[petsc-dev] superlu_dist: update to version v5.4.0
Smith, Barry F. bsmith at mcs.anl.gov
Wed Jun 13 08:57:18 CDT 2018
> On Jun 12, 2018, at 9:36 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Sure - that will work.
> But ultimately - if superlu and superlu_dist are separate packages
> (and meant to be used from the same applicaton)- they should not have
> any include files - that are common.
> If they have common files - then there should be some version check
> that prevent the wrong version of the common file from used.
> Or perhaps some other better organizaton of files between the packages
> is possible.
> Alternative is - PETSc configure should eror out if one tries to use
> both packages at the same time.
   We don't like this at all. Applications should be able to switch between packages at runtime not require reconfiguring and rebuild etc.
    Barry
> Satish
> On Tue, 12 Jun 2018, Xiaoye S. Li wrote:
>> Satish,
>> I forgot to update sequential superlu. Right now I am busy with a paper
>> deadline on Friday. If I couldn't get to it before then, will certainly do
>> it on Saturday.
>> Is it sufficient to just update the master branch, without doing a new
>> tarball release?
>> Sherry
>> On Tue, Jun 12, 2018 at 11:00 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> For now - removed from next [until I figureout how to handle it]
>>> One motivation for this change is xsdk at devel build [wrt ATPESC tutorials].
>>> Satish
>>> On Tue, 12 Jun 2018, Smith, Barry F. wrote:
>>>>  Complain to Sherry and have her fix it before moving the new release
>>> into PETSc
>>>>   Barry
>>>>> On Jun 12, 2018, at 10:59 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> $ diff superlu/SRC/superlu_enum_consts.h
>>> superlu_dist/SRC/superlu_enum_consts.h
>>>>> 16a17
>>>>>> * January 28, 2018
>>>>> 28c29
>>>>> < typedef enum {NOROWPERM, LargeDiag, MY_PERMR}
>>> rowperm_t;
>>>>>> typedef enum {NOROWPERM, LargeDiag_MC64, LargeDiag_AWPM, MY_PERMR}
>>> rowperm_t;
>>>>> 34c35,36
>>>>> < typedef enum {LUSUP, UCOL, LSUB, USUB, LLVL, ULVL}
>>> MemType;
>>>>>> //typedef enum {LUSUP, UCOL, LSUB, USUB, LLVL, ULVL, NO_MEMTYPE}
>>> MemType;
>>>>>> typedef enum {USUB, LSUB, UCOL, LUSUP, LLVL, ULVL, NO_MEMTYPE}
>>> MemType;
>>>>> 69a72,74
>>>>>>   COMM_DIAG, /* Bcast diagonal block to process column */
>>>>>>   COMM_RIGHT, /* communicate L panel */
>>>>>>   COMM_DOWN, /* communicate U panel */
>>>>> So superlu and superlu_dist share the same 'superlu_enum_consts.h'
>>>>> file - but with differences that are now incompatible with each other.
>>>>> I'm not sure how to resolve this..
>>>>> Satish
>>>>> On Tue, 12 Jun 2018, PETSc checkBuilds wrote:
>>>>>> Dear PETSc developer,
>>>>>> This email contains listings of contributions attributed to you by
>>>>>> `git blame` that caused compiler errors or warnings in PETSc automated
>>>>>> testing.  Follow the links to see the full log files. Please attempt
>>> to fix
>>>>>> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you
>>> are unable
>>>>>> to resolve the issues.
>>>>>> Thanks,
>>>>>> The PETSc development team
>>>>>> warnings attributed to commit https://bitbucket.org/petsc/
>>> petsc/commits/8e05559
>>>>>> src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:571
>>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
>>> 2018/06/12/build_next_arch-freebsd-cxx-pkgs-opt_wii.log]
>>>>>>     /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:571:8:
>>> error: 'LargeDiag_MC64' was not declared in this scope
>>> 2018/06/12/build_next_arch-linux-pkgs-cxx-mlib_el6.log]
>>>>>>     /home/sandbox/petsc/petsc.next-3/src/mat/impls/aij/mpi/
>>> superlu_dist/superlu_dist.c:571:8: error: 'LargeDiag_MC64' was not
>>> 2018/06/12/build_next_arch-osx-10.6-cxx-cmplx-pkgs-dbg_ipro.log]
>>>>>>     /Users/petsc/petsc.next-3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:571:8:
>>> error: use of undeclared identifier 'LargeDiag_MC64'
>>>>>> src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:574
>>>>>>     /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:574:8:
>>> error: 'LargeDiag_AWPM' was not declared in this scope
>>> superlu_dist/superlu_dist.c:574:8: error: 'LargeDiag_AWPM' was not
>>>>>>     /Users/petsc/petsc.next-3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:574:8:
>>> error: use of undeclared identifier 'LargeDiag_AWPM'
>>>>>> src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:720
>>> superlu_dist/superlu_dist.c:720:25: error: 'LargeDiag_MC64' was not
>>>>>>     /Users/petsc/petsc.next-3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:720:25:
>>>>>>     /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:720:25:
>>>>>> src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:723
>>>>>>     /Users/petsc/petsc.next-3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:723:25:
>>>>>>     /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:723:25:
>>> superlu_dist/superlu_dist.c:723:25: error: 'LargeDiag_AWPM' was not
>>>>>> To opt-out from receiving these messages - send a request to
>>> petsc-dev at mcs.anl.gov.
