[petsc-dev] HDF5 download error
Mark Adams
mfadams at lbl.gov
Wed Jun 20 06:08:52 CDT 2018
I get this error downloading HDF5 on Cori at NERSC and it has worked
before. This is on maint.
Trying to download
https://support.hdfgroup.org/ftp/HDF5/current18/src/hdf5-1.8.18.tar.gz for
HDF5
Trying to download
http://ftp.mcs.anl.gov/pub/petsc/externalpackages/hdf5-1.8.18.tar.gz for
HDF5
Trying to download
ftp://ftp.mcs.anl.gov/pub/petsc/externalpackages/hdf5-1.8.18.tar.gz for
HDF5
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
details):
Error during download/extract/detection of HDF5:
file could not be opened successfully
Downloaded package HDF5 from:
https://support.hdfgroup.org/ftp/HDF5/current18/src/hdf5-1.8.18.tar.gz is
not a tarball.
[or installed python cannot process compressed files]
* If you are behind a firewall - please fix your proxy and rerun ./configure
For example at LANL you may need to set the environmental variable
http_proxy (or HTTP_PROXY?) to http://proxyout.lanl.gov
* You can run with --with-packages-dir=/adirectory and ./configure will
instruct you what packages to download manually
* or you can download the above URL manually, to
/yourselectedlocation/hdf5-1.8.18.tar.gz
and use the configure option:
--download-hdf5=/yourselectedlocation/hdf5-1.8.18.tar.gz
Unable to download package HDF5 from:
* If URL specified manually - perhaps there is a typo?
* If your network is disconnected - please reconnect and rerun ./configure
* Or perhaps you have a firewall blocking the download
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180620/3b3cb099/attachment.html>
