[petsc-dev] HDF5 download error
Karl Rupp rupp at iue.tuwien.ac.at
Wed Jun 20 06:18:22 CDT 2018
Hi Mark,
the FTP server at MCS is down today. It should come back up later today.
Best regards,
Karli
On 06/20/2018 01:17 PM, Mark Adams wrote:
> This looks like it is a problem with NERSC, this does not work:
> 04:14 cori04 maint= ~/petsc_install/petsc$ ping ftp.mcs.anl.gov
> <http://ftp.mcs.anl.gov>
> PING ftp.mcs.anl.gov <http://ftp.mcs.anl.gov> (140.221.6.23) 56(84)
> bytes of data.
> On Wed, Jun 20, 2018 at 7:08 AM Mark Adams <mfadams at lbl.gov
> <mailto:mfadams at lbl.gov>> wrote:
>     I get this error downloading HDF5 on Cori at NERSC and it has worked
>     before. This is on maint.
>                            Trying to download
>     https://support.hdfgroup.org/ftp/HDF5/current18/src/hdf5-1.8.18.tar.gz
>     for HDF5
>       ===============================================================================        ===============================================================================        Trying to download http://ftp.mcs.anl.gov/pub/petsc/externalpackages/hdf5-1.8.18.tar.gz for HDF5                                                               ===============================================================================        ===============================================================================        Trying to download ftp://ftp.mcs.anl.gov/pub/petsc/externalpackages/hdf5-1.8.18.tar.gz for HDF5        ===============================================================================        *******************************************************************************
>               UNABLE to CONFIGURE with GIVEN OPTIONS    (see
>     configure.log for details):
>     Error during download/extract/detection of HDF5:
>     file could not be opened successfully
>     Downloaded package HDF5 from:
>     is not a tarball.
>     [or installed python cannot process compressed files]
>     * If you are behind a firewall - please fix your proxy and rerun
>     ./configure
>        For example at LANL you may need to set the environmental
>     variable http_proxy (or HTTP_PROXY?) to http://proxyout.lanl.gov
>     * You can run with --with-packages-dir=/adirectory and ./configure
>     will instruct you what packages to download manually
>     * or you can download the above URL manually, to
>     /yourselectedlocation/hdf5-1.8.18.tar.gz
>        and use the configure option:
>        --download-hdf5=/yourselectedlocation/hdf5-1.8.18.tar.gz
>     Unable to download package HDF5 from:
>     * If URL specified manually - perhaps there is a typo?
>     * If your network is disconnected - please reconnect and rerun
>     ./configure
>     * Or perhaps you have a firewall blocking the download
>     ./configure
