[petsc-dev] HDF5 download error
Mark Adams
mfadams at lbl.gov
Wed Jun 20 06:17:08 CDT 2018
This looks like it is a problem with NERSC, this does not work:
04:14 cori04 maint= ~/petsc_install/petsc$ ping ftp.mcs.anl.gov
PING ftp.mcs.anl.gov (140.221.6.23) 56(84) bytes of data.
On Wed, Jun 20, 2018 at 7:08 AM Mark Adams <mfadams at lbl.gov> wrote:
> I get this error downloading HDF5 on Cori at NERSC and it has worked
> before. This is on maint.
> Trying to download
> https://support.hdfgroup.org/ftp/HDF5/current18/src/hdf5-1.8.18.tar.gz
> for HDF5
> Trying to download
> http://ftp.mcs.anl.gov/pub/petsc/externalpackages/hdf5-1.8.18.tar.gz for
> HDF5
> Trying to download
> ftp://ftp.mcs.anl.gov/pub/petsc/externalpackages/hdf5-1.8.18.tar.gz for
> HDF5
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> Error during download/extract/detection of HDF5:
> file could not be opened successfully
> Downloaded package HDF5 from:
> https://support.hdfgroup.org/ftp/HDF5/current18/src/hdf5-1.8.18.tar.gz is
> not a tarball.
> [or installed python cannot process compressed files]
> * If you are behind a firewall - please fix your proxy and rerun
> ./configure
> For example at LANL you may need to set the environmental variable
> http_proxy (or HTTP_PROXY?) to http://proxyout.lanl.gov
> * You can run with --with-packages-dir=/adirectory and ./configure will
> instruct you what packages to download manually
> * or you can download the above URL manually, to
> /yourselectedlocation/hdf5-1.8.18.tar.gz
> and use the configure option:
> --download-hdf5=/yourselectedlocation/hdf5-1.8.18.tar.gz
> Unable to download package HDF5 from:
> * If URL specified manually - perhaps there is a typo?
> * If your network is disconnected - please reconnect and rerun ./configure
> * Or perhaps you have a firewall blocking the download
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180620/ea79db1e/attachment.html>
