[petsc-dev] superlu_dist: update to version v5.4.0
Paul T. Bauman
ptbauman at gmail.com
Wed Jun 13 09:21:10 CDT 2018
On Wed, Jun 13, 2018 at 9:57 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Jun 12, 2018, at 9:36 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Sure - that will work.
> > But ultimately - if superlu and superlu_dist are separate packages
> > (and meant to be used from the same applicaton)- they should not have
> > any include files - that are common.
> > If they have common files - then there should be some version check
> > that prevent the wrong version of the common file from used.
> > Or perhaps some other better organizaton of files between the packages
> > is possible.
> > Alternative is - PETSc configure should eror out if one tries to use
> > both packages at the same time.
> We don't like this at all. Applications should be able to switch
> between packages at runtime not require reconfiguring and rebuild etc.
Not meaning to butt-in, but I wanted to reenforce this point from the user
perspective because we do this *all the time* (superlu in serial, then
superlu_dist in parallel) and would be very frustrating if it went away.
Paul
> Barry
> > Satish
> > On Tue, 12 Jun 2018, Xiaoye S. Li wrote:
> >> Satish,
> >> I forgot to update sequential superlu. Right now I am busy with a paper
> >> deadline on Friday. If I couldn't get to it before then, will certainly
> do
> >> it on Saturday.
> >> Is it sufficient to just update the master branch, without doing a new
> >> tarball release?
> >> Sherry
> >> On Tue, Jun 12, 2018 at 11:00 AM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> >>> For now - removed from next [until I figureout how to handle it]
> >>> One motivation for this change is xsdk at devel build [wrt ATPESC
> tutorials].
> >>> Satish
> >>> On Tue, 12 Jun 2018, Smith, Barry F. wrote:
> >>>> Complain to Sherry and have her fix it before moving the new release
> >>> into PETSc
> >>>> Barry
> >>>>> On Jun 12, 2018, at 10:59 AM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> >>>>> $ diff superlu/SRC/superlu_enum_consts.h
> >>> superlu_dist/SRC/superlu_enum_consts.h
> >>>>> 16a17
> >>>>>> * January 28, 2018
> >>>>> 28c29
> >>>>> < typedef enum {NOROWPERM, LargeDiag, MY_PERMR}
> >>> rowperm_t;
> >>>>>> typedef enum {NOROWPERM, LargeDiag_MC64, LargeDiag_AWPM, MY_PERMR}
> >>> rowperm_t;
> >>>>> 34c35,36
> >>>>> < typedef enum {LUSUP, UCOL, LSUB, USUB, LLVL, ULVL}
> >>> MemType;
> >>>>>> //typedef enum {LUSUP, UCOL, LSUB, USUB, LLVL, ULVL, NO_MEMTYPE}
> >>> MemType;
> >>>>>> typedef enum {USUB, LSUB, UCOL, LUSUP, LLVL, ULVL, NO_MEMTYPE}
> >>> MemType;
> >>>>> 69a72,74
> >>>>>> COMM_DIAG, /* Bcast diagonal block to process column */
> >>>>>> COMM_RIGHT, /* communicate L panel */
> >>>>>> COMM_DOWN, /* communicate U panel */
> >>>>> So superlu and superlu_dist share the same 'superlu_enum_consts.h'
> >>>>> file - but with differences that are now incompatible with each
> other.
> >>>>> I'm not sure how to resolve this..
> >>>>> Satish
> >>>>> On Tue, 12 Jun 2018, PETSc checkBuilds wrote:
> >>>>>> Dear PETSc developer,
> >>>>>> This email contains listings of contributions attributed to you by
> >>>>>> `git blame` that caused compiler errors or warnings in PETSc
> automated
> >>>>>> testing. Follow the links to see the full log files. Please attempt
> >>> to fix
> >>>>>> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you
> >>> are unable
> >>>>>> to resolve the issues.
> >>>>>> Thanks,
> >>>>>> The PETSc development team
> >>>>>> warnings attributed to commit https://bitbucket.org/petsc/
> >>> petsc/commits/8e05559
> >>>>>> src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:571
> >>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
> >>> 2018/06/12/build_next_arch-freebsd-cxx-pkgs-opt_wii.log]
> /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:571:8:
> >>> error: 'LargeDiag_MC64' was not declared in this scope
> >>> 2018/06/12/build_next_arch-linux-pkgs-cxx-mlib_el6.log]
> >>>>>> /home/sandbox/petsc/petsc.next-3/src/mat/impls/aij/mpi/
> >>> superlu_dist/superlu_dist.c:571:8: error: 'LargeDiag_MC64' was not
> >>> 2018/06/12/build_next_arch-osx-10.6-cxx-cmplx-pkgs-dbg_ipro.log]
> /Users/petsc/petsc.next-3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:571:8:
> >>> error: use of undeclared identifier 'LargeDiag_MC64'
> >>>>>> src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:574
> /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:574:8:
> >>> error: 'LargeDiag_AWPM' was not declared in this scope
> >>> superlu_dist/superlu_dist.c:574:8: error: 'LargeDiag_AWPM' was not
> /Users/petsc/petsc.next-3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:574:8:
> >>> error: use of undeclared identifier 'LargeDiag_AWPM'
> >>>>>> src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:720
> >>> superlu_dist/superlu_dist.c:720:25: error: 'LargeDiag_MC64' was not
> /Users/petsc/petsc.next-3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:720:25:
> /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:720:25:
> >>>>>> src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:723
> /Users/petsc/petsc.next-3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:723:25:
> /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:723:25:
> >>> superlu_dist/superlu_dist.c:723:25: error: 'LargeDiag_AWPM' was not
> >>>>>> To opt-out from receiving these messages - send a request to
> >>> petsc-dev at mcs.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180613/8465eb94/attachment.html>
