
