[petsc-dev] Is ./configure --help broken?
Satish Balay
balay at mcs.anl.gov
Thu Mar 15 08:30:55 CDT 2018
On Thu, 15 Mar 2018, Stefano Zampini wrote:
> it seems we can no longer print the available configure options in master
> [szampini at localhost petsc]$ ./configure --help
> Configuring PETSc to compile on your system
Hm - its just taking a long time.. The trigger is this change.
603e7a67219475153ffb5c1693e4f8ee41f93af7 is the first bad commit
commit 603e7a67219475153ffb5c1693e4f8ee41f93af7
Author: Satish Balay <balay at mcs.anl.gov>
Date: Thu Mar 8 20:02:30 2018 -0600
rdict: attempt to workarround (not always reproduceable) error
*** Using PETSC_DIR=/home/sandbox/petsc/petsc.next PETSC_ARCH=arch-linux-opt-misc ***
No cached configure in RDict at /home/sandbox/petsc/petsc.next/arch-linux-opt-misc/lib/petsc/conf/RDict.db
:040000 040000 654ea5265523cbcbb50b1104be63b5c7899b4478 01384d9a268f7c89859c64f9f091bee066d47cda M config
But I see script.py has code:
if self.hasHelpFlag():
self.argDB.readonly = True
This code is not getting triggered '-h'/--help - I don't know if this is the correct behavior. Matt?
Same slowdown with --with-packages-dir= [which behaves as help in one
case - and no-help in the other case].. And we have this chane to fix
its its misbehavior with --prefix
6ffe0648adde44dfc4a394659acd0d3e40176240
Satish
