[petsc-dev] superlu_dist: update to version v5.4.0
    Satish Balay
    balay at mcs.anl.gov
    Tue Jun 12 21:36:10 CDT 2018
Sure - that will work.
But ultimately - if superlu and superlu_dist are separate packages
(and meant to be used from the same applicaton)- they should not have
any include files - that are common.
If they have common files - then there should be some version check
that prevent the wrong version of the common file from used.
Or perhaps some other better organizaton of files between the packages
is possible.
Alternative is - PETSc configure should eror out if one tries to use
both packages at the same time.
Satish
On Tue, 12 Jun 2018, Xiaoye S. Li wrote:
> Satish,
> I forgot to update sequential superlu. Right now I am busy with a paper
> deadline on Friday. If I couldn't get to it before then, will certainly do
> it on Saturday.
> Is it sufficient to just update the master branch, without doing a new
> tarball release?
> Sherry
> On Tue, Jun 12, 2018 at 11:00 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > For now - removed from next [until I figureout how to handle it]
> > One motivation for this change is xsdk at devel build [wrt ATPESC tutorials].
> > Satish
> > On Tue, 12 Jun 2018, Smith, Barry F. wrote:
> > >   Complain to Sherry and have her fix it before moving the new release
> > into PETSc
> > >    Barry
> > > > On Jun 12, 2018, at 10:59 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > > $ diff superlu/SRC/superlu_enum_consts.h
> > superlu_dist/SRC/superlu_enum_consts.h
> > > > 16a17
> > > >> * January 28, 2018
> > > > 28c29
> > > > < typedef enum {NOROWPERM, LargeDiag, MY_PERMR}
> >  rowperm_t;
> > > >> typedef enum {NOROWPERM, LargeDiag_MC64, LargeDiag_AWPM, MY_PERMR}
> > rowperm_t;
> > > > 34c35,36
> > > > < typedef enum {LUSUP, UCOL, LSUB, USUB, LLVL, ULVL}
> > MemType;
> > > >> //typedef enum {LUSUP, UCOL, LSUB, USUB, LLVL, ULVL, NO_MEMTYPE}
> > MemType;
> > > >> typedef enum {USUB, LSUB, UCOL, LUSUP, LLVL, ULVL, NO_MEMTYPE}
> > MemType;
> > > > 69a72,74
> > > >>    COMM_DIAG, /* Bcast diagonal block to process column */
> > > >>    COMM_RIGHT, /* communicate L panel */
> > > >>    COMM_DOWN, /* communicate U panel */
> > > > So superlu and superlu_dist share the same 'superlu_enum_consts.h'
> > > > file - but with differences that are now incompatible with each other.
> > > > I'm not sure how to resolve this..
> > > > Satish
> > > > On Tue, 12 Jun 2018, PETSc checkBuilds wrote:
> > > >> Dear PETSc developer,
> > > >> This email contains listings of contributions attributed to you by
> > > >> `git blame` that caused compiler errors or warnings in PETSc automated
> > > >> testing.  Follow the links to see the full log files. Please attempt
> > to fix
> > > >> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you
> > are unable
> > > >> to resolve the issues.
> > > >> Thanks,
> > > >>  The PETSc development team
> > > >> warnings attributed to commit https://bitbucket.org/petsc/
> > petsc/commits/8e05559
> > > >>  src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:571
> > > >>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
> > 2018/06/12/build_next_arch-freebsd-cxx-pkgs-opt_wii.log]
> > > >>      /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:571:8:
> > error: 'LargeDiag_MC64' was not declared in this scope
> > 2018/06/12/build_next_arch-linux-pkgs-cxx-mlib_el6.log]
> > > >>      /home/sandbox/petsc/petsc.next-3/src/mat/impls/aij/mpi/
> > superlu_dist/superlu_dist.c:571:8: error: 'LargeDiag_MC64' was not
> > 2018/06/12/build_next_arch-osx-10.6-cxx-cmplx-pkgs-dbg_ipro.log]
> > > >>      /Users/petsc/petsc.next-3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:571:8:
> > error: use of undeclared identifier 'LargeDiag_MC64'
> > > >>  src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:574
> > > >>      /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:574:8:
> > error: 'LargeDiag_AWPM' was not declared in this scope
> > superlu_dist/superlu_dist.c:574:8: error: 'LargeDiag_AWPM' was not
> > > >>      /Users/petsc/petsc.next-3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:574:8:
> > error: use of undeclared identifier 'LargeDiag_AWPM'
> > > >>  src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:720
> > superlu_dist/superlu_dist.c:720:25: error: 'LargeDiag_MC64' was not
> > > >>      /Users/petsc/petsc.next-3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:720:25:
> > > >>      /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:720:25:
> > > >>  src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:723
> > > >>      /Users/petsc/petsc.next-3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:723:25:
> > > >>      /usr/home/balay/petsc.next-2/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:723:25:
> > superlu_dist/superlu_dist.c:723:25: error: 'LargeDiag_AWPM' was not
> > > >> To opt-out from receiving these messages - send a request to
> > petsc-dev at mcs.anl.gov.
